Construcción de los circuitos de la placa
Estas páginas describen la electrónica estándar RepRap. Quizás te interese comprobar la alternative electronics.
Si compras las placas del circuito impresas para Mendel de MakerBot Industries conseguirás las versiones previstas para sus máquinas CupCake. Se pueden usar como se mantienen, pero haciéndoles unos pequeños retoques (tenazas, pinzas, un pequeño tornillo, y una soldadura de hierro es todo lo que necesitamos) puedes hacer que el cableado de Mendel sea mucho más cuidado. Estos son los detalles de como hacer esto:
If you get kit boards or buy the bare PCBs and then get your own components to populate them you can build them for Mendel from the start, of course. Here are the instructions for building the kit boards yourself. One Mendel will need:
- 1 RepRap Motherboard (mendel/electronics/motherboard),
- 1 Mendel USB and power connector (no Eagle design - it's a simple piece of stripboard),
- 3 RepRap Stepper drivers (mendel/electronics/stepper-motor-driver, buy PCB online),
- 3 RepRap Opto Endstops (mendel/electronics/opto-endstop, buy PCB online), and
- As many RepRap extruder controllers as you have extruders (mendel/electronics/extruder-controller, buy PCB online).
The locations in your download that you made to install RepRap on your computer of the Eagle design files for these circuit boards is given in brackets after the links.
There is a Testing RepRap Electronics page at that link with details of how to test each board.
You may care also to see the experimental Pololu Electronics page.
Back to How to make RepRap Version II Mendel.
