RAMPS 1.4.4
Revision as of 12:00, 17 September 2019 by MrAlvin (talk | contribs) (Firmware - Marlin: typo)
Version specific info
RAMPS 1.7 | RAMPS 1.6 | RAMPS 1.5 | RAMPS 1.4.4 | RAMPS 1.4 | RAMPS 1.3 | RAMPS 1.2 (RAMPS 1.2 old) and older
RAMPS 1.4.4
Release status: Prototype
RepRap Arduino Mega Pololu Shield Arduino MEGA based modular RepRap electronics.
Summary
A RAMPS shield that can be used with:
  • 8-bit or 32-bit controllers
  • a single 12V or 24V power supply.
  • TMC2130 drivers via SPI bus jumper selection.
And:
  • on-board 3V->5V buffer chip, for a higher Gate voltage control for all mosfets
  • two additional Fan mosfets. For a total of 3 PWM controlled Fans. With 3x 2.54mm jumper pins for Fan connections (max 1A per fan)
  • power selection for Fans: 24V or 12V rails
  • SMD mosfets. (datasheet numbers: 2 milli Ohm for Heated Bed, 4 milli Ohm for Hot-end) Max 1A for Fans.
  • 'on-board' 24V-to-12V DC-DC switch mode regulator
  • a 4-pin 7.62 mm (20A) Screw Terminal Power Connector, for Power Supply and Heat Bed connections
  • a "blue" 5.08 (13A) Screw Terminal Connector for Heat-Bed connection
  • jumper selection of 12V -> Vin on the Arduino. No soldering of D1 needed.
Further additions are:
  • 24V protection on Thermistor inputs
  • 100nF capacitors on end-stop pins.
  • 5V protection on end-stops - even for 3V controllers
  • a high voltage (12V) Z-probe port. Connected to either Z-Min (default) or Z-Max end-stop pins
  • Hardware SPI port (at center of board) for use with the Arduino DUE controller
  • includes all RAMPS familiar Aux ports - like: Aux-1, Aux-2, Aux-3 (with extensions), Aux-4, Servo, PS-on, I2C, 6x End-stops, 3x Thermistors
  • jumper connections for 5V, 12V, 24V. In addition to the usual +Voltage (Vcc pins) on the Aux ports.
And some options:
  • for use with a 5V PT100 sense amplifier - even on 3V controllers
  • an on-board Resistor option. For experimenting with Thermistor self heating issues
  • on-board diodes, which can be used to lower Vin voltage, and help prevent overheating of the Arduino Mega 5V voltage regulator
  • an option for an on-board 24LS256 EEPROM. For use with controllers that have no built-in EEPROM.
Click any image for larger versions
How this board came into existence
While I was designing the RAMPS 1.7 shield, a friend said: Well, that is all good and dandy, but 10x10 cm is too big for my printer. I need a RAMPS shield that can do:
  • TMC2130 drivers (without SPI wires floating on-top),
  • can be used with a single 24V power supply,
  • and still only be the size of a standard RAMPS board - or it will not fit nicely on my printer.
And this RAMPS 1.4.4 shield is what we have ended up designing, over several experimental iterations.
Files
Once we have a working prototype, we will share the design files.
Schematics
PDF version here
Reverse Polarity - just DO NOT do it!!!
Generation3Electronics-achtung.gif Do NOT reverse polarity on the power connector. There is NO PROTECTION DIODE for the mosfet's.
Reversing polarity is likely to fry your electronics.
Triple check to make sure the polarity on your power input is 100% correct!
Stepper driver Jumper settings
A4988 etc.
TMC2130
Motherboard/Controller board options
Arduino Mega
Works as is. And uses the same settings are the same as RAMPS 1.4 shield, with the following exceptions:
  • PS-on, is controlled by pin D39.
And is firmware 'Active High' (because of the additional "open collector" mosfet used to actually do the pull-down of the 'Power On' pin of an ATX styler power supply.
Where the RAMPS 1.4 signal is firmware 'Active Low', in order to turn on an ATX style power supply.
  • Fan 0 is still D9
  • Fan 1 is D7
  • Fan 2 is D12
CS pins for TMC2130 drivers are all connected to Aux-4, on pins that are NOT being used for the RRD LCD displays. This leaves all pins on Aux-1, Aux-2, Aux-3 and Servo available for regular use.
The TMC2130 CS pins are as follows:
  • CsX = D47
  • CsY = D45
  • CsZ = D32
  • CsE0 = D22
  • CsE1 = D43
Firmware - Marlin
In file 'configuration.h', select the following:
- For the line MOTHERBOARD, select (or type) "#define MOTHERBOARD BOARD_RAMPS_14_EFB"
- For regular Z-Min use, make sure that the line 'Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN' is uncommented (no // in front of the line)
For Marlin 2.0.x, in file: 'configuration_adv.h' possibly do the following changes
  • #define X_CS_PIN 47
  • #define Y_CS_PIN 45
  • #define Z_CS_PIN 32
  • #define E0_CS_PIN 22
  • #define E1_CS_PIN 42
  • #define E0_AUTO_FAN_PIN 7
For Marlin 1.0.x, in file 'pins_RAMPS_14.h' possibly do the following changes:
- If using the PS_ON_PIN, change it from 12 to 39
- If using TMC2130 stepper driver, with SPI control, then set the corresponding numbers
  • For X change from 53 to 47
  • For Y change from 49 to 45
  • For Z change from 40 to 32
  • For E0 change from 42 to 22
  • For E1 change from 44 to 43
Arduino Due
Pull-down resistors during power-up
As the DUE pins are Active High, during power-up (and rest/being programmed) it is necessary to use some pull-down resistors to pins/functions that would otherwise be running wild, while not under firmware control.
For this reason, all mosfet signals on the RAMPS-1.4.4 have 4K7 pull-down resistors mounted.
All other functions are fine with being Active High, during power-up of the Due.
Thermistor pins
Thermistor pins are default on A13-A15. But for use with Arduino DUE it is necessary to physically connect the thermistor signal pins to A9-A11
On the RAMPS 1.4.4 board this can be done in one of several ways.
One way is:
  • Cut the pins connecting the 144-shield to the Arduino, on pins A13-A15, and
  • solder the three jumpers marked J22 on the bottom of the Shield.
This will connect the thermistor signals to the correct Arduino DUE analog pins. But it will not be possible to access the A13-A15 (D67-D69) pins, for other possible uses. And on a standard 3D printer, this is fine.
Another way is:
  • Cut the three pcb paths, at the letter 'Z' (for the Z stepper driver).
The cut path is shown with two lines on the silk screen
  • Solder wires (or pins) into the three holes marked as J23 (J23 is shown on the bottom of the shield)
  • use jumper wires to connect from J23, to AUX-2.
    • A9 (D63) connects to the Hot-End (previous A13)
    • A10 (D64) connects to the Bed (previous A14)
    • A11 (D65) connects to the Chamber (previous A15)
It is now possible to replace the A13-A15 pins with longer pins (or solder some pins directly on top), so one could get access to pins A13-A15 pins, for other purposes. On a standard 3D printer, this is not necessary - for the adventures hacker, it might be useful to have access to all un-used pins.
A third way is:
  • to select the RAMPS 1.4.5 PCB files.
The 1.4.5 PCB file is the same as the 1.4.4 PCB files - except for the analog pin connections.
And you can still use the 1.4.5 shield with the Arduino Mega or Adafruit Grand Central M4 controllers, without hardware modification, and only by changing some numbers in the pins_.h files.
Firmware - Marlin
- For the line MOTHERBOARD, select (or type) "#define MOTHERBOARD BOARD_RAMPS4DUE_EFB "
In file: 'configuration_adv.h' possibly do the following changes
In file 'pins_RAMPS_14.h' possibly do the following changes:
- If using TMC2139 stepper driver, with SPI control, it could be useful to also then set the corresponding CS numbers. But if they have already been defined in 'configuration.adv' it is not necessary to repeat in the 'pins_RAMPS_14.h' file
Connecting RRD LCD displays
As the DUE board primarily is a 3V board, the standard RRD LCD dispays, become quite dim, if operated on only 3V.
An easy way to fix this, is to use one of the LCD144 adapters that connect to the Aux-3 and Aux-4 ports, and provides 5V to the LCD's - without risk of damage to the 3V DUE pins.
As the DUE pins are also High, during power-up, the LCD beep will go off, during power-up - unless a pull-down resistor prevents this.
The LCD144 adapter boards all provide this pull-down resistor on the buzzer pin.
These LCD144 adapter boards:
  • provide the EXP-1 and EXP-2 sockets that the RRD LCD displays use.
  • they also repeat the AUX-4 port, so any pins, not used for controlling the LCD display, can be used for other purposes.
  • they supply 5V
  • they have a pull-down resistor to stop the buzzer going off, during DUE power-up
  • and there can be other functions as well, depending on the particular version of LCD144 adapter board.
PCB files 'LCD144-A' is a basics EXP-1 and EXP-2 sockets adapter board, as well as it repeats the the Aux-3 port.
PCB files 'LCD144-B' offers the same as LCD144-A, but also has a 24LS256 EEPROM footprint. In case one does not want to use the EEPROM foot print provided on the underside of the RAMPS-144 and -145 shields.
Re-Arm
ToDo
ToDo
