File:Milling pcbs 01 detail.jpg
Revision as of 07:24, 11 December 2010 by Lanthan (talk | contribs)
Original file(1,253 × 940 pixels, file size: 298 KB, MIME type: image/jpeg)
Copper plate milling with gEDA/pcb -> gerber and excellon files -> pcb2gcode -> EMC2/Axis. 60 degrees v-bit with 0.2 mm flat end. Milling at 0.1 mm (still to deep!). epoxy-glass board.
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeThumbnailDimensionsUserComment
current07:23, 11 December 2010Thumbnail for version as of 07:23, 11 December 20101,253 × 940 (298 KB)Lanthan (talk | contribs)Copper plate milling with gEDA/pcb -> gerber and excellon files -> pcb2gcode -> EMC2/Axis. 60 degrees v-bit with 0.2 mm flat end. Milling at 0.1 mm (still to deep. epoxy-glass board.
  • You cannot overwrite this file.
The following 2 pages link to this file:
Metadata
