Prusa i3
Revision as of 11:42, 15 November 2012 by Idolcrasher (talk | contribs) (Introduction)
Prusa i3 Documentation
Prusa i3
Prusa i3 is a redesign by Prusajr.
Introduction
The Prusa i3 (iteration 3) is the newest and current 3D Printer design by RepRap Core Developer Prusajr. The i3 incorporates lessons learned from the previous two Prusa designs, as well as other popular modern RepRaps designs.
Main improvements
The following is a list of the main improvements made on the Prusa mendel iteration 2
  • enhanced frame rigidity (prevents x backlash)
  • easy assembly
  • parameric files for multiple sizes/barings or bushings
Development
The development of the Prusa Mendel is hosted on github: https://github.com/josefprusa/Prusa3.
History
Printed Parts
The STL files to make the printer can be found at Clone_wars:_Prusa_iteración_3.
To compile yourselve use the files from Github [[2]] (box style files) [[3]] (Singel sheet style) Copy configuration.scad.dist to configuration.scad and fill custom settings section there
RP every .scad in this directory (except complete-printer) once. Aim for 0.3mm layers and 2.2 extrusion width (width over thickness), for 0.66mm stroke width. Printer is tested at this setting.
Using doc/complete-printer.scad as a visual clue and doc/manual.txt as a guide, build the printer.
Frame type
The prusa I3 frame consists of a treaded rod Y-axis that looks similar to meldel type frames and a other material vertical frame part for the X-axis and Z-axis. A single sheet frame can be made from metal or a box style frame that can be made from wood.
Single Sheet Frame
This is a frame created from a single sheet of metal (for example aluminum)
Prusa i3 with a single metal sheet style frame.
pro:
- Looks professional (subjective)
con:
- requires specialised tools (e.g. Water flow jet cutter)
- Less rigid connection between XZ-frame and Y-frame part
Box Style Frame
This frame is created created from 8 small sheets of wood.
Prusa i3 with a box style frame.
pro:
- Can be created with standard DIY tools
- More rigid connection between XZ-frame and Y-frame part
con:
- Looks less professional (subjective)
Electronics
Stepper Motors
Controller Electronics
There are many controllers available to use for the Prusa i3. Choosing the best one for your printer is up to you. It's probably best to head over to Comparison_of_Electronics and choose the best one for you. The most popular tend to be RAMPS or Sanguinololu.
Extruder
Extruder
On November 12th, 2012 Josef Prusa (@josefprusa) tweeted a picture of his metal frame i3 with a custom dual extruder mounted.
Prusa i3 with an unnamed dual extruder mounted.
//Need name, info, and link to this extruder and how to build it. Can anyone help? -idolcrasher
Previous posts on Prusa's twitter feed reveal that Sound (Slic3r's Developer) inspired Prusa to attach a dual extruder.
Heated Bed
Heated Bed
