File:Rroofl Z-axis STLs.zip
Revision as of 18:41, 26 September 2012 by BouncyMonkey (talk | contribs) (uploaded a new version of "File:Rroofl Z-axis STLs.zip": Two of the STLs have been changed from the previous edition. These are both of the z-axis base parts. The changes make the two ends have the same pattern and spacing for the bolt and screw)
Rroofl_Z-axis_STLs.zip (file size: 61 KB, MIME type: application/zip)
Warning: This file type may contain malicious code.
By executing it, your system may be compromised.
The STLs for the Rroofl Z-axis development.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Dimensions | User | Comment | |
current | 21:03, 27 October 2012 | (61 KB) | BouncyMonkey (talk | contribs) | Modifications to the Z-axis bits in response to suggestions from Vik. The changes add stiffness to the assembly and also remove interference between the x-axis belt pulleys and the adjustment screw. |
18:41, 26 September 2012 | (65 KB) | BouncyMonkey (talk | contribs) | Two of the STLs have been changed from the previous edition. These are both of the z-axis base parts. The changes make the two ends have the same pattern and spacing for the bolt and screw holes. The drive support end also has been modified a little to | |
20:41, 23 September 2012 | (65 KB) | BouncyMonkey (talk | contribs) | This edition included updated versions of the Z-axis printable components. The z-axis drive location has been shifted and many holes resized to allow a better fit. | |
00:47, 15 September 2012 | (82 KB) | BouncyMonkey (talk | contribs) | The Zaxis assembly has been rejigged to make assembly easier and also enable Vik to use him Mallet more effectively when installing bearings. A limit switch fitting option has been added. | |
01:26, 7 September 2012 | (52 KB) | BouncyMonkey (talk | contribs) | The STLs for the Rroofl Z-axis development. |
- You cannot overwrite this file.
File usage
The following 2 pages link to this file:
