RUG/Pennsylvania/State College/Printers
Main | Gallery | Printers | Software | Electronics | Members and Alumni | 3D Printing Club
All our machines now feature NFC tags! With an NFC tag reader (some smart phones now have this capability), you can now reach each machine's individual page. Just look for and scan the round white sticker on each machine.
Present printers
Name | Color | Extruder | Temperature | ||||
Beta | Wood | .35mm | 220C | Open Hybrid Mendel | RAMPS | Marlin | |
White | White | .35mm | Hot Tip: 205C Bed: 55C | Open Hybrid Mendel | RAMPS 1.4 | Marlin | |
Rainbow | Rainbow | .5mm (TBD since the "new" hot end had filament stuck inside) | 203C | Open Hybrid Mendel | RAMPS | Marlin | |
Gold | Gold | .35mm | 200C | Open Hybrid Mendel | RAMPS 1.4 | Marlin | |
Big Red | Red | .35mm | 210C | Open Hybrid Mendel | Rambo | Marlin | |
McDonalds | Yellow / Red | .5mm | 210C | Open Hybrid Mendel | Monotronics | Marlin | |
Purple | Purple | .35mm | 190C | ||||
Blue and White | Blue and White | .35mm | Hot tip: 210C, Bed: 0C | Open Hybrid Mendel | RAMPS | Marlin | |
Black | Black | .35mm | 220C | Open Hybrid Mendel | RAMPS | Marlin | |
Yellow & Green | Yellow & Green | .40mm | 185C | Open Hybrid Mendel | RAMPS | Marlin |
Printers Under Construction
Alpha | Wood | ? | ? |
Mondo | Wood | ? | ? |
Green | Green | ? | ? |
Rainbow2 | Rainbow | ? | ? |
Club Printers
Name | Color | Extruder | Temperature | |||||||||||||||||||||||
Solidoodle #1 | Silver
Ruby |
.25mm
.25mm
200c
200C
Former printers
Desktop/Personal 3D Printer ManufacturesThese companies sell 3D printers and kits intended for personal, DIY use with some potential for commercial application BitsFromBytes.com Bits from Bytes is part of 3D Systems, and sells a range of low-cost 3D printers and 3D printer kits including the 3D Touch and RapMan 3.2. Cost: Discontinued see Cubify Boots Industries Boots Industries produce a low-cost thermoplastic extrusion 3D printer called the Rostock, and also make nice 1.75mm PLA filament. Cost: $1,899 The Buccaneer This kickstarter project completely blew its funding goal of $100,000 and has funded $1.5 million. This project is hoping to have the buccaneer compete directly with Makerbot's Replicator 2, but for a much cheaper price. Cost: $347 Cubify •Cubify is part of 3D Systems, and sells several thermoplastic extrusion, consumer-grade 3D printers. These range from the single-material Cube, to the larger, multimaterial Cube X Duo and Cube X Trio. Cost: $1,299 CB-Printer.com CB-Printer is the first domestic 3D printer to be produced in Poland. Its '3D Printer CB-printer' is available either fully assembled or as a kit. Cost: $2,239 Delta Micro Factory Corporation The Delta Micro Factory Corporation is a Chinese 3D printer manufacturer. Under their PP3DP brand, the company sells the UP! range of low-cost, desktop 3D printers which use thermoplastic extrusion to build plastic objects. The same printers are also imported into the United States and resold by a company called Afinia. Cost: $1649 FormLabs Formlabs produces a low-cost desktop stereolithographic printer called the Form 1 Cost: $3,299 Makerbot Industries Makerbot produces a range of low-cost, desktop 3D printers that use thermoplastic extrusion to create plastic objects. The company claims around a 20 per cent share of all 3D printers sold, and was recently purchased by Stratasys Cost: $2199 MakeGEAR.com MakerGear develop products and services for the maker community, and sells its own M Series thermoplastic extrusion 3D printers in both kit and fully-assembled formats, as well as some RepRap open source models. Cost: $1,775 Portabee The Portabee is a small, low-cost and foldable thermoplastic extrusion 3D printer available either fully assembled or as a kit. Cost: $395 PrintrBot PrinterBot produces very low cost 3D printers in both kit-form and fully assembled. The company's printers are based on thermoplastic extrusion, and have iconic laser-cut-plywood body panels. Cost: $299 - $999 RepRapPro RepRapPro sell a wide range of kits for building open source RepRap 3D printers based on thermoplastic extrusion technology. Cost: Roughly $1000 ReprapUniverse.com ReprapUniverse.com sells kits for MendleMax and Prussa open source RepRap 3D printers. Cost: $1000 - $1200 Solidoodle Solidoodle is a fully-assembled, low-cost 3D printer available in 'base', 'pro' and 'expert' versions. Cost: $499 - $999 Ultimaker The Ultimaker is a lightweight, robust and very well respected thermoplastic extrusion 3D printer that in group tests frequently beats all rivals on the basis of its speed and quality of output Cost: $1640 - $2600 B9Creator - 3D Printer High Resolution DIY This is a kick starter project is a cool initiative to develop a low-cost kit for a stereolithographic (SLA) 3D printer. Cost: $2,795 |
