Category:Development
Revision as of 04:13, 29 September 2016 by Lou (talk | contribs) (Full Kits Packing List)
About | Development | Community | RepRap Machines | Resources | Policy
An Extruder Design on a Reprap Darwin
This page aims to contain links to all RepRap related development. This is the leading-edge and experimental part of the RepRap experience!
Assembly instructions
  1. 01-A-9
  2. 02-B-6-1
  3. 03-B-7
  4. 04-B-5
  5. 05-B-4
  6. 06-B-6-3
  7. 07-B-6-2
  8. 08-B-2
  9. 09-B-3
  10. 10
  11. 11-B-4-1
  12. 12-B-4-2
  13. 13-B-7-1
  14. 14
  15. 15-A-6
  16. 16-A-10
Product Specifications
Parameters Description
Structure Aluminum profiles(black)
Frame Lead Screw
Print Size(X Y Z) 200×200×200mm/200×280×200mm
Layer Resolution 100 Microns
Print Precision 0.1-0.4mm
XY Axis Positioning Accuracy 0.012mm
Z Axis Positioning Accuracy 0.004mm
LCD Screen YES
Extruder single/dual/triple(Full Metal)
Control Board MKS Base 1.5v
Nozzle Size 0.2/0.3/0.4/0.5mm
Nozzle Temperature 210℃(MAX 260℃)
Heat Bed MK3
Power Supply DC 12v/250W
Connection SD Card or USB
OS Windows XP,Windows Vista,Windows 7,MAC OX
Software Repetier-Host,Cura,Slic3r
Material Type PLA,ABS,HIPS,Wood,PVA,Nylon,Flexiable PLA,Copper fill (metal)
Material Specifications 1.75mm
Machine Size 430×440×400mm
A Floor Units
2040 Aiuminum Extrusion 420mm (2040型材 420mm) 2
2040 Aiuminum Extrusion 400mm (2040型材 400mm) 1
2020 Aiuminum Extrusion 400mm (2020型材 400mm) 1
2020 Aiuminum Extrusion 380mm (2020型材 380mm) 1
Threaded Rods 380m (丝杆 380mm) 1
Aluminum Wires Holder (型材藏线管) 3
2040 Aluminum Extrusion 150mm (2040型材 150mm) 2
Acrylic For LCD Display (亚克力 -显示屏) 2
2004 LCD Display 1
screw Kits A-6 (螺丝包 -A6) 1
Acrylic For L Alunimun Connector (压克力 - L型) 2
screw Kits A-7 (螺丝包 -A7) 1
Acrylic For End Stop (亚克力 -限位开关) 2
screw Kits A-8 (螺丝包 -A8) 1
X Carriage -Holde (亚克力 -X轴马车) 1
screw Kits A-9 1
Other useful templates
Other templates can be added to a page as well. you can use them as flags to alert other users to issues with a page, or of upcoming changes. Templates can be added by putting {{ currly brackets }} around the template name. Some templates have useful parameters, so it's best to check the template page for more detailed instructions.
