File:Rroofl Z-axis Assembly-Blender257.zip
Revision as of 00:50, 15 September 2012 by BouncyMonkey (talk | contribs) (This is a single Blender file containing all of the development models for the Rroofle Z-axis. It also includes other components so that it can all be made to line up properly. If we're lucky it may even be able to be made.)
Rroofl_Z-axis_Assembly-Blender257.zip(file size: 1.29 MB, MIME type: application/zip)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current21:01, 27 October 2012 (1.29 MB)BouncyMonkey (talk | contribs)Modifications to the top bracket and the bottom bracket of the z-axis to reflect adjustments in switch locations, and greater stiffness for the z-axis assembly.
18:39, 26 September 2012 (1.35 MB)BouncyMonkey (talk | contribs)The z-axis base ends have been modified to have the same bolt hole pattern and spacing and the clearance between the z-axis frame and the big gear has been enlarged.
20:39, 23 September 2012 (1.44 MB)BouncyMonkey (talk | contribs)This edition has major changes to the z-axis drive base to sort out binding issues. Also most holes are slightly larger to allow easier fitting and less work with a drill.
00:50, 15 September 2012 (972 KB)BouncyMonkey (talk | contribs)This is a single Blender file containing all of the development models for the Rroofle Z-axis. It also includes other components so that it can all be made to line up properly. If we're lucky it may even be able to be made.
  • You cannot overwrite this file.
The following 2 pages link to this file:
