File:Milling pcbs 06 detail.jpg
Size of this preview: 800 × 600 pixels. Other resolutions: 320 × 240 pixels | 1,200 × 900 pixels.
Original file (1,200 × 900 pixels, file size: 310 KB, MIME type: image/jpeg)
Detail of pcb milling done on a tabletop cnc. 60 degrees cheap carbide v-bit with 0.2 mm flat end. Right: milled at 0.2 mm depth. Left: milled at 0.1 mm depth.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 07:40, 11 December 2010 | 1,200 × 900 (310 KB) | Lanthan (talk | contribs) | Detail of pcb milling done on a tabletop cnc. 60 degrees cheap carbide v-bit with 0.2 mm flat end. Right: milled at 0.2 mm depth. Left: milled at 0.1 mm depth. |
- You cannot overwrite this file.
File usage
The following 2 pages link to this file:
