Prusa i3 Hephestos
Revision as of 15:48, 8 August 2014 by JustMaD (talk | contribs) (Preparation of the threaded rods M8 - Part 1)
Prusa i3 Hephestos
Introduction
Facilitate the installation and set-up of the printer.
Prusa 3D printer Hephestos is an open source 3D printer designed and developed by the bq Department of Innovation and Robotics. Hephestos is based on the Prusa i3 and adds several improvements to other printers like PowerCode. Parts were developed by the RepRap community with modifications and new parts added by bq.
This project has sought to offer a robust printer design, addressing many of the shortcomings of earlier designs such as end-stop positioning and wiring routing. We have placed particular emphasis on providing good documentation to facilitate its assembly.
Where to buy
 - bq Spain - (author) - free shipment
 - Leds & Chips Assembled - Portugal
 - Leds & Chips Portugal
 - Iniciativas 3D Spain
 - wi3d Print Spain
 - 3D Proditive Shop Spain
 - Simac Spain
 - Crea3D Italy
 - 3DPrinter Store Ch
Building Instructions Video (Youtube):
<videoflash type="youtube">nvTeJvRi8Bo</videoflash>
Prusa i3: Unboxing video (Youtube):
<videoflash type="youtube">c_TUTrBQ2XU</videoflash>
Gallery
  • Technical specifications
    Dimensions
    -Printer Dimensions: 460(X) x 370(Y) x 510 mm(Z without roll) 583 mm(Z with roll )
    -Print Area Dimensions: 215(X) x 210(Y) x 180 mm(Z)
    -Box Dimensions: 400(X) x 400(Y) x 250 mm(Z)
    Mechanical Construction
    -Powder coated aluminium frame & base
    -Smooth chrome rods for bearing carriages X, Y, Z
    -Linear ball bearing LM8UU for X, Y, Z
    -Axial ball bearing pulleys B623ZZ for X, Y
    -Igus cable carrier chain
    -Flexible aluminium coupling for threaded rods of Z Axis
    -4 point print base levelling system with cushioning
    -Quick change system for print base with Clips
    -Brushless Fans with axial ball bearings.
    Print resolution
    -Very high: 60 microns
    -High 100 microns
    -Medium 200 microns
    -Low 300 microns
    Extruder Mechanics
    -Custom extruder design (Witbox)
    -0.4mm nozzle
    -Fin heatsinks with axial fan
    -Part cooling nozzle
    Print speed
    -Recommended speed: 50 mm / s
    -Maximum recommended speed: 80 mm / s
    Electronics
    Any RepRap electronics conforming to RepRap Interface Standard RIS 1.
    -LCD with rotary encoder and push-button navigation
    -Cold glass base (size:220 ​​x 220 x 3 mm)
    -Power supply: 220 AC 12 DC 100W
    -Thermistor 100k extruder
    -Heating element: 12V 40W
    Software
    -Firmware derivative Marlin
    -Recommended environment: Cura Software
    -Supported Files:. Gcode
    -OS supported:
    Windows XP and above
    Mac OS X and above
    Linux
    Communications
    -Standard SD card reader
    -USB Port Type B
    Materials
    PLA Filament 1.75-mm
    Changes with respect to other models Prusa i3
    Limit switch clamping:
    Designed by the department specifically for this model.
    Belt tensioners
    Tensioner X axis identical to the Power Code. Tensioner Axis Ydownloaded from Thingiverse. http://www.thingiverse.com/thing:68185
    Support for RAMPS
    Designed by the department specifically for this model. Includes three anchors to collect the wires on one side through the use of a cable tie. Guiding the cables ensures the Driver heatsinks are not covered.
    Support LCD
    Designed by the department specifically for this model. The design has been inspired by http://www.thingiverse.com/thing:121640
    Support Fan
    Cable Carrier
    Parts modified to include the cable carrier on all axis, avoiding pinching, cuts and catching the cable during axis movement.
    Power supply
    Laptop power supply
    Extruder
    Witbox extruder.
    Frame
    Official Prusa design modified. A recess has been added to the Y axis area to prevent friction which previously existed during the levelling of the base plate caused by the screw protruding. File:Frame&base Hephestos.dxf.zip
    Printing volume
    215x210x180 mm
    Printed Parts
    Thingiverse page: http://www.thingiverse.com/thing:371842
    Own designs
    X Axis cable carrier coupling
    Part Downloads
    Acople cadeneta Eje X.png File:Acople cadeneta Eje X.zip
    Mechanical Endstop clamping X axis
    Part Downloads
    Sujecion para final X.PNG File:EjeX final de carrera.zip
    Mechanical Endstop clamping Y axis
    Parts Downloads
    Sujecion para ele final Y marco.PNG File:EjeY final carrera marco.zip
    Sujecion para ele final Y base.PNG File:EjeY final carrera base.zip
    Mechanical Endstop clamping Z axis
    Part Downloads
    Sujecion para final Z.PNG File:Eje Z final carrera.zip
    Hot End security
    Part Downloads
    Seguridad Hot End.PNG File:Seguridad Hot end.zip
    Tools
    Part Downloads
    Llave fija impresa render.PNG File:Llave fija impresa archivos.zip
    LCD support
    Part Downloads
    Soporte LCD.PNG File:Soporte lcd.stl
    Bisagra soporte LCD.PNG File:Bisagra lcd.stl
    Fan support
    Part Downloads
    Soporte para el ventilador.PNG File:Soporte ventilador archivos.zip
    Filament holder
    Part Downloads
    Soporte filamento derecha.PNG File:Soporte filamento derecha archivos.zip
    Soporte filamento izquierda.PNG File:Soporte filamento izquierda archivos.zip
    Soporte filamento union.PNG File:Soporte filamento union archivos.zip
    Modified
    X Axis carriage
    The following changes have been made to the original carriage:
    -Attachment to rewind Igus cable carrier at the top (above the bearings).
    -Addition of a small cap to ensure contact with the limit of X axis (on the side, next to the linear bearing carriage below)
    Original Modified
    X Axis carriage (PowerCode) X Axis carriage (Hephestos)
    File:Eje X carro A archcivos.zip
    Left side motor mounting for Z-Axis
    -Incorporated coupling for cable carrier.
    Original Modified
    Left side motor mounting for Z-Axis (PowerCode) Left side motor mounting for Z-Axis (Hephestos)
    Eje Z soporte inferior izquierdo Prusa i3.PNG Eje Z soporte inferior izquierdo Hephestos.PNG
    File:I3-zbottom izq.stl File:Eje Z soporte inferior izquierda archivos.zip
    End of the X Axis motor
    Added support material to the screw which adjusts the Z axis height.
    -The base has been elongated to reduced the clearance of the nut thereby preventing the screw from moving.
    -The screw hole has been shifted outwards to improve accuracy in the mechanical Endstop activation.
    Original Modified
    X Axis left (PowerCode) X Axis left (Hephestos)
    File:EjeX izquierda.zip
    RAMPS support
    Added three hooks. Each hook works by using cable ties to hold and collect all the cables connected to the RAMPS. By guiding the cables through the side and into the plate at the top left corner it facilitates cooling of drivers by not having cables directly above the heat sinks.
    Original Modified
    RAMPS support (Witbox) RAMPS support (Hephestos)
    File:Suplemento RAMPS(original).stl File:Soporte RAMPS archivos.zip
    Complete Kit
    Complete Part Kit for Hephestos:
    File:Piezas Hephestos.zip
    Bill of Materials
    Tools
    Part Name Quantity Description
    Llave Allen 2mm.png Allen key s/long Ø 2 UNIOR Ø 2 mm 1 -
    Llave Allen 2,5mm.png Allen key s/long Ø 2.5 mm 1 -
    Destornillador trimmer.PNG Ceramic screw driver trimmer for electronics. 1 Screwdriver for adjusting the current of the motor drivers step by step, bipolar Nema 17 and extruder.
    Aguja acupuntura.png Precision Needle 0.4mm diameter 2 Required for maintaining the Hotend and removing blockages.
    Llave fija impresa.png Printed spanner 10 (M6) - 13 (M8) - 17 (M10) 1 Printed spanner for nuts M6, M8 & M10 (corresponds to spanner size 10, 13, & 17)
    Electronics
    RAMPS 1.4 bq.png Ramps 1.4 1 Freaduino Mega 2560 v1.2. Design based on Arduino Mega 2560 + Ramps 1.4, with heatsink on the MOSFET of the hot bed.
    Stepsitck Drivers A4988.png Stepstick Drivers A4988 4 Stepstick Drivers A4988 with 4 layers and improved heat dissipation to avoid overheating & heatsinks for attached drivers.
    Final de carrera PCB.png Endstop 3 Endstop mounted on PCB with LED indicator.
    Panel de Control LCD.PNG LCD control panel 1 LCD control panel with card reader for automatic printing (SD card not included) and 30 cm cables.
    Cable USB tipo B 1,8 metros.png USB cable (type B), 1.8 m. 1 Standard USB cable with male connectors (type A & B) 1.8 meters long.
    Cable motor Nema 17.png Motor wire Nema 17 4 4 strand cable for bipolar stepping motor Nema 17 (2.5A 1.8deg/step) with female connector.
    Cable para final de carrera.png Endstop wire 40 cm 2 3 strand cable for Endstop with female click connector (3pins) 40 cm long.
    Cable para final de carrera.png Endstop wire 85 cm 1 3 strand cable for Endstop with female click connector (3pins) 85 cm long.
    Motor Nema 17.png Motor Nema 17 4 Bipolar stepping motor Nema 17 (2.5A 1.8deg/step)
    Kit de cables Extrusor.PNG Wiring kit for extruder (Motor wire Nema (with connector) + Thermistor wire with connector + Fan and blower wire + Heater cartridge) 1 Wiring kit for extruder (4 strand cable for bipolar stepping motor Nema 17 (2.5A 1.8deg/step) with connector JST XHP-6 & female 4 pin connector + 2 strand cable for extruder thermistor with female 2 pin connector + Crimped fan and blower wire with terminal sleeve + Cartridge heater cable with terminal sleeve.
    150mm de cable flexible de dos hilos bicolor sección 1mm^2.png 150 mm of flexible wire with two bicolor strands with cross section of 1 mm² 1 150 mm of flexible wire with two bicolor strands with cross section of 1 mm².
    Fuente 220 AC 12 DC 100W.png Power supply 220 AC 12 DC 100W 1 Power supply with 1.10m cable, 100 W with 2.1mm connector Jack INPUT: 100-240VAC 1,8A 50-60Hz & OUTPUT: 12 VDC 8.0A).
    Cable fuente de alimentación.PNG Power Supply Cable (European) 1 Cable of 1,10m for 220V AC with Schuko connector (Male) & IEC-60320-C13 connector (Female).
    Soporte LCD bq.png Printed support for lcd 1 Support to locate the LCD on the top part of the aluminium frame. Custom design.
    Bisagra LCD bq.png Printed hinge for lcd support 1 Hinge for the LCD support located on the top part of the aluminium frame. Custom design.
    Soporte para RAMPS.PNG Printed support for ramps 1 Support for isolating the electronics from the aluminium frame. Used in conjunction with 3 cable ties to organise the wiring. Custom design.
    Soporte ventilador RAMPS.PNG Printed fan support 1 Support for 50x50mm fan. Located above the electronics to prevent overheating. Custom design.
    Tornillo M3x10.png M3x10 Screw - DIN-912 Class 8.8 Black 4 -
    Tornillo M3x12.png M3x12 Screw - DIN-912 Class 8.8 Black 2 -
    Tornillo M3x16.png M3x16 Screw - DIN-912 Class 8.8 Black 2 -
    Tornillo M3x20.png M3x20 Screw - DIN-912 Class 8.8 Black 4 -
    Tuerca M3.png M3 Nut - DIN 934 Class 8 Black 12 -
    Tubo termoretráctil.png Heat shrink tube 2.5 x 500 mm 1 -
    Brida Negra.png Black cable tie 100 x 2.5 mm 10 -
    Ventilador 50x50mm.png Brushless DC Cooling Fan - RD5010B12H with 20cm wire without connector 1
    C05I070078.png Adapter/connector Jack-Ramps 1 Adaptor/connector Jack, 2.1mm, female with Ramps 1.4 2 terminal header.
    Eslabón cadeneta recogecables Igus.png Plastic cable carrier chain link Igus 52 Link for constructing Igus cable carrier 045.10.018 (external measurements: 15 x 10mm)
    Extruder
    Part Name Quantity
    Extrusor Witbox.png Witbox Extruder ( direct extruder for 1.75 mm filament, with 0.4mm nozzle) 1
    Soporte Extrusor Witbox.png Extruder support 1
    Seguridad hot End.png Hot End safety guard (Hephestos) 1
    Tornillo M4x6.png M4 x 6mm Screw DIN-912 8.8 Class (with head for Allen 2.5mm) 2
    Tornillo M3x10.png M3x10 Screw - DIN-912 8.8 Class Black 2
    Tornillo M3x12.png M3 x16 Screw - DIN-912 8.8 Class Black 1
    X Axis
    Part Name Quantity
    Varilla lisa cromada 8x370.png Chromed smooth rod 8mm x 370mm 2
    Tornillo M3x10.png M3x10 Screw - DIN-912 8.8 Class Black 4
    Tornillo M3x16.png M3x16 Screw - DIN-912 8.8 Class Black 2
    Tornillo M3x20.png M3x20 Screw - DIN-912 8.8 Class Black 2
    Tornillo M3x25.png M3x25 Screw - DIN-912 8.8 Class Black 1
    Tornillo M6x40.png M6x40 Screw - DIN-912 8.8 Class Black 1
    Tuerca M3.png M3 Nut - DIN 934 Class 8 Black 7
    Tuerca M5.png M5 Nut - DIN 934 Class 8 Black 2
    Tuerca M6.png M6 Nut - DIN 934 Class 8 Black 3
    Eje x Carro A.PNG X Axis Carriage A PowerCode modified 1
    Eje x Carro B.png X Axis Carriage B PowerCode 1
    Polea rodamiento.png X Axis B623ZZ bearing Pulley PowerCode 2
    Eje X derecha.png X Axis Right PowerCode 1
    Tensor rodamiento B623ZZ.png X Axis tensioner B623ZZ bearingPowerCode 1
    Eje X Izquierda.png X Axis leftPowerCode Modified 1
    Eje X acople cadenenta izquierda.png X Axis left thread chain coupling PowerCode 1
    Eje X final de carrera.png X Axis Endstop (Hephestos) 1
    Rodamiento axial de bolas B623ZZ.png B623ZZ axial bearing 1
    Polea de 20 dientes para correa GT2.png GT2 pulley (20 theet) 1
    Rodamiento lineal de bolas LM8UU.png LM8UU Linear bearing 1
    Brida Negra.png Black cable tie 100x2.5mm 1
    Y Axis
    Part Name Quantity
    Varilla lisa cromada 8x370.png Chromed smooth rod 8mm x 340mm 2
    Varillas roscada.png Black threaded rod M10x370mm 2
    Varillas roscada.png Black threaded rod M8 x 205mm 4
    Tornillo M3x10.png M3 x10 Screw - DIN-912 8.8 Class Black 7
    Tornillo M3x16.png M3 x16 Screw - DIN-912 8.8 Class Black 1
    Tornillo M3x20.png M3 x20 Screw - DIN-912 8.8 Class Black 1
    Tornillo M3x25.png M3 x25 Screw - DIN-912 8.8 Class Black 6
    Tuerca M8.png M8 Nut - DIN 934 Class 8 Black 22
    Tuerca M10.png M10 Nut - DIN 934 Class 8 Black 8
    Arandela M8.png M8 Washer - DIN-125 Class 6 Black 22
    Arandela M10.png M10 Washer - DIN-125 Class 6 Black 8
    Tuerca serrado.png M10 serrated Nut - DIN 6923 Class 8 Black 4
    Arandela Ala Ancha.png M10 Washer - DIN-125 Class 6 Black 4
    Polea rodamiento.png Y Axis B623ZZ bearing Pulley 2
    Eje Y sujeta correa.png Y Axis belt holder. Prusa 1
    Eje Y tensor rodamiento B623ZZ.png Y Axis tensioner B623ZZ bearing http://www.thingiverse.com/thing:68185 1
    Eje Y motor.png Y Axis motor PowerCode 1
    Eje Y esquina.png Y Axis Corner PowerCode 1
    Eje Y final carrera base.png Y Axis base Endstop (Hephestos) 1
    Eje Y final de carrera marco.png Y Axis frame Endstop (Hephestos) 1
    Polea de 20 dientes para correa GT2.png GT2 pulley (20 teeth) 1
    Rodamiento lineal de bolas LM8UU.png LM8UU Linear bearing 3
    Brida Negra.png Black cable tie 100x2.5mm 11
    Correa GT2 6mmx1m.png GT2 belt 6mmx1m 1
    Base y marco i3.png Aluminium base 1
    Base de metacrilato.png Acrylic base 220x220x8mm holes 3.5mm 1
    Muele base.png Spring (long: 30,5mm ; Outside diameter: 4,5mm; Wire thickness: 0.45mm) 4
    C05I070083.png Glass Plate 220x220x3mm 1
    Binder Clip Negro (35x10mm).png Black Binder Clip (35x10mm) 4
    Z Axis
    Part Name Quantity
    Varilla lisa cromada 8x370.png Chromed smooth rod 8mm x 320mm 2
    Varillas roscada.png Black threaded rod M5x300mm 2
    Tornillo M3x10.png M3x10 Screw - DIN-912 8.8 Class Black 16
    Tornillo M3x18.PNG M3 x18 Screw - DIN-912 8.8 Class Black 2
    Tuerca M3.png M3 Nut - DIN 934 Class 8 Black 2
    Eje Z soporte superior.png Z Axis top support PowerCode 1
    Eje Z soporte inferior derecha.png Z Axis bottom right support PowerCode 1
    Eje Z final de carrera.png Z Axis Endstop (Hephestos) 1
    Eje Z soporte inferior izquierda.png Z Axis bottom left support PowerCode modified 1
    Acoplamiento flexible de aluminio de 5 a 5 mm.png Flexible coupling aluminium 5 to 5 mm 2
    Base y marco i3.png Black aluminium frame 1
    Assembly Guide
    Required tools not included in the BOM
    Part Picture
    Soldador y estaño.png Solder Iron and Solder
    Mordaza.png Vice
    Lima metal.png Metal file
    Tijeras.png Scissors
    Preparation before assembly
    Prepare pulleys
    Materials Needed:
    Part Name Quantity
    Rodamiento axial de bolas B623ZZ.png LM8UU Linear bearing       1
    Polea rodamiento.png X and Y Axis Pulley bearing B623ZZ       2
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Preparation of the motors
    Materials Needed:
    Part Name Quantity
    Lima metal.png Metal file       1
    Mordaza.png Vice       1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Embed nuts
    Materials Needed:
    Picure Name
    Soldador.png Solder Iron
    Tensor rodamiento B623ZZ.png Part
    - Nut
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Step F
  • Parts to be embed with nut:
    Picture Detail Picture Name Nut Quantity
    Eje X derecha.png Code Xend Idler A M6 TUERCA M5.png X Axis Right M5 Nut - DIN 934 Class 8 Black 1
    Eje X Izquierda.png Code Xend Motor Tornillo modificadoV2 TUERCA M3.png X Axis left M3 Nut - DIN 934 Class 8 Black 1
    Eje X Izquierda.png Code Xend Motor Tornillo modificadoV2 TUERCA M5.png X Axis left M5 Nut - DIN 934 Class 8 Black 1
    Tensor rodamiento B623ZZ.png Code Xend Idler B 623 M6 TUERCA M3.png X Axis tensioner B623ZZ bearing M3 Nut - DIN 934 Class 8 Black 1
    Eje Y tensor rodamiento B623ZZ.png Y-idler-tensioner3-3mm TUERCA M3.png Y Axis tensioner B623ZZ bearing M3 Nut - DIN 934 Class 8 Black 1
    Eje x Carro A.PNG CarroX con cadeneta girado TUERCA M3.png X Axis Carriage A M3 Nut - DIN 934 Class 8 Black 2
    Soporte ventilador RAMPS.PNG Soporte ventilador Tuerca M3.PNG Fan support M3 Nut - DIN 934 Class 8 Black 2
    Soporte ventilador RAMPS.PNG Soporte ventilador girado 2 TUERCA M3.png Fan support M3 Nut - DIN 934 Class 8 Black 2
    Y EndStop base.png Y EndStop base TUERCA M3.png Y Axis base Endstop M3 Nut - DIN 934 Class 8 Black 1
    Seguridad hot End.png Seguridad Hot End embutir.PNG Hot End Safety Guard M3 Nut - DIN 934 Class 8 Black 1
    Preparation of motor cables
    Materials Needed:
    Picture Name Quantity
    Cable motor Nema 17.png Motor Nema wire 17 4
    Soldador y estaño.png Solder Iron and Solder 1
    Cable length (from base of engine to end of connector)
    Motor Total length (cm) Motor length (cm) Extesnion lenght(cm)
    X 85 30 55
    Y 50 20 30
    Z Right 45 15 30
    Z Left 65 30 35
    Note: Cut four parts of the heat shrink tubing for the Motor wire to 2cm long.
    Note: Prepare motors of X and Y axis before mounting the engines, and the Prusa Z Axis, after mounting.
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Step F
  • Step G
  • Step H
  • Step I
  • Step J
  • Note: Before soldering the cables of Z axis motors, pass the bare wire through the motor hole.
    Assembly:
  • Step A
  • Step B
  • Power supply cable preparation
    Materials Needed:
    Tijeras.png Scissors 1
    150mm de cable flexible de dos hilos bicolor sección 1mm^2.png 150 mm flexible 2 colour wire (1 mm²) 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Step F
  • Step G
  • Axis assembly
    X Axis
    Bearing Assembly
    Materials Needed:
    Part Name Quantity
    Rodamiento lineal de bolas LM8UU.png LM8UU Linear bearing 4
    Eje X Izquierda.png X Axis left 1
    Eje X derecha.png X Axis Right 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Prepare the X Axis tensioner
    Materials Needed:
    Part Name Quantity
    Tensor rodamiento B623ZZ.png X Axis tensioner B623ZZ bearing 1
    Preprarar poleas D.png Pulley 1
    Tornillo M3x20.png M3x20 Screw - DIN-912 8.8 Class Black 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Enter the X Axis tensioner
    Materials Needed:
    Part Name Quantity
    Eje X-Paso 1 C.png Assembly step 1 1
    Eje X-Paso 2 D.png Assembly step 2 1
    The objective of the tensioner is to load or unload a belt easily once set.
    Note: It is necessary to sand/file the parts. The tensioner should slide perfectly into the part that holds it.
    Assembly:
  • Step A
  • Step B
  • Step C
  • Note: The two nuts at the end are to be tightened together. Use a nut wrench on the adjacent nut to assist. This way you can ensure that the nuts are securely fitted to the screw. Now by using the wrench as shown in the picture, crank the tensioner to the side to achieve the required tension when fitting the belt.
  • Step D
  • Step E
  • Step F
  • Note: Use the nut wrench when fitting and tightening the nuts on the screw.
    Assembly smooth rod bearings
    Materials Needed:
    Part Name Quantity
    Varilla lisa cromada 8x370.png Chromed smooth rod Ø 8mm x 370mm 2
    Assembly:
  • Step A
  • Step B
  • Prepare the X Axis Endstop sensor
    Materials Needed:
    Part Name Quantity
    Eje X final de carrera.png X Axis Endstop 1
    Final de carrera PCB.png Endstop 1
    Assembly:
  • Step A
  • Step B
  • Introduce the X Axis Endstop sensor in the smooth rod
    Materials Needed:
    Part Name Quantity
    Eje X-Paso 4 B.png Assembly step 4 1
    Eje X-Paso 5 B.png Assembly step 5 1
    Assembly:
  • Step A
  • Step B
  • Assemble the smooth rod into the side parts
    Materials Needed:
    Part Name Quantity
    Eje X Izquierda.png Assembly step 1 1
    Eje X-Paso 3 D.PNG Assembly step 3 1
    Eje X-Paso 4 B.png Assembly step 6 2
    Assembly:
    The length of the rod between the side parts (when assembled) should be approximately 31 cm.
  • Step A
  • Step B
  • Mount the X Axis motor
    Materials Needed:
    Part Name Quantity
    Motor Nema 17.png Motor Nema 17 1
    Eje X-Paso 7 C.png Assembly step 7 1
    Eje X acople cadenenta izquierda.png X Axis left thread chain coupling 1
    Assembly:
    Note: Orient the motor cable from the top.
  • Step A
  • Step B
  • Step C
  • Introduce the adjustment screw for the X Axis Endstop
    Materials Needed:
    Part Name Quantity
    Eje X-Paso 8 C.png Assembly step 8 8
    Assembly:
  • Step A
  • Step B
  • Introduce the pulley on the X Axis motor
    Materials Needed:
    Part Name Quantity
    Assembly:
    Note: Use the 2mm Allen wrench to tighten the pulley to the motor axis by the chamfered area.
  • Step A
  • Step B
  • Step C
  • Z Axis
    Couple the motor hold on the frame
    Materials Needed:
    Part Name Quantity
    Eje Z soporte inferior derecha.png Z Axis right bottom support 1
    Eje Z soporte inferior izquierda.png Z Axis left bottom support 1
    Marco negro.png Black aluminum frame 1
    Tornillo M3x10.png M3x10 Screw - DIN-912 8.8 Class Black 6
    Assembly:
  • Step A
  • Step B
  • Couple the Z motors
    Materials Needed:
    Part Name Quantity
    Motor Nema 17.png Motor Nema 17 2
    Eje Z-Paso 1 B.png Assembly step 1 1
    Assembly:
    Note: Orient the motor cable to the frame
  • Step A
  • Step B
  • Attach the top tether of smooth rods
    Materials Needed:
    Part Name Quantity
    Eje Z soporte superior.png Z Axis top support 2
    Tornillo M3x18.PNG M3x18 Screw - DIN-912 8.8 Class Black 2
    Assembly:
    Note: It is necessary to sand the parts.
  • Step A
  • Step B
  • Prepare the Z Axis Endstop
    Materials Needed:
    Part Name Quantity
    Eje Z final de carrera.png Z Axis Endstop 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Union X Axis with Z Axis: Insert threaded rods
    Materials Needed:
    Part Name Quantity
    Eje X hephestos.png X Axis 1
    Varilla roscada M5x300mm.png Z Axis Endstop 1
    Assembly:
  • Step A
  • Step B
  • Union X Axis with Z Axis: Introduce smooth rod
    Materials Needed:
    Part Name Quantity
    Eje Z-Paso 3 C.png Eje Z-Paso 2 B.png Assembly step 2 and 3 1
    Varilla lisa cromada 8mm x 320mm.png Chromed smooth rod 8mm x 320mm 2
    Assembly:
  • Step A
  • Step B
  • Union X Axis with Z Axis: Union with X Axis:
    Materials Needed:
    Part Name Quantity
    Eje Z-Paso 6 B.png Assembly step 6 1
    Eje Z paso 5.PNG Assembly step 5 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Union X Axis with Z Axis: Flexible coupling
    Materials Needed:
    Part Name Quantity
    Eje Z-Paso 8 A.png Assembly step 7 1
    Acoplamiento flexible de aluminio de 5 a 5 mm.png Flexible coupling aluminum 5 to 5 mm 2
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Union X Axis with Z Axis: Z Axis Endstop
    Materials Needed:
    Part Name Quantity
    Eje Z-Paso 8 A.png Assembly step 8 1
    Eje Z-Paso 4 C.png Assembly step 4 1
    Assembly:
    Note: Paste with adhesive for plastics the step assembly 4 to the motor bracket.
  • Step A
  • Step B
  • Y Axis
    Preparation of M10 threaded rod
    Materials Needed:
    Part Name Quantity
    Tuerca M10.png M10 Nut - DIN 934 Class 8 Black 4
    Arandela M10.png M10 Washer - DIN-125 Class 6 Black 4
    Arandela Ala Ancha.png M10 Washer -(Ø 30 mm) DIN-9021 Black 4
    Tuerca serrado.png M10 Nut - DIN 934 Class 8 Black 4
    Assembly:
  • Step A
  • Step B
  • Preparation of smooth rods
    Materials Needed:
    Part Name Quantity
    Varilla lisa cromada 8x370.png Chromed smooth rod Ø 8mm x 340mm 2
    Assembly:
  • Step A
  • Step B
  • Union of smooth rods with threaded rods
    Materials Needed:
    Part Name Quantity
    Eje Y esquina.png Y Axis Corner 4
    Eje Y-Paso 1 B.png Assembly step 1 1
    Eje Y-Paso 2 B.png Assembly step 2 1
    Assembly:
  • Step A
  • Step B
  • Secure with nuts
    Materials Needed:
    Part Name Quantity
    Assembly:
  • Step A
  • Step B
  • Step C
  • Secure with cable ties
    Materials Needed:
    Part Name Quantity
    Bridas negras 100x2,5mm x4.png Black cable tie 100x2.5mm 4
    Assembly:
  • Step A
  • Step B
  • Step C
  • Preparation of Y Axis tensioner
    Materials Needed:
    Part Name Quantity
    Eje Y tensor rodamiento B623ZZ.png Y Axis tensor B623ZZ bearing 1
    Tornillo M3x25.png M3 x25 Screw - DIN-912 8.8 Class Black 1
    Assembly:
    Note: The 25 mm screw is used as shaft for the pulley and the 20mm screw for the tensioner.
  • Step A
  • Step B
  • Preparation of Y Axis motor
    Materials Needed:
    Part Name Quantity
    Eje Y motor.png Y Axis motor mount 1
    Tornillo M3x10.png M3 x10 Screw - DIN-912 8.8 Class Black 3
    Assembly:
  • Step A
  • Step B
  • Preparation of the M8 threaded rods - Part 1
    Materials Needed:
    Part Name Quantity
    Arandela M8.png M8 Washer - DIN-125 Class 6 Black 6
    Tuerca M8.png M8 Nut - DIN 934 Class 8 Black 6
    Eje Y-Paso 6 B.png Assembly step 6 1
    Eje Y-Paso 7 B.png Assembly step 7 1
    Assembly:
  • Step A
  • Step B
  • Preparation M8 threaded rod - Part 2
    Materials Needed:
    Part Name Quantity
    Arandela M8.png M8 Washer - DIN-125 Class 6 Black 8
    Tuerca M8.png M8 Nut - DIN 934 Class 8 Black 8
    Eje Y-Paso 8 B.png Assembly step 8 1
    Assembly:
  • Step A
  • Step B
  • Union of the rods
    Materials Needed:
    Part Name Quantity
    Eje Y-Paso 4 B.png Assembly step 5 1
    Eje Y-Paso 9 A.png Assembly step 9 1
    Assembly:
  • Step A
  • Step B
  • Secure with nuts the structure
    Materials Needed:
    Part Name Quantity
    Eje Y-Paso 10 B.png Assembly step 10 1
    Assembly:
  • Step A
  • Step B
  • Step B
  • Preparation of the aluminum base
    Materials Needed:
    Part Name Quantity
    Base de aluminio.png Aluminum base 1
    Eje Y sujeta correa.png Y Axis belt holder 1
    Tornillo M3x10.png M3 x10 Screw - DIN-912 8.8 Class Black 2
    Assembly:
  • Step A
  • Step B
  • Secure the base aluminum with flanges
    Materials Needed:
    Part Name Quantity
    Eje Y-Paso 11 B.png Assembly step 11 1
    Eje Y-Paso 12 B.PNG Assembly step 12 1
    Brida Negra.png Black bridle 100x2.5mm 3
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Step F
  • Step G
  • Step H
  • Prepare the Endstop of the base
    Materials Needed:
    Part Name Quantity
    Eje Y final carrera base.png Y Axis Endstop 1
    Assembly:
  • Step A
  • Step B
  • Secure the Endstop at the base
    Materials Needed:
    Part Name Quantity
    Eje Y-Paso 13 H.png Assembly step 13 1
    Eje Y-Paso 14 B.png Assembly step 14 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Place the belt of the Axis Y
    Materials Needed:
    Part Name Quantity
    Brida Negra.png Black bridle 100 x 2.5 mm 4
    Assembly:
    Note: Turn the set
    Note: Tighten pulley with 2mm Allen wrench
  • Step A
  • Step B
  • Step C
  • Step D
  • Note: Screw out screw to slacken the tensioner
  • Step E
  • Step F
  • Step G
  • Step H
  • Step I
  • Step J
  • Step K
  • Step L
  • Note: Align belt
  • Step M
  • Step N
  • Step Ñ
  • Step O
  • Note: Tighten the belt tensioner bolt tightening
    Tighten all nuts
    Materials Needed:
    Part Name Quantity
    Assembly:
    Note: It is necessary to file the burrs.
  • Step A
  • Place the acrylic base
    Materials Needed:
    Part Name Quantity
    Tornillo M3x25.png M3 x25 Screw - DIN-912 8.8 Class Black 4
    Assembly:
  • Step A
  • Step B
  • Prepare the Y Axis Endstop on the frame
    Materials Needed:
    Part Name Quantity
    Eje Y final de carrera marco.png Y Axis Endstop 1
    Assembly:
  • Step A
  • Step B
  • Secure the Y Axis Endstop on the frame
    Materials Needed:
    Part Name Quantity
    Eje Y-Paso 19 B.png Assembly step 19 1
    Tornillo M3x16.png M3x16 Screw - DIN-912 Class 8.8 Black 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Union Y Axis with the X and Z axes: Snap axes
    Materials Needed:
    Part Name Quantity
    Eje Y-Paso 18 C.png Y Axis 1
    EjeXZ.png XZ Axis 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Union Y Axis with the X and Z axes: Fit and tighten nuts
    Materials Needed:
    Part Name Quantity
    Eje Y-Paso 21 B.png Assembly step21 1
    Assembly:
  • Step A
  • Extruder
    Prepare the carriage
    Materials Needed:
    Part Name Quantity
    Eje x Carro A.PNG X Axis Carriage A 1
    Eje x Carro B.png X Axis Carriage B 1
    Assembly:
  • Step A
  • Step B
  • Place the carriage in the X axis
    Materials Needed:
    Part Name Quantity
    Extrusor-Paso 1 B.png Step assembly 1 1
    Eje Y-Paso 21 B.png Prusa 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Secure the carriage with a flange
    Materials Needed:
    Part Name Quantity
    Extrusor-Paso 2 B.png Step assembly 2 1
    Brida Negra.png Black bridle 100 x 2.5 mm 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Place the belt on the X Axis
    Materials Needed:
    Part Name Quantity
    Extrusor-Paso 2 B.png GT2 belt 6mmx1m 1
    Extrusor-Paso 3 E.png Step assembly 3 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Step F
  • Screw the Extruder support
    Materials Needed:
    Part Name Quantity
    Assembly:
  • Step A
  • Step B
  • Place the extruder
    Materials Needed:
    Part Name Quantity
    Extrusor Witbox.png Witbox Extruder 1
    Assembly:
    Note: This step is necessary to remove the nozzle of the extruder.
    Nota: Secure with screws the Extruder.
  • Step A
  • Step B
  • Step C
  • Placing the blower nozzle and Hot end security
    Materials Needed:
    Part Name Quantity
    Tobera.png Blower nozzle of the Witbox extruder 1
    Seguridad hot End.png Hot End security 1
    Assembly:
    Nota: The Hot end security is a opcional complement and no necessary for the correct printer working, but its use is highly recommended to avoid burns.
  • Step A
  • Step B
  • Step C
  • Place the glass on the base
    Materials Needed:
    Part Name Quantity
    C05I070083.png Glass 220x220x3mm 1
    Binder Clip Negro (35x10mm).png Black Biinder Clip (35x10mm) 4
    Assembly:
  • Step A
  • Step B
  • Step C
  • Electronic
    Place the RAMPS 1.4
    Materials Needed:
    Part Name Quantity
    Tornillo M3x20.png M3x20 Screw - DIN-912 Class 8.8 Black 2
    Assembly:
  • Step A
  • Step B
  • Step C
  • Prepare the LCD control panel
    Materials Needed:
    Part Name Quantity
    Soporte LCD bq.png Printed support for lcd 2
    Bisagra LCD bq.png Printed hinge for lcd 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Step D
  • Mount the LCD control panel on the frame
    Materials Needed:
    Part Name Quantity
    Electrónica-Paso 2 D.png Assembly step 2 1
    Assembly:
  • Step A
  • Step B
  • Step C
  • Tuck the wires in the X Axis chain stitch
    Materials Needed:
    Part Name Quantity
    Cadeneta.png 25 roller chain 1
    Cadeneta.png 27 roller chain 1
    Kit de cables Extrusor.PNG Kit wiring extruder (Nema motor wire (with connector) + Thermistor wire + Fan and blower wiring + Heat cartdridge wire) 1
    Assembly:
    Note: Introduce the wires singly
  • Step A
  • Step B
  • Step C
  • Step D
  • Place the X Axis chain stitch
    Materials Needed:
    Part Name Quantity
    Electrónica-Paso 5 A.png Cadeneta Eje X con cables 1
    Assembly:
    Note: The 25 shackle chain stitch link the X Axis carriage with the X Axis left.
  • Step A
  • Step B
  • Step C
  • Step D
  • Step E
  • Step F
  • Introduce the Z Axis wires in to the Z Axis chain stitch.
    Materials Needed:
    Part Name Quantity
    Electrónica-Paso 5 F.png Assembly step 5 1
    Cable para final de carrera.png EndStop wire with click and female connector 85 cm 1
    Assembly:
    Note: Introduce in to the Z Axis chain stitch the X Axis motor and Endstop wires.
  • Step A
  • Step B
  • Note: The 27 shackle chain stitch link the X Axis left with the Z Axis left bottom support.
  • Step C
  • Step D
  • Step E
  • Prepare the fan
    Materials Needed:
    Part Name Quantity
    Ventilador 50x50mm.png Fan 50 x 50 mm 1
    Soporte ventilador RAMPS.PNG Printed support for fan 1
    Tornillo M3x16.png M3 x16 Screw - DIN-912 8.8 Class Black 2
    Assembly:
  • Step A
  • Step B
  • Wiring and cable routing
    Cable connection diagram
    Materials Needed:
    Part Name Quantity
    Brida Negra.png Black bridle 100 x 2.5 mm 11
    Preparación del cable de la fuente G.png Power supply wire 1
    Cable para final de carrera.png EndStop wire with click and female connector 40 cm 2
    Extruder wiring
  • Step A
  • Step B
  • Step C
  • Note: Use a flange with the extruder wires.
  • Step D
  • Step E
  • Motors cable routing
    Note: Use a flange with the motors wires.
  • Step A
  • Step B
  • Endstop cable routing
  • Step A
  • Step B
  • Step C
  • RAMPS Wiring and cable routing
    Note: Use the flanges with the wires.
  • Step A
  • Step B
  • Step C
  • Note: Guide the cables through the printed part that holds the RAMPS and secure them with the flanges.
    Note: Connect the clamp plate the fan cables and power supply.
  • Step D
  • Step E
  • Step F
  • Place the fan
    Materials Needed:
    Part Name Quantity
    Electrónica-Paso 8 B.png Assembly step 8 1
    Assembly:
    Note: Disconnect the LCD panel control Ramps before placing the fan and pass it through the hole in the workpiece.
  • Step A
  • Step B
  • Step C
  • Placement the filament holder
    Materials Needed:
    Part Name Quantity
    Soporte rollos.png Filament holder 1
    Assembly:
    Note: Disconnect the LCD control panel of Ramps before placing the fan and pass it through the hole in the workpiece.
  • Step A
  • Step B
  • Step C
  • Printer settings
    Z Axis adjustment
    Before printing with your printer you must calibrate the screw that adjusts the height of the Z axis so that the extruder is to the correct height of the base. To do this, follow these steps:
    -Put the same height ends of the X Axis. Thread each axis manually until both are at the same height.
  • Step A
  • -Tighten the set screw everything without possible forcing the printer part.
  • Step B
  • -Use the LCD control panel to bring the extruder to home.
    Control > Move Axis > Auto home
  • Step C
  • Step D
  • Note: Make sure that the Endstops are being touching correctly by their respective axes.
    -Adjusts the position of the endstop sensor adjustment screw and repeat the previous step (bringing the Z axis to home).
  • Step E
  • -If the adjustment isn't correct, repeat the previous step.
  • Step F
  • Level plate
    Once Z Axis is adjusted, is necessary level the plate.
    Using the LCD control panel, start the leveling program.
    Control > Level plate
    The program moves the extruder at four points of the base, where you must adjust the screws on each corner, so that you can pass a sheet between the extruder nozzle and glass. Must feel the friction produced by the extruder in the paper passing therebetween.
  • Step A
  • Step B
  • Step C
  • Step D
  • Extruder obstruction
    If a blockage occurs in the extruder, follow the next step:
    You must hate the extruder at 220 ° C and insert the 0.4mm needle into the nozzle until you see it come out the other end. After you must clean the needle of adhered plastic.
  • Step A
  • Hello world: Your first print
    If you followed all steps of this manual, you should have your Prusa i3 Hephestos ready to do his first print!
    First you must laminate the 3D design. The 3D designs must be in .stl. For this, you can follow our guides for some used programs.
    Slic3r guide: https://www-cdn.bq.com/file/Witbox/Manual_Slic3r_ES.pdf
    Repetier-Host guide: https://www-cdn.bq.com/file/Witbox/Manual_Repetier_ES.pdf
    Cura 3D guide: https://www-cdn.bq.com/file/Witbox/Manual_Cura_ESP.pdf
    Note: Remember that Prusa i3 Hephestos area is 215x210x180 mm.
    Once you have the g-code file, save the file in a SD card. Insert the SD card in the LCD control panel slot. In main menu select "Print from SD". Now select your g-code file. The printer will start automatically. You can view the progress of the part and the extrusion temperature from the LCD panel of the printer. When printing is completed remove the glass base by removing the clamps. With the base resting on a glass table parts removed by pulling them tight.
    You need apply lac on the glass for the correct adhesion of parts!
    Annex
    Firmware load
    For load a new firmware follow the next steps:
    1. Donwload the firmware. In RepRap wiki you can find a entire list of available firmwares:
       Link: http://reprap.org/wiki/List_of_Firmware
    2. Here are some of the most popular firmwares and our modification of Marlin:
           Marlin: http://reprap.org/wiki/Marlin
           Sprinter: http://reprap.org/wiki/Sprinter
           Marlin Hephestos: File:Marlin Hephestos.zip
    3. Download and install Arduino software from main site:
            Link: http://www.arduino.cc/en/Main/Software
    4. Inside of firmware folder, you must open .ino file with the Arduini IDE.
    5. Once open, will appear one tab called "configuration.h". In this file you can configurate the params of your printer.
    6. When you complete configuration, load program into Arduino Mega.
    Drivers calibration
    Materials Needed
    Part Name Quantity
    Polimetro.png Multimeter 1
    Destornillador trimmer.PNG Ceramic screw trimmer f 1
    Clemas.png Clema 1
    Cable USB tipo B 1,8 metros.png Cable USB tipy B de 1.8 meters 1
    - Computer with Pronterface 1
    This step must be repeat with all drivers, you will need two motors for Z Axis driver calibration.
    Intensity for each Driver
    Driver Intensity (mA)
    X Axis 250
    Y Axis 250
    Z Axis 450
    Extruder 680
    Arduino with RAMPS aprox. 74 (no regulable)
    Wiring
    Is necessary connect one endstop sensor and thermistor, because of firmware firewalls.
    Multimeter preparation
    Connect the multimeter in serial connection between Arduino and power supply. Put multimeter in intensity measurement mode.
    Multimeter adjustment
    Connect Arduino Mega to computer. The flowing current is 74 mA aprox. (this may differ between plates). Open Pronterface, select the correct port and connect to Arduino.
    You must move the motor using Pronterface interface. Measure the current and regulate this using the Ceramic screw trimmer together with the mulitmeter. The current should be set to the sum of the current circulating in the PCBA and the current in the motor. For example, in X Axis current must be 74 mA + 250 mA = 324 mA.
    Pre-heat or send the M302 command for completing the extruder calibration.
    Arduino needs to be reset before calibrating the next driver.
    Pronterface donwload link: http://reprap.org/wiki/Printrun
