File:Knob-by-nophead.aoi
Made by nophead. When he e-mailed it to me he had this to say: "I assume you have AOI so can make the STL. I have been meaning to put it on the objects wiki but have not got round to it. If published it really needs a table of scaling factors for various nut sizes, or an array of STLs. Also BA nuts are thicker than metric so it may need a bit slicing off the end. You will have to play around with scaling it because it was for 2BA, but was a bit tight as internal holes come out a lot smaller than they should be. This seems to depend on the filament width and the type of plastic. I also think how much you stretch it will have an effect. Adrian published corrections for circles but I get an order of magnitude more error that that formula. It is something on my list of things to research and quantify."
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 05:34, 24 August 2008 | (12 KB) | ErikDeBruijn (talk | contribs) | Made by nophead. When he e-mailed it to me he had this to say: "I assume you have AOI so can make the STL. I have been meaning to put it on the objects wiki but have not got round to it. If published it really needs a table of scaling factors for various |
- You cannot overwrite this file.
File usage
The following page links to this file:
