Stepper motor
- 1 What is a Stepper Motor ?
- 2 Terms
- 3 History
- 4 Holding Torque
- 5 Size
- 6 Wiring
- 7 Heat
- 8 Current
- 9 Suppliers
- 10 Unscientific rules of thumb for motor purchases
- 11 Driving stepper motors
- 12 Wiring Your Stepper
- 12.1 Shortcut for finding the proper wiring sequence
- 12.2 NEMA 17 Motors
- 12.3 NEMA 23 Motors
- 12.4 Stepper Motors
- 12.5 Torque
- 12.6 Power and current
- 12.7 Stepper drivers vs stepper controllers
- 12.8 PWM and Stepper Drivers
- 12.9 Stepper drivers
- 12.10 Micro stepping
- 12.11 Mid-Band Resonance Compensation
- 13 Further reading
Stepper motors are one kind of electric motor used in the robotics industry. Stepper motors move a known interval for each pulse of power. These pulses of power are provided by a stepper driver and is referred to as a step. As each step moves the motor a known distance it makes them handy devices for repeatable positioning.
There are two major types of stepper motor known as bipolar and unipolar. Wikipedia has further information on stepper motors. Please see Wikipedia: stepper motor. A good diagram showing a stepper motor's mechanical operation is here.
Terms
NEMA - refers to the frame size of the motor (as standardized by the US National Electrical Manufacturers Association [1] ). It specifies the “face” size of the motor but not its length. For example a NEMA 23 stepper has a face of 2.3 x 2.3 inches with screw holes to match. Note: just because a motor is bigger does not mean it is more powerful in terms of torque. It is perfectly possible for a NEMA 14 to “out pull” a NEMA 17 or a NEMA 23. Bipolar and unipolar - These terms refers to the internals of the motor. Each type has a different stepper driver circuit board to control them. In theory a RepRap could use either, but in practice most are bipolar.
Bipolar Motors
These motors are the strongest type of stepper motor. You identify them by counting the leads - there should be four or eight. They are also the type of motors we are using in the RepRap Project's Mendel & Darwin designs. They have two coils inside, and stepping the motor round is achieved by energising the coils and changing the direction of the current within those coils. This requires more complex electronics than a unipolar motor, so we use a special driver chip to take care of all that for us. Some designs (the eight-wire ones) split each coil in the middle so you can wire the motor either as bipolar (short the middles) or unipolar (short the middles and treat the link as the centre tap - see below).
Unipolar Motors
Unipolar motors have two coils, each one has a centre tap. They are readily recognizable because they have 5, 6 or even 8 leads. It is possible to drive 6 or 8 lead unipolar motors as bipolar motors if you ignore the centre tap wires. 5 lead motors have both centre taps connected, so re-wiring them to a 4 lead version requires at least opening the motor, if it can be done at all.
The main beauty of unipolar motors is that you can step them without having to reverse the direction of current in any coil, which makes the electronics simpler. Some early RepRap prototypes used this trick. Because the centre tap is used to energise only half of each coil at a time, unipolar motors generally have less torque than bipolar motors.
Stepping Angle
Most stepper motors used for a Mendel have a step angle of 1.8 degrees. It is sometimes possible to use motors with larger step angles, however for printing to be accurate, they will need to be geared down to reduce the angle moved per step, which may lead to a slower maximum speed.
History
Stepper Motor History for Darwin (V1.0 RepRap)
The RepRap Darwin used a NEMA 23 stepper motor. This stepper motor was a unipolar stepper motor which could be configured as a bipolar. This design used 3 stepper motors, one for each axis, and a DC motor for its extruder. Later many people upgraded their extruders to increase their control of the extruder.
Note the Generation 2 electronics supported the first configuration with 3 stepper driver circuit boards for the steppers and a PWM circuit board to control the DC motor.
The Darwin stepper motor requirements were as follows:
Parameter | Specification |
Size | NEMA 23 |
Type | Bipolar |
Shaft | dual-output shaft |
Torque | 100 oz-in or about 71 N-cm |
Resistance | about 10 ohms, or 1 to 30 ohms |
Note
If you are using the PIC controller (Note: Generation 1 electronics) you need a motor that will use about 1A per winding at 12V - that is, around 10 ohms. The Arduino circuit can be adjusted to accommodate a wider range of steppers, but remember that if you specify a low-resistance one and the Arduino controller has to chop the voltage to limit the current going through it, that will also limit the torque.
Stepper Motor History for Mendel (V2.0 RepRap)
The RepRap Mendel used either NEMA 17 or NEMA 14 bipolar stepper motors. It used four stepper motors: one for each of the three axes and one for the extruder.
Note this configuration of four stepper motors was supported by the 3rd generation electronics.
The Mendel stepper motor requirements were as follows:
Size | NEMA 17 or 14 (prototype was NEMA 14) |
Type | Bipolar |
Shaft | dual-output shaft (need to make knurling the stepper shaft easier, not applicable to recent geared extruders) |
Torque | 13.7 N-cm (= 1400 g-cm or 19.4 oz-in) |
Resistance | Must be over 6 ohms (not applicable to recent stepper controllers, see "current" below) |
Holding Torque
It is recommended that you get approximately 13.7 N-cm (= 0.137 N-m or 1400 gf-cm or 19.4 ozf-in or 1.21 lbf-in) of holding torque (or more) to avoid issues, although one stepper with less has been used successfully (see below). If in doubt, higher is better. If you need to convert between different units for the torque you can use the torque unit converter here.
Size
If using the smaller NEMA 14 motors, aim for the high torque option. NEMA 14s are neater, lighter and smaller, but can be hard to obtain with the appropriate holding torque. NEMA 17s are quite easy to get in the specification that Mendel needs, but are bulkier and less neat. NEMA 14s are running near the edge of their envelope: they will get warm. NEMA 17s are well inside what they can do, and will run much cooler.
Note that any Mendel part that goes on to a stepper motor shaft expects the shaft to be roughly Ø5mm. If the shaft is a different size, you will need to make allowances for this in the parts you obtain/make.
Wiring
Steppers motors come in several wiring configurations. 4, 6 and 8 wires are all fairly common and work fine with the standard RepRap electronics. 5 wire stepper motors exist but won't work with the standard RepRap electronics, because the 5th wire connects to both coil centers. See stepper wiring for more details.
Heat
Most of the motors specs give the current for two coils that will give an 80 °C rise, i.e. they can run at 100 °C! When using them on plastic brackets you need to under-run them to keep the brackets from melting. With PLA you have to seriously under-run them! Fortunately temperature rise is proportional to the square of current, but torque is directly proportional so you can keep temperature under control without losing too much torque.
Current
All recent stepper controllers use a current-limiting design. Because of this, the resistance (ohms) of the coils doesn't matter, as long as it is low enough for the current to rise fast enough for the current-limiting design to come into play. If the resistance is too high (i.e. 24V steppers) the current doesn't raise fast enough for reliable microstepping.
Designs which use a separate "extruder controller board" sometimes use H-bridges (which are designed for running a DC motor) instead of a proper current-limiting stepper controller. On these boards, you need to be careful not to turn the current (PWM) too high, especially with low-ohm (low voltage) motors. You run the risk of overheating both the stepper motor and the H-bridge chip.
Suppliers
Below is a list of possible motors and suppliers. Please add to it. If you have built a Mendel successfully with a given motor, remember to put true in the tested field.
Vendors (link to product) | Shipping location | Manufacturer | Model # (link to datasheet) | Holding Torque | Shaft | Tested | Additional notes |
Motion Control Products | UK | Fulling Motor | FL35ST36-1004B | ~13.7 N-cm | Dual | true | Used in mendel prototype |
Active Robots | UK | Wantai | 35BYHG04 | ~12.3 N-cm | Ø4.9mm | true | Less holding torque than recommended, but has apparently been used successfully |
Pololu Robotics | US | SOYO | SY35ST36-1004A | ~13.7 N-cm | Ø5mm | ? | Note: Pololu list this motor as 1400 g-cm AND as 20 oz-in (converts to 19.44 oz-in). According to supplier information, the metric value is correct. |
Paoparts | EU-FR | SOYO | SY35ST36-1004A | ~13.7 N-cm | Ø5mm | ? | Length cable 80 cm |
Zapp Automation | UK | ? | SY35ST36-1004B | ~14 N-cm | Dual | ? |
Zapp Automation Pololu Robotics |
UK US |
SOYO | SY42STH47-1206A | ~31.1 N-cm | Single | true | None |
Zapp Automation Paoparts |
UK FR |
SOYO | SY42STH47-1684A | ~43.1 N-cm | Single, d-shape, Ø5mm | true | 4.5mm flat paoparts.com motors are factory custom made with 80cm cables |
Zapp Automation mendel-parts.com |
UK NL |
SOYO | SY42STH47-1684B | ~43.1 N-cm | Dual, round, Ø5mm | true | mendel-parts.com motors are factory custom made with 80cm cables and have an option to include Molex connectors for our GEN6 electronics |
Interinar Electronics, LLC | US | Oriental Motors | PX243M-01AA | 15 N-cm | Single | ? | Not strong enough for direct drive extruder, Uses Imperial #4-40 TPI mounting holes instead of M3 metric |
Alltronics.com | US | Lin Engineering | 4218L-01-10 | ~53 N-cm | Round, Ø5mm | true | None |
Alltronics.com | US | Lin Engineering | 4218L-01-11 | ~53 N-cm | Ø5mm = 0.1968 inches, d-shape | true | None |
Phidgets.com Thingfarm North America |
US US |
Wantai | 42BYGHW811 | 47.1 N-cm | Ø5mm | true | 0.9 degree |
Cool Components SparkFun Robot Gear Australian Robotics Mindkits |
UK US AU AU NZ |
Mercury Motor | SM-42BYG011-25 | 23 N-cm | Ø5mm | true | None |
AusXMods | AU | Rugao Xinhe | 17H185H-04A | ~43.8 N-cm | ? | ? | 2.8v,1.68A/phase,1.65ohm/phase, the -04B variant is dual-shaft |
Kysan | China | Kysan | 42BYGH4803 | 49 N-cm | Ø5mm | true | Successfully tested with Wade's Geared Nema 17 extruder - high flow rates. According to datasheet, 5mm round shaft. Requires Minimum Purchase of $100 when buying online. |
MakerBot | US | Kysan | 1123029 | 26 N-cm | Ø4.78mm (3/16"), 24mm long | ? | None |
erbyers on ebay | US | Applied Motion | 4017-871 | ~8.47 N-cm | Dual, Ø5mm | ? | One side of shaft is splined ~4.3mm 0.5in from face, other shaft is 5mm; wires 95mm long terminating in 0.1" header; date code from 1984 |
Reichelt | DE | Trinamic | QSH4218-51-049 | 49 N-cm | Ø5mm | true | Tested on MakerBot Cupcake CNC |
mechapro | DE | Nidec Servo | KH4248-B95101 | 48 N-cm | Ø5mm | ? | None |
LulzBot | US | SOYO | SY42STH47-1504A | 55 N-cm | Ø5mm D-shaped | true | None |
2PrintBeta | DE | ACT | 17HS4417 | 40 N-cm | Ø5mm | ? | None |
XYZPrinters | NL | XYZ | 42BYGH4803-04 | 55 N-cm | Ø5mm | true | Custom model, includes 60cm leads |
1) Generally, the longer the motor body, the more torque the motor has.
2) If a motor is rated 2.5 A and your stepper driver produces only 2 A your motor will not produce the manufacturer's rated torque.
3) If a motor is rated 35 V and your stepper produces only 12 V your motor will not produce the manufacturer's rated torque.
4) A motor can safely exceed its rated voltage with a chopping stepper driver (which is all the RepRap stepper drivers, save only the Gen3 electronics extruder board hack). It cannot exceed its rated current (amps) without severely overheating and dying a quick death.
5) Stepper motors are generally rated for a 50 °C temperature rise at rated current/torque.
6) ABS melts at 105 - 120 °C but softens at 80 °C. Therefore you probably can't run your steppers at their full rated torque without melting your plastic motor mounts.
7) Power is measured in watts (W) and is calculated as volts (V) × current (A).
8) Power made available to a motor will be turned into heat and motion.
9) The more power made available to the motor the higher the amount of heat and motion. Heat is proportional to current squared while motion is proportional to current, so losing a little motion (torque) can lose a lot of heat.
