Category:Prusa i3 Development
Dutchie3719's Partial SAE Conversion
Currently in development is a partial SAE conversion
All Manufactured Parts will be manufactured using SAE tooling & measurements
All Rods will Remain Metric
All Bolts & Hardware will Remain Metric
Changed from RP to CNC
- Y-Corners.stl
- Z-axis-bottom.stl
- Z-axis-top.stl
- Ymotor.stl
Changed from AWJ / Laser to CNC
- Prusa3Wood-v4.dxf
CAD / Solidworks Most STL files are being re-drawn from .STL Form to .SLDPRT and engineering drawings will be produced.
Thingiverse
There are a number of interesting add-ons for the Prusa i3 on Thingiverse.com. Search for 'i3' or 'Prusa'.
Besides the add-ons and accessories, there are numerous Prusa i3 variants published on Thingiverse:
- Prusa i3 Improved for laser cut by Twelvepro.com - [1] (also see these pictures of an assembled Prusa i3 Twelvepro )
- P3Steel by irobri, a Prusa i3 Twelvepro remix using laser-cut 3mm steel.
- Prusa i3 aluminum frame w/ aluminum upgrades by Nathaniel E. Bolin - [2]
- Prusa I3 using aluminum profile by ju jusujn - [3]
note on alluminium 6mm dxf file
A note if getting the frame cut make sure the holes are smaller waterjet cutting made them 3.25 to big to tap m3
Graber i3 Laser Cut Design by S. Graber
- Complete laser cut design by S. Graber (no printed parts) - http://twelvepro.com/index.php?route=product/product&product_id=52
- Assembly pictures are here - http://twelvepro.com/news/graber-i3-assembly/
Prusa i3 Development and Open Source licenses
Josef Prusa, the genius designer of the various 3D printers that bear his name, has a repository on GitHub with among many other things, the OpenSCAD source code for the printed parts for his Prusa i3. The availability of this source code has made possible the continuous development of new, improved printed parts for the many Prusa i3 variants available around the world.
Here is the header from one of these OpenSCAD files:
- // PRUSA iteration3
- // X end motor
- // GNU GPL v3
- // Josef Průša <[email protected]> and contributors
The header clearly states these OpenSCAD source files are made available under the GPLV3 license.
I have done some research to trace the evolution of some of Josef Prusa's designs and I found that in many cases, the GPLV3 license was not exactly respected.
I have added a page to this wiki about this with a specific example: Genealogy / Archeology of the Prusa i3 X Motor End
I urge all developers to properly adhere to and not stray away from, the spirit and the letter of whatever license was used originally for the source code and designs they are working on, as only in this way can further development and improvements remain possible.
Pages in category "Prusa i3 Development"
The following 23 pages are in this category, out of 23 total.
