FutureToolIdeas
- 1 Future Tool Ideas
- 1.1 Polymer granule Extruder
- 1.2 Support Filler Extruder
- 1.3 Drawing / Plotting Head
- 1.4 Painting / Brush Holder
- 1.5 Milling / Drilling Head
- 1.6 Laser Etch Tool
- 1.7 Solder Paste Syringe
- 1.8 Fields Metal Syringe
- 1.9 Fab@Home Print Head
- 1.10 Pick and Place Tool
- 1.11 Soldering Tool
- 1.12 Hot Wax Syringe
- 1.13 Ceramic Print Head
- 1.14 water ice extruder
- 1.15 Electrochemical Milling / Drilling Head
- 1.16 Electrochemical Printed Circuit Board Head
- 1.17 laser Milling / Drilling / Printing Head (SLS)
- 1.18 Electron beam Milling / Drilling / Printing Head (EBM)
- 2 Comparison of Tool head processes
- 3 Other
Future Tool Ideas
(When someone succeeds in building one of these tools, move it to RepRapToolHeads).
If you have a great idea that is not directly tool-head-related, drop it off at FuturePlans or GSoC 2010 or the FirmwareWishList.
The advantage of a polymer granule extruder is, of course, that all thermoplastic polymers are available in bulk at very low cost in granules - it's the standard form. Getting 3mm filament (which is what RepRap currently uses) is not difficult - many companies will do it - but it does add slightly to material costs.
More information on the Granule Extruder
The support filler extruder allows parts to be printed with overhangs that would otherwise not be possible to print with just a plastic extruder. Pump a syringe full of putty, then you can make even more intricate objects. It adds another layer of design challenge however. But thats a software issue ;)
More information on the Support Filler Extruder
This head is actually quite simple. It consists of a pen or marker as a drawing tip and a mount to hold it, It can be used to draw stuff in 2 dimensions. the third dimension becomes more of an "on the paper / off the paper" movement, and there is even no control board required for the head itself! One very useful aspect of this is that certain common art pens are etch resistant and this head can be used to make PCB masks directly on the copper board. It can also be used for pen calligraphy, or as a signing machine.
currently, there are no software tools that can directly convert an image into usable gcode.
A more complex variation would use multiple colors, like commercial plotters. These designs would require the 4th axis motor and control board, as well as firmware/software modification, in order to select the color.
More information on the Drawing / Plotting Head
Similar to the drawing, but with a paint brush. Watercolor or ink would be easiest, perhaps with a stepper driven syringe to deliver paint/ink to the brush. Fast Z axis movement would also be helpful for altering width of painted lines, perhaps with a stepper driven rack-and-pinion mount for the brush.
Painting would require significant software/firmware development.
A milling drilling head would bridge the gap between additive manufacturing and subtractive manufacturing. on early and basic versions, it would only really need to support lightweight materials such as wood (MDF) and copper clad boards (PCB milling). These two materials would allow the machine to have the best of both worlds and also the potential to vastly simplify the circuit board creation process.
More information on the Milling / Drilling Head
Laser Etch Tool
Consisting of a laser and a system of mirrors to redirect the beam, a laser etch tool could be used for a variety of purposes. With a low powered laser, the tool could simply be used to mark designs on a printed object or with a higher powered laser it could even used to do laser sintering to make objects from a high strength metal.
More information on the Laser Etch Tool
A solder place syringe would be a very useful addition to the Fields Metal syringe and the PCB Mill head. It would allow the machine to put solder down in places ahead of time to ease soldering of components after the fact. It would even make it much easier to use surface mount parts on RepRapped board.
More information on the Solder Paste Syringe
Similar to the extruder, a fields metal syringe would be a syringe with a heating element that would be able to melt and extrude Fields Metal, a special metal with a low melting point. This material has a wide variety of uses in making fabricated circuits.
More information on the Fields Metal Syringe
Fab@Home Print Head
The Fab@Home project has created a very nice syringe based print head that can extrude a variety of materials. It would theoretically be very simple to mount it on the RepRap robot frame and then have at it. Currently both projects are blissfully working away in their own separate worlds, but due to the open nature of both projects, collaboration has a very bright future.
More information on the Fab@Home Print Head
Pick and Place Tool
More of a pipe dream than a solid idea, but a pick and place head would make RepRap one step closer to hands free circuit board production. Consisting of a simple grabber that would grab and place components in place on the circuit board, the print head could dramatically reduce time and effort required to build a RepRap.
More information on the Pick and Place Tool
Soldering Tool
Also more of a dream than a solid idea, it would be used in conjunction with the solder paste syringe and the pick and place tool, a soldering tool would be able to make the physical solder joint to join the component to the board. It would probably take the form of a heated tip of some sort.
More information on the Soldering Tool
Hot Wax Syringe
Nearly identical to the fields metal syringe, a hot wax syringe would be used to produce objects with wax. These objects could then further be used in a process called lost wax casing to produce parts out of metal such as aluminum. This would allow the RepRap project to produce its own custom metal parts.
More information on the Hot Wax Syringe
Ceramic Print Head
A ceramics extruder would be extremely useful. It could produce a variety of objects that could then be fired. These objects would have interesting and desirable properties such as hardness, insulation, non-conductivity, etc. For example the extruder barrel could be insulated with a ceramic part printed by a RepRap.
More information on the Ceramic Print Head
-- Main.ZachSmith - 11 Feb 2007
water ice extruder
For mass-produced ice sculpture, individualized ice lolly, etc.
An electrochemical milling drilling head would mill away any conductive material. The tool head is the cathode, and the workpiece is the anode. There is very little tool wear and the objects milled in this way are not distorted. This would allow the RepRap project to produce its own custom metal parts.
More information on the Electrochemical Milling / Drilling Head
-- Main.EnriquePerez - 13 Aug 2008
An electrochemical PCB head would be designed to mill away copper from copper clad boards. The tool head is the cathode, and the board is the anode. This would be another way for the RepRap project to produce its own circuit boards.
More information on the Electrochemical Printed Circuit Board Head
-- Main.EnriquePerez - 04 Dec 2008
Selective laser sintering of metal Good on non reflective metals 98% energy transfer on steel very low on Aluminium ( reflective )
of glass
Of metal Can be used on all common metals except lithium
Non conductive materials do effect the beam as beam is not attracted to it.
Discussion of Advantages and Disadvantages of different manufacturing / tool head processes.
Other
tool head changer
If a single machine can switch between multiple, independent tool heads, it can do things that would be very difficult to do, even with the same identical tool heads, carrying a part back and forth between single-tool machines. For example, Shape Deposition Manufacturing.
Even a first step towards this goal -- making it easier for a human to pop out one tool head and snap in a different one -- would be useful.
Multiple tool heads
Attaching several independent tool heads to one machine gives most of the capabilities of a fully automatic tool head changer, and seems easier to implement.
The Hydra-MMM Prototype has made a lot of progress towards implementing this idea.
