File:Rroofl Z-axis STLs.zip
Revision as of 00:47, 15 September 2012 by BouncyMonkey (talk | contribs) (uploaded a new version of "File:Rroofl Z-axis STLs.zip": The Zaxis assembly has been rejigged to make assembly easier and also enable Vik to use him Mallet more effectively when installing bearings. A limit switch fitting option has been added.)
Rroofl_Z-axis_STLs.zip(file size: 61 KB, MIME type: application/zip)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
The STLs for the Rroofl Z-axis development.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current21:03, 27 October 2012 (61 KB)BouncyMonkey (talk | contribs)Modifications to the Z-axis bits in response to suggestions from Vik. The changes add stiffness to the assembly and also remove interference between the x-axis belt pulleys and the adjustment screw.
18:41, 26 September 2012 (65 KB)BouncyMonkey (talk | contribs)Two of the STLs have been changed from the previous edition. These are both of the z-axis base parts. The changes make the two ends have the same pattern and spacing for the bolt and screw holes. The drive support end also has been modified a little to
20:41, 23 September 2012 (65 KB)BouncyMonkey (talk | contribs)This edition included updated versions of the Z-axis printable components. The z-axis drive location has been shifted and many holes resized to allow a better fit.
00:47, 15 September 2012 (82 KB)BouncyMonkey (talk | contribs)The Zaxis assembly has been rejigged to make assembly easier and also enable Vik to use him Mallet more effectively when installing bearings. A limit switch fitting option has been added.
01:26, 7 September 2012 (52 KB)BouncyMonkey (talk | contribs)The STLs for the Rroofl Z-axis development.
  • You cannot overwrite this file.
The following 2 pages link to this file:
