Living hinge
Revision as of 23:38, 6 February 2013 by DavidCary (talk | contribs) (rough draft)
Many people treat the plastic parts printed by a RepRap or other FFF machine, or the plastic parts cut out of acrylic by a Laser Cutter, as more-or-less rigid items. If they need one thing to move relative to another, they make (at least) 2 separate plastic parts and add the appropriate hardware to enable that motion in the desired direction(s) and constrain the motion in other direction(s).
A few researchers are experimenting with making parts that are designed to move and flex. Some of them are relatively stiff parts that can be pushed very little -- only a few degrees, or only a fraction of a mm -- before they snap back into position. Others are relatively flexible parts that can be pushed much further -- a half-turn bend, or motion across several centimeters.
Further reading
