Mendel Z-axis
Revision as of 09:52, 25 November 2009 by Adrianbowyer (talk | contribs) (Assembly)
Mendel Build Documentation
You may find the Mendel assembly data sheet useful during assembly.
Leadscrew base
Total # of assemblies 2
Name Qty/assembly Total Qty Type
z-leadscrew-base-bar-clamp_2off.par 1 2 RP
z-leadscrew-base_2off.par 1 2 RP
624-bearing.par 2 4 Bearing
m4-nylock.par 2 4 Fastener
m4-washer.par 8 16 Fastener
m4x40-cap.par 4 8 Fastener
m5-mudguard-washer.par 2 4 Fastener
RP parts
Assembly
The screws are the wrong way round in the picture (sorry...). The heads should be on the bearing side.
Leadscrew base with optoswitch
One of the leadscrew bases needs an optoswitch.
BOM
Total # of assemblies: 1
Optoswitch PCB 1 1 PCB
z-opto-bracket_1off 1 1 RP
z-axis-opto-spring.aoi 1 1 Spring
m4-nut.par 1 1 Fastener
m4-washer.par 1 1 Fastener
m4x40-cap.par 1 1 Fastener
m3-capx20.par 2 2 Fastener
m3-nylock.par 2 2 Fastener
m3-washer.par 4 4 Fastener
Printed parts
Assembly
  • Once again, the screws are the wrong way round in both pictures (sorry).* The heads should be on the bearing side.
Slot the nut into the hexagonal cavity between the two bearings (underside in view). Put a spare 15mm M4 cap screw through a washer and tighten that on the nut to move it down the cavity - it should be a snug fit and not fall out. Undo the cap screw and return it to your collection.
This picture shows the assembly with the spring omitted for clarity (the opto-switch PCB is upside-down in this picture - sorry...):
And this one shows it in place:
Put the bearing 40mm M4 screws and washers through first, then the spring assembly and its 40mm M4 screw. Tighten the spring screw a little way into its trapped nut. Then tighten the nuts onto the bearings. Finally fit the PCB. Don't tighten the M3 screws too tight, or you'll bend the PCB on the solder bumps sticking out the back (if you've got some, you can scalpel off two 2 mm lengths of 3mm internal-diameter silicone tube and use them as spacers).
Motor bracket
BOM
Total # of assemblies:1
drive-pulley_3off.par 1 1 RP
z-motor-bracket_1off.par 1 1 RP
m3-capx20.par 4 4 Fastener
stepper-motor-nema17-fl42sth47-1684A-01.par 1 1 Motor
Printed parts
Assembly
Tensioner
BOM
Total # of assemblies 1
z-tensioner_1off.par 1 1 RP
624-bearing.par 1 1 Bearing
m4-nylock.par 1 1 Fastener
m4-washer.par 3 3 Fastener
m5-mudguard-washer.par 1 1 Fastener
Printed parts
Assembly
Lead-screw
BOM
stud-z-leadscrew.par 1 2 Studding
z-drive-pulley-rim_4off.par 2 4 RP
z-driven-pulley_2off.par 1 2 RP
608-bearing.par 1 2 Bearing
m8-nut.par 3 6 Fastener
m8-washer.par 6 12 Fastener
Printed parts
Assembly
Loosely load the lead-screw (1) to ensure studding comes flush with lower nut. Tighten the two nuts which surround the bearing. Remove the lower parts (2) and store - these will be re-assembled later.
Back to Mendel mechanical construction root.