10) Power and torque are related. The more power, the more torque.
11) A motor's actual rated amps (if missing from the spec sheet) can be calculated by dividing the specified volts supplied to it by the ohms of resistance it has.
To make stepper motors work, you need to use stepper driver chips. These chips keep the power that drives the motors separate from the power that is on the arduino. The arduino can't provide enough juice to power the stepper motors directly. This is why you have to use separate chips to sort of act as valves that control how the motor spins.
Here's a list of stepper driver chips:
- L297/L298 combo
- Last stepper motor driver to use this was v1.2
- Allegro A3967
- Used in Easy Driver boards sold on sparkfun
- Not sure if they can be used in repraps but they're good for experimenting
- Allegro A3977
- Abandoned in stepper motor driver v2.0
- Allegro A3979
- Abandoned due to tiny size in v2.1
- Allegro A3982
- Improved over v1.2 in v2.2
- also used in stepper motor driver v2.3
- Allegro A4983
- Used in Pololu driver boards
- Texas Instruments DRV8811
- Used in gen6 electronics
- This is probably why the FiveD firmware was modified
- National Semiconductor LMD18245T
- these are used in the AVRSTMD (see below)
- You need 2 of these to drive a bipolar stepper motor
Open Source Stepper Motor Drivers
RepRap Stepper Motor Driver v1.x
The first generation of RepRap stepper motor drivers. (Note: These boards were used in the generation 2 collection of electronics.) Uses the L297/L298 stepper motor driver combo. Half-stepping. Handles up to 2A. All through hole. A nice, solid driver. It uses some old technology, so it's not as fancy as the newer stepper drivers, but it gets the job done. Read the documentation page here.
RepRap Stepper Motor Driver v2.x
The second generation of RepRap stepper motor drivers. (Note: These boards were used in the generation 3 collection of electronics but could be retrograded to generation 2.)
Uses the Allegro A3982 chip which does a bunch of nice things and makes the board much simpler. It also drops the price by $10 compared to the v1.x series. It can handle up to 2A, and does half-stepping. The only downside is that it's SMT, which can be a bit scary for people. It's all large SMT parts, so it's pretty simple to solder, especially with the solder paste / hotplate method. Read the documentation page here.
AVRSTMD
AVRSTMD - An open source microstepping driver that uses an atmega168 and current limited h-bridges. Very rad circuit.
Wiring Your Stepper
Pretty much all of our RepRap electronics are designed for Bipolar stepper motors. Every bipolar stepper motor has 4 wires that need to be wired to the driver board. These are labeled A, B, C, and D for lack of better terms. A and B are connected, as well as C and D. You can generally find out which wires are connected using a multimeter to measure the resistance. If you measure a small resistance (1-30 ohm) then they are connected. Generally, they are color coded and we have datasheets available, so things are easy.
Reproduced by kind permission of Rustle Laidman at StepperWorld.com [1]
Connect the 4 coil wires to the controller in any pattern. If it doesn't work at first, you only need try these 2 swaps:
Name | A | B | C | D |
Arbitrary first wiring order | 1 | 2 | 4 | 8 |
Switch end pair | 1 | 2 | 8 | 4 |
switch middle pair | 1 | 8 | 2 | 4 |
You're finished when the motor turns smoothly in either direction. If the motor turns in the opposite direction from desired, reverse the wires so that ABCD would become DCBA.
NEMA 17 Motors
Lin Engineering / 4118S-62-07
This is an awesome little NEMA 17 stepper motor. It is the primary motor used on the Cupcake CNC. It has good torque and a small size. Here are some of the specs:
- 200 steps per revolution (1.8 deg/step)
- 2.5 A/phase
- Phase resistance: 0.6 ohm
- Phase inductance: 0.93 mH
- Holding torque: 3240 g-cm or about 0.31 N-m
- Shaft diameter: 0.190" [4.83 mm]
- Shaft length: 0.50" [12.7 mm]
- Motor depth: 1.34" [34 mm]
NEMA 17 is a standard motor mounting geometry. The outside of the motor housing is 1.7" x 1.7".
Name | Pololu pin | Color |
A | 2B | Red |
B | 2A | Blue |
C | 1A | Green |
D | 1B | Black |
Suppliers
Technical Information
Zapp Automation / SY42STH47-1684B
- Rated current: 1.68 A
- Phase resistance: 1.65 ohm
- Phase inductance: 2.8 mH
- Holding torque: 4400 g-cm [0.43 N-m]
- Shaft diameter: 5 mm
- Shaft length: 22 mm
- Motor depth: 47 mm
A | 1B | Black |
B | 1A | Green |
C | 2A | Blue |
D | 2B | Red |
Suppliers
NEMA 23 Motors
Nanotec ST5709S1208-B
This was the original standard RepRap stepper motor. It has 400 steps to one revolution (0.9o per step). It actually has 4 coils (which means it can be wired as both a bipolar and unipolar), but we join up the wires to turn it into a bipolar motor.
Bipolar - Serial
This configuration is suited for our driver boards. It has higher impedance and higher resistance which means it draws less current. In this mode it can handle 0.85 amps, which is ideally matched to our L298 based boards. We recommend wiring it in this configuration.
Name | Color |
A | Red |
B | Black |
C | Green |
D | Yellow |
You will also need to splice the following wires together:
- Red/White and Black/White
- Green/White and Yellow/White
Bipolar - Parallel
This configuration offers higher performance. It has lower impedance, and lower resistance. That means you can push more electrons through, at a faster rate. However, it will draw about 1.7 amps, which is at the upper end of what the L298 is capable of delivering. We do not recommend wiring it like this.
Keep in mind that two wires make up the start and end of each coil.
Name | Color |
A | Red and Black/White |
B | Black and Red/White |
C | Green and Yellow/White |
D | Yellow and Green/White |
Suppliers
- ST5709S1208-B stepper motor from Farnell
- Nanotec Gmbh - Supplier / Manufacturer
Keling KL23H51-24-08B
This is the RepRap stepper motor for the Arduino controller. It has 200 steps to one revolution (1.8o per step). It actually has 4 coils (which means it can be wired as both a bipolar and unipolar), but we join up the wires to turn it into a bipolar motor. It is much cheaper than the Nanotec, and with half-stepping it is almost as accurate. (The Keling KL23H51-24-08B is also used in the Eiffel prototype).
Bipolar - Serial
This configuration is suited for our driver boards. It has higher impedance and higher resistance which means it draws less current. In this mode it can handle 1.5 amps, which is ideally matched to our L298 based boards. We recommend wiring it in this configuration.
Name | Color |
A | Blue |
B | Green |
C | Brown |
D | White |
- Red and Yellow
- Black and Orange
Bipolar - Parallel
This configuration offers higher performance. It has lower impedance, and lower resistance. That means you can push more electrons through, at a faster rate. However, it will draw about 3 amps, which our L298 is just not capable of delivering. We do not recommend wiring it like this.
Name | Color |
A | Blue and Yellow |
B | Red and Green |
C | Brown and Orange |
D | Black and White |
Suppliers
- MakerBot Industries
- Keling Inc. - The manufacturer/supplier. #5 on the list.
FL57STH51-2808A (axis extending 1 way) and FL57STH51-3008B (axis 2 ways like the picture)
The stepper motors are provided by Bits From Bytes. They come in two variations. Bought three from Bits From Bytes and I got one with the axis through and extending from both ends, and two with the axis extending one side. Their weight is slightly above 0.6 kg (I measured 619 gram).
To make the unipolar stepper a bipolar one, connect these wires together:
- Blue and Red/White
- Green and Black/white
Name | Color |
A | Blue/white |
B | Red |
C | Green/white |
D | Black |
Datasheets: FL57STH51-3008B. FL57STH56-2008B
Lin Engineering 5718X-05S
The 5718X-05S has the right specification to drive RepRap from the PIC controllers but we haven't tested it yet. It should work with the Arduino electronics too. It has 200 steps per revolution, so you need to set the controller to half-step it to get the resolution needed. Take care to get the model where the output shaft comes out front and back, not just at the front.
Stepper Motors
There is a good article on Wikipedia explaining the technology behind stepper motors. The physical size of stepper motors are usually described via a US-based NEMA standard, which describes the bolt-up pattern and shaft diameter; the RepRap site has an article explaining the standard. In addition to the NEMA size rating, stepper motors also also rated by the depth of the motor in mm, the longer the motor typically the more powerful. Stepper motors also have a step size rating, 4 steps within each cycle. The step size, divided into 360 degrees gives the number of steps per revolution. For example, "1.8 degrees per full step" is a common step size rating, equivalent to "200 steps per revolution".
Some stepper motor controllers generate 'microsteps' by generating a sine/cosine waveform for the stepper coils. The microsteps become less accurate then the full size steps, but allow finer control and smother operation. Also check the motor torque and the current draw to compare stepper motor strengths.
The pages related to building a Mendel has a list of suppliers of stepping motors.
The power of a motor is usually proportional to the physical size of the motor, The Darwin version of RepRap primarily used NEMA 24 motors, whereas the Mendel version is designed to use either NEMA 14 or NEMA 17 motors. The more commonly used size is NEMA 17 as it is easier to find NEMA 17 motors with sufficient torque compared to NEMA 14.
The StepperMotor page has even more details about the most common motors used in a RepRap/RepStrap.
Torque
The Mendel officially requires 13.7 N-cm torque (0.137 N-m or 1400 g-cm or 1.215 lb-in) for each of the X, Y and Z axes. Recent designs for extruders (ExtruderController) almost exclusively require stepper motors as well, but no torque requirements have been given in those designs.
Stepper motors do not offer as much torque or holding force as comparable DC servo motors or DC gear motors. Their advantage over these motors is one of positional control. Whereas DC motors require a closed loop feedback mechanism, as well as support circuitry to drive them, a stepper motor has positional control by its nature of rotation via fractional increments.
Power and current
All stepper motors will have certain specifications for voltage and current (typically 2.8 V and 1.68 A); as long as the stepper driver/controller does current control, you can use any supply voltage greater than the motor's rated voltage. In fact, a large difference is advantageous to the top speed of the motor. If the driver/controller does not do current control, you must use a supply voltage fairly close to the motor voltage (no more than 2x the voltage specified by the manufacturer) or the motor will overheat and burn out its winding insulation or demagnetize its rotor.
The version 2.3 RepRap axis controllers do have current control.
To run a stepper motor, two things are normally required: a controller to create step and direction signals (at ±5 V normally) and a driver circuit which can generate the necessary current to drive the motor. In some cases, a very small stepper may be driven directly from the controller, or the controller and driver circuits may be combined on to one board.
The stepper controller drives 3 wires -- traditionally labeled "step", "dir", "GND" -- which carry motion information to the stepper driver. (Often these 3 lines are opto-isolated at the front end of a stepper driver). The stepper controller is typically a pure digital logic device, and requires relatively little power.
The stepper driver connects to the 4 thick wires of the stepper motor. It contains the big power transistors, and requires a thick power cable to a DC power supply, because all the power to drive the motors runs through it.
From Wikipedia:[[2]]: Pulse-width modulation (PWM) is a very efficient way of providing intermediate amounts of electrical power between fully on and fully off. A simple power switch with a typical power source provides full power only, when switched on. PWM is a comparatively recent technique, made practical by modern electronic power switches.
Stepper drivers normally work by chopping up a supply voltage using an embedded PWM chip. These chips do require minor support circuitry (which is the primary thing you pay for when you buy a stepper driver). The PWM chips themselves usually have a unit price below 10 USD, depending mostly on their rated current.
Some example chips include:
Chip | Verified? | Max current | Comments |
[L293D | Yes | 0.6 A | Multiples can be stacked on top of each other to divide up amperage. |
[A3967] | No | 0.75 A | Slightly underpowered, at only 750 mA/phase |
[A4983] | Yes | 2 A | Can get very warm, active cooling is needed |
[Allegro 3977] | No | 2.5 A | |
[TB6560] | No | 2.5 - 3 A |
Stepper drivers
Sourcing stepper motor drivers can be a bit difficult. The RepRap V2.3 stepper drivers are very hard to purchase pre-assembled. Sourcing the individual parts and assembling the controllers can be done with just a little bit of skill; for those without skills or materials to assemble the boards, generic stepper drivers can be purchased. In Europe it will usually be more cost-effective to purchase pre-assembled boards than to purchase the individual parts and perform a DIY assembly.
Manufacturer | Verified? | Location | Max current | Microstepping | Comments |
Stepper Motor Driver 2.3 (A3982) | Yes | US | 2 A | 1/2 | Listed for comparison. |
EasyDriver (A3967) | Yes | US | 0.75 A | 1/8 | Slightly underpowered compared to other drivers, at only 750 mA/phase. bothacker uses EasyDriver[3], and reports that it has plenty sufficient power for Mendel. Recommended. |
Pololu (A4983) | Yes | US | 2 A | 1/16 | Can get very warm; active fan cooling or passive small heatsink is needed above ~0.5 A. Recommended. |
4 Axis Stepper Motor Driver Controller (A3977) | Yes | US | 2.5 A | 1/8 | 4 stepper drivers on a single board. |
DIY CNC | No | GB | 2.5 A | 1/8 | Can drive 1 stepper; discount when buying several. |
Arduino Motor Shield | No | US | 0.6 A | ? | Requires Arduino as controller. Can drive 2 servos, 4 DC, or 2 (bipolar or unipolar) steppers. Website notes that you can increase the max current by piggy-backing (soldering a chip onto a chip) another L293D chip on top of the first (and another one on top of that) |
TB6560AHQ based | No | GB/PRC | 1.5 - 3 A | 1, 1/2, 1/8, 1/16 | Can drive 3 to 5 steppers depending on model; read more. |
Stepper Driver 2.3 Clone by kymberlyaandrus | Yes | US | 2 A | 1/2 | Same schematic but physically smaller than the original version. The trim pot doesn't have a start/end point so adjusting the current can be more difficult than other boards. The terminal blocks are nice because they don't require making special connectors. |
Gecko Drive | Yes | US | 3.5 A | 1/10 (only) | Can drive 4 steppers |
Nanotec SMC11 | Yes | GER | 1.4 A | 1/16 | with cooling until 2.5 A |
LiniStepper by Roman Black | no | US | 3 A | 1/18 and "stepless" | Open Source: Circuit Diagram, PCB (Board) Layout, and PIC Software all available. |
Tri Duino Stepper | ??? | ??? | ??? | ??? | Open Source |
A3979breakout | ??? | ??? | ??? | ??? | ??? |
[grblshield] | No | US | 2.5 | 1/8 | 3 axis controller plugs onto Arduino Uno or similar |
PMinMo stepper motor driver comparison.
Micro stepping
Microstepping between the pole-positions is made with lower torque than with full-stepping, but has much lower tendency for mechanical oscillation around the step-positions and you can drive with much higher frequencies.
If your motors are near to mechanical limitations and you have high friction or dynamics, microsteps don't give you much more accuracy over half-stepping. When your motors are 'overpowered' and/or you don't have much friction, then microstepping can give you much higher accuracy over half-stepping. You can transfer the higher positioning accuracy to moving accuracy too.
Gecko drivers have a feature called mid-band resonance compensation which keeps stepper motors from stalling due to resonance issues that can occur when the motor is turning in the range of 5-15 RPMs. This can be very useful when controlling the steppers on a Tiag mill, for example. However, the stepper motors in a Mendel never run anywhere near that range, so mid-band resonance compensation provides no benefit to a Mendel build.
Further reading
- Alternative electronics has some design considerations for people designing stepper motor controllers and other reprap electronics.
- The PMinMO wiki: "Motors" article gives some recommendations for CNC motor selection.
- The Open Circuits wiki "motor driver" article has a long list of open-source stepper motor drivers, and related information.
- Some Wikipedia: linear actuator#Electro-mechanical actuators, rather than the motor spinning the lead screw as in most CNC designs, instead the motor spins an internal lead nut, pulling the motor up and down a (non-spinning) lead screw that passes all the way through the motor. The electronics works identically to other stepper motors -- standard stepper motor electronics can drive it. One RepRap researcher points out that this makes the mechanics simpler and, with a few changes to the design, could potentially lower total cost of a RepRap.[4][5][6]
- Stepper World has a great series of articles about how stepper motors work.
