Litone v1.1
Release status: Working
Description |
The Litone is a project derived from graber i3 which is itself a variation of the MDF Prusa i3
License |
Author |
Contributors |
Based-on |
Categories |
CAD Models |
External Link |
You can find the elements of Litone here: The litone github
The Litone is a Prusa i3 while MDF, close and fully achievable with portable tools. There is no printed piece to begin to make it work (although some elements will simplify the later setting). It has been derived from Graber i3 which is designed for a laser cutting. The litone is slightly different to overcome lower tolerances when cutting the elements at hand.
Build volume: 200 x 200 x 150 mm
Track Changes
v1.1 update the box to bring the volume of printing 200x200x200 mm
Bill of tools
This list may be incomplete!
Tools
Nom
Besoin
Jigsaw |
Highly recommended
Drill |
Compulsory
Bill of Materials
This list may be change!
Threaded rods
Qty
Metric
Imperial
2 |
M5 x 292mm |
5mm x 11.5" (Z-Axis)
2 |
M8 x 51mm |
5/16" x 2" (y-belt idler)
Smooth rods
Qty
Metric
Imperial
2 |
8mm x 317mm |
8mm x 12.5" (Z-Axis)
2 |
8mm x 342mm |
8mm x 13.5" (Y-Axis)
2 |
8mm x 400mm |
8mm x 15 3/4" (X-Axis)
Bolts
Qty
Metric
Imperial
15 |
M3 x 10mm (for stepper motors) |
6 |
M3 x 13mm |
6-32 x 0.5"
41 |
M3 x 19mm |
6-32 x 3/4"
4 |
M3 x 20mm (Heated Bed) |
3 |
M3 x 25mm (RAMPS mount) |
2 |
M3 x 25mm |
6-32 x 1"
4 |
M3 x 32mm |
6-32 x 1,1/4" (X-Car)
8 |
M3 x 38mm |
6-32 x 1,1/2"
Nuts
Qty
Metric
Imperial
7 |
M3 Nut Nylon Insert |
61 |
Nut 6-32 Nylon Insert
2 |
M5 Nut |
2 |
M8 Nut |
Nut 5/16"
Washers
Qty
Metric
Imperial
6 |
M3 Washers |
Washers 6-32
2 |
M8 Washers |
Washers 5/16"
Other Parts
Qty
Item
4 |
Spring (heated bed mount)
7 |
Zip Tie 4"
2 |
bearing 608zz (for Y and X idler)
2 |
Flexible 5 mm x 5 mm Shaft Coupling OR 20mm lenth of PVC Tubing (Z-Axis)
10 |
LM8UU linear bearing
1 |
Extruder w/ 0.3mm Nozzle for 1.75mm Filament w/ 100k NTC
1 |
Wade Gear
2m |
(7 feet) GT2 belt 6mm width
2 |
GT2 20-Tooth Pulley 5mm Shaft
Electronics
Qty
Item
1 |
Mega2560 R3 ATmega2560
1 |
RAMPS 1.4
1 |
MK2B Dual Power PCB Heat Bed
3 |
Micro Switch (end stops)
1 |
RAMPS 1.4 LCD12864 Intelligent Controller LCD Control Board (optional, for standalone operation)
5 |
Nema 17 Stepper motor
5 |
A4988 Stepper Motor Drive Module
1 |
12V 15A power supply unit
