File:Milling pcbs 01 detail.jpg
Size of this preview: 799 × 599 pixels. Other resolutions: 320 × 240 pixels | 1,253 × 940 pixels.
Original file (1,253 × 940 pixels, file size: 298 KB, MIME type: image/jpeg)
Copper plate milling with gEDA/pcb -> gerber and excellon files -> pcb2gcode -> EMC2/Axis. 60 degrees v-bit with 0.2 mm flat end. Milling at 0.1 mm (still to deep. epoxy-glass board.
File history
Click on a date/time to view the file as it appeared at that time.
Date/Time | Thumbnail | Dimensions | User | Comment | |
current | 07:23, 11 December 2010 | 1,253 × 940 (298 KB) | Lanthan (talk | contribs) | Copper plate milling with gEDA/pcb -> gerber and excellon files -> pcb2gcode -> EMC2/Axis. 60 degrees v-bit with 0.2 mm flat end. Milling at 0.1 mm (still to deep. epoxy-glass board. |
- You cannot overwrite this file.
File usage
The following 2 pages link to this file:
