Mondrian
Revision as of 21:14, 10 July 2014 by Emmanuel (talk | contribs) (Medium)
Mondrian Documentation
Mondrian
a modular cartesian RepRap
RepRap, XY-head, Other
Here is what I wanted to try among the possibilities to make a Foldable RepRap.
I didn't pursued the XY-head + telescopic Z because I couldn't get my head around how to do it properly at this moment.
But after having seen the Create it gave me some new ideas, for another concept after the FoldaRap :)
<videoflash>iblqWGGPKoU</videoflash>
<videoflash>DySxmGJvnyQ</videoflash>
<videoflash>PEaP7HCyGPY</videoflash>
Specifications
  • Printed Parts: 20-21
  • Non-Printed Parts: ?
  • Material Cost: ?
  • Cost: ?
  • Printing Size: length of choosen extrusion minus 50-100mm (=100^3 for 200mm ; 200^3 for 300mm ; 350^3 for 400mm ; etc.)
  • Resolution : XY = 0.0125 mm ; Z = 0,00025 mm with m5 rods
  • Accuracy : 0.1 mm
  • Speed: 50 - 500 mm/s (print-travel, max speed tested yet)
Special features
  • Modular/scalable design (with the same printed part you can build a small cube or a big plotter frame, just choose accordingly your length of extrusions/belt)
  • Based on standard/cheap 20x20mm aluminium extrusion (with 6mm slot)
  • The frame is the linear guide for X, Y, Z axis
  • Easy to build, with few tools
  • 1.75mm Direct Driven Bowden Extruders (dual-head)
  • small footprint : lenght of extrusion plus 40mm (240x240 for 200mm ; 340x340 for 300mm ; etc.)
  • Big Blue Power Switch
  • [to-do] scissor-lift Z (not on the intermediate iteration), for a "flat" printer that expand as it print
Naming Convention
  • M222 : Mondrian (non-foldable verion), 200mm extrusion in X, 200mm in Y and 200mm in Z (the first prototype, the 9th iteration achieved the first nice print)
  • then you can build things like : M332, M333, M763, or even a huge M71010 (latest prototype of 700 x 1000 x 1000 mm)
To Do
  • rebuild latest design
  • dual-extrusion settings
  • x-addon for the chocolate extruder of LaurentF. from LabFab
  • mini-cnc addon [66]
  • foldable Z axis (long term)
  • bio-printing
R&D
Exemples of size scaling
Small
Medium
From left to right (3310, 332, 333)
XL
A huge Mondrian, using 70cm and 100cm profiles
External links, media/press, etc.
  1. Github mentioning an "awesome" project among others ^^
More inspiration
<videoflash>qpffEF9Jew0|320|240</videoflash>
  • H-XY
<videoflash>Hc0ADpQ6FBg|320|240</videoflash> <videoflash>FP2ciUBT6nY|320|240</videoflash> <videoflash>uqW3t7c3u4M|320|240</videoflash> <videoflash>_EWfmcWAz-M|320|240</videoflash>
  • Direct sliding on the aluminium frame
<videoflash>5UYMnzXQEtw|320|240</videoflash>
