Builders
This is the place for you to write up improvements to RepRap Version I "Darwin" or other RepRap and RepStrap machines. It is also the place to post ideas that you think will help other RepRap users, particularly new ones.
Please include as many pictures and diagrams as you can; these really help understanding.
Don't be frightened to tidy, to re-organize, to correct and to clarify the work of others, but don't delete anything without good reason (good reasons are things like the post is offensive, is spam, or is scientifically incorrect).
By all means include lasting information that has previously appeared in the [Main Blog], the [Builder's Blog] or the [Forums] - we want to systematize that in a chronologically-independent way here. But please don't post questions (they belong on the [Forums]) or information that is transient.
There is a dedicated [forum thread here] for discussion of this Builder's wiki, what should go on it, and how it should be organized.
New and Experimental Documentation
User-submitted Hints, Files and Patches to RepRap Version I Darwin
Click on one of the links below to take you to the appropriate section of the Builder's Wiki for you to post your work.
Thermoplast Extruder
User-submitted hints, variations, patches, and improvements on the [Thermoplast Extruder]
Please try to stick to the headings below, each of which links to the page to use to post your work.
Cartesian Bot
User-submitted hints,variations, patches, and improvements on the [Cartesian Bot].
Electronics
User-submitted hints,variations, patches, and improvements on the [Electronics] to control a RepRap.
Software and firmware
User-submitted hints,variations, patches, and improvements on the [Software] to control a RepRap. There are separate sections for the firmware in the machine, and the software that drives it from the host computer.
- Builders/Host software If you want to add to the information on the RepRap host software, follow the link above.
- Builders/Firmware If you want to add to the information on the RepRap microcontroller firmware, follow that link.
- Builders/Software alternatives If you have an alternative RepRap driving program or alternative firmware (for any microcontroller) this is the place to document it.
Configuration
User-submitted configuration hints, examples and suggested settings. Scared of the hundreds of numbers? Start here.
- Builders/Config/Getting_Started How to get started and test your RepRap
- Builders/Config_Methods How to configure and tweak your reprap
- Builders/Config_Hints Hints, example configuration files and settings
Links and Blogs Of Reprap Builders
- Builders/Links_and_Blogs A collection of links to different blogs and websites which deal directly with RepRap, or are of Interest to RepRappers.
User-submitted Hints, Files and Patches to RepStrap machines
A RepStrap is a homebuilt 3-axis positioning system used as a 'bootstrap' machine to fabricate a RepRap 3D Printer.
LaserCut Repstraps
- There are a growing number of laser-cut Rep(St)raps being developed. Follow that link to find out about them, to add details of yours, and to see why the (St) is in brackets...
Repstraps
- If you've built a non-laser-cut RepStrap, this is the place to tell people about it..
