File:Knob-by-nophead.aoi
Revision as of 05:34, 24 August 2008 by ErikDeBruijn (talk | contribs) (Made by nophead. When he e-mailed it to me he had this to say: "I assume you have AOI so can make the STL. I have been meaning to put it on the objects wiki but have not got round to it. If published it really needs a table of scaling factors for various )
Knob-by-nophead.aoi(file size: 12 KB, MIME type: unknown/unknown)
Warning: This file type may contain malicious code. By executing it, your system may be compromised.
Made by nophead. When he e-mailed it to me he had this to say: "I assume you have AOI so can make the STL. I have been meaning to put it on the objects wiki but have not got round to it. If published it really needs a table of scaling factors for various nut sizes, or an array of STLs. Also BA nuts are thicker than metric so it may need a bit slicing off the end. You will have to play around with scaling it because it was for 2BA, but was a bit tight as internal holes come out a lot smaller than they should be. This seems to depend on the filament width and the type of plastic. I also think how much you stretch it will have an effect. Adrian published corrections for circles but I get an order of magnitude more error that that formula. It is something on my list of things to research and quantify."
File history
Click on a date/time to view the file as it appeared at that time.
Date/TimeDimensionsUserComment
current05:34, 24 August 2008 (12 KB)ErikDeBruijn (talk | contribs)Made by nophead. When he e-mailed it to me he had this to say: "I assume you have AOI so can make the STL. I have been meaning to put it on the objects wiki but have not got round to it. If published it really needs a table of scaling factors for various
  • You cannot overwrite this file.
The following page links to this file:
