LaserCutYAxis
Revision as of 17:28, 6 April 2011 by Smurf (talk | contribs) (Connecting to Frog Plate)
General
This page and its peers should guide you through assembling a RepRap Lasercut Mendel from the TechZone kit, or from parts you have laser cut which are the same as the TechZone parts. It is a work in progress, and needs some help, feel free to edit this document to add comments of you your own, or contact us [here] and send us messages asking us for better clarification or details.
I am starting by posting the pictures I have, and over the next few days, I will fill in the instructions and detials (6 April 2011)
Thanks,
Lambert (TechZone R&D/Support/Documenter)
You can access this page and it's peers (for the other parts of the Lasercut Mendel assembly from the TechZone Lasercut Mendel Page
Whene assembling the Y Axis, it is OK to actually tighten the bolts/nuts since it is all aligned by the frog plate and later installation into the frame.
Y 180 and Y 360
On the left is a picture of the parts used to make the Y Axis 180 side. See the image below on assembling the Y Axis to view the assembled Y 180 parts. This part requires a captive nut which can be tricky since you need to widen the hole enough to fit the nut in but not so wide that the nut can break free and rotate. A good way to do this is to gently heat the nut up with a soldering iron until the plastic around it starts melting and push it into place with the soldering iron. Be careful not to push it too far since there really is no way to pull it back out. This trick is useful almost anywhere there is a nut being held with plastic. Do not use the soldering iron trick with the lock nuts because the plastic will melt and they will no longer thread properly (these are the nuts with the plastic ring in one side that holds the threads on).
Photo of the parts used to Assemble the Y axis
Photo of assembled frog plate and Y 180 and Y 360
Install the Axis
Photo of the parts used to install the build platform
Photo of an Installed Axis
The two Y smooth bars are all that is needed other than the Huxley frame and the Y axis. The bars are 265mm (10-1/2") in length. Instalation of the build platform itself will come later... after the motors, belts and endstops.
Place the smooth bar in the front smooth bar clamps
I place the front of the machine away from me and put the two smooth bars into the the smooth bar clamps. I put them through a few inches, so that they fall short of the back smooth bar clamps.
Slide the Axis onto the smooth bars
I then slide the Y axis onto the smooth bars, the wasteplate is away from me, towards the front of the machine.
I then slide the smooth bars towards me, into the back smooth bar clamps.
Alignment of these bars is included with the Frame squaring and adjustment information here.
Go back to the frame adjustment information and follow the instructions there to tighten the smooth bar clamps into place. Threadlock is probably a good idea on the nuts holding the smooth bar clamps in place... once they are all adjusted.
