Plastic Blaster
Revision as of 07:13, 8 July 2014 by AlbertDesigns (talk | contribs)
For big prints with less detail, we developed a nozzle that can print up to 3mm walls, in one go.
"We" is a 3d printing company in the Netherlands, "huur een 3d printer.nl" that rents 3d printers and also has a print-service.
To get an idea of the capabilities of this nozzle, let's look at some figures:
nozzle diameter: 2.5mm layer: 0.5mm print speed: 100mm/s flow rate: 2.5x0.5x100= 125mm3/s
compared to more standard settings:
nozzle diameter: 0.6mm layer: 0.2mm print speed: 75mm/s flow rate: 0.6*0.2*75 = 9mm3/s
so a ten-fold increase in flow rate is achievable, or: 10 times faster printing. Below pictures are of the first prototype, that already works fine. The nozzle brass, 3d printed in wax and then casted (brass) Like with smaller nozzles, you can print a bit thicker or thinner than the nozzle diameter. In this case: from 2 to 3mm is no problem.
