Calibration
Revision as of 09:35, 28 October 2012 by Danielpublic (talk | contribs) (Added a tl;dr-section with useful formula and helpful gcodes. X & Y scaling)
This page has been flagged as containing duplicate material that RepRapSoftwareTweakingManual also attempts to cover.
These pages should be merged such that both pages do not attempt to cover the duplicate topics.
Calibration is the collection of mechanical "tweaking" processes needed to get exact, quality prints. While your reprap machine may be working as far as the electronics are concerned, calibration is necessary to have well printed parts.
Without calibration, prints may not be the correct dimensions, they may not stick to the build surface, and a variety of other not-so-wanted effects can occur. A Reprap can be calibrated to be as accurate as the mechanics allow.
Once you have finished the physical build of your reprap printer Calibration is the next big hurdle. Trying to print before calibration will likely result in a messy "blob" smeared over the printer bed.
The following set of objects and notes are taken (and edited) from Coasterman who posted them to Thingiverse. They have been moved to the RepRap wiki so that they could more easily be edited and contributed to by the broader community.
The specific recommendation made in this article are based on Skeinforge (or sfact). This information should be nearly equivalent for many other softwares. Regardless of the software used, this set of calibration objects invaluable.
Note that calibration is an ongoing process that needs to be performed throughout the life of the printer. There are almost always adjustments and tweaks that can be done to improve print quality.
Prerequisites
Before attempting calibration, a few things are necessary:
  • A stable build process should be established. Your machine should be completely built and all of the nuts and bolts tightened down.
  • The machine should be on a steady, flat, level surface.
  • Calipers, a level, and any necessary wrenches/screwdrivers to adjust the machine should be handy.
Calibration processes
Bed Leveling
Objective: To level the print bed so that your objects will adhere to the surface. The result of this step should make the extruder nozzle the exact same height above the bed across the entire bed surface.
Signs of having an unlevel bed: Plastic will adhere to part of the bed but not others. The extruder nozzle might "dig" into parts of the bed, pulling up or deforming the bed surface.
Importance: The first layer of the print is the foundation of all subsequent layers. Having bad first layers could mean the part might peel off of the print bed during the print, "blobs" of plastic may form, causing problems in following layers, and a variety of other things.
Calibration Object: bedleveling.stl
Instructions
Establish a corner height (step 1):
  • Move the nozzle to a corner of the bed and measure it's height at this point.
  • Move the nozzle down close to the bed.
  • Use a thick piece of paper or plastic as a shim and slide it under the nozzle. It should just barely fit underneath. If not, move your nozzle up or down slightly until it does.
Getting that second corner (step 2):
  • Move the Y axis (the bed should move) to the second corner.
  • Using the same shim, determine if the bed is too close or too far away from the nozzle at that point.
  • Adjust the screws that hold up the bed along that edge so that the height at the corner matches your shim.
  • Move back to the first corner and check the height with the shim again. It should match, if not, repeat step 1 and step 2 until it does.
Getting the third and fourth corners (step 3): There are two ways to adjust this - tweaking the jack screws that hold up your X axis travel track and adjusting the bed itself.
Jack screw method:
  • Move the Y axis to the third corner and check it with the shim. If it is too high or too low, turn off the motors and slightly rotate one of the jack screws until the nozzle height matches the shim.
  • If this method is used, you MUST return to the second corner and move the nozzle up/down to the shim, and then repeat this method until both sides line up with the shim.
Nut and bolt method:
  • Move the Y axis to the third corner and check it with the shim. If it is too high or too low, adjust the bed screws along that edge until they line up.
  • Check the height with the second corner and repeat this method until the corners line up
Once the bed is level print the bed level testing object and ensure that each square is even, smooth and consistent.
Other methods do exist. Referencethis document for more information. You may want to download the original scad file so that you can change the dimensions to match your print bed.
http://www.thingiverse.com/thing:13053
Bed surface preparation
Objective: correct preparation of the bed to ensure that objects adhere to it.
Instructions
An incorrectly prepared bed can result in poor adherence of the plastic to the base as well as a 'bubbling' effect.
Even a little bit of finger print grease on some surfaces is enough to ruin a print.
Bed preparation will depend on what material your bed is made out of, what you intend on covering it with, as well as what material you expect to be printing:
Glass
Clean the glass with a common household window cleaner and a lint free cloth. Spare no effort in ensuring that the glass is spotless.
Tapes
When applying any type of tape to print on, it is important to make sure the print surface is still smooth when you are done. Attempt to lay down tape edge-to-edge, with no overlap. If applying multiple layers, it can be benificial for the layers to alternate directions, so that direction-specific defects do not build up as you add layers.
Blue Tape
For those printing PLA, it has been found to adhere well to 3M's 'Scotch-Blue Painters Tape for Multi-Surfaces #2090'. This tape may be found in two inch rolls, or three inch rolls. The PLA will adhere to multiple layers, so it is advised to place down at least three layers of tape, before printing on a surface, to prevent damage to the print bed.
Kapton Tape
Kapton tape is a heat resistant tape which is commonly used to cover a variety of material types used in beds. The kapton tape provides good adherence for a variety of plastics.
Other Materials
TODO: need details on other materials.
Motor Calibration
Objective: set the current for the stepper motors to the correct level.
Your motors should be quiet when running and can occasionally make musical sounds, particularly when making circles. If they are making a fair amount of noise then you have a problem.
Calibration Object: None
NOTE: incorrect current settings can damage your pololus and/or your motors.
Symptoms
Motors make significant noise.
This generally means you have too much current.
Motor vibrates without turning.
This generally means that you don't have sufficient current to the motors. You could also have a problem with a part sticking which stops the motor from being able to drive the axis. It might also be possible to be way off in your steps/mm (eg typo), when steps/mm is double the correct value your motor might vibrate on the spot.
Axis movement pauses momentarily and then resumes.
You may have too much current going to the motor which is causing the pololu to over-heat. Reduce the current. This can also be caused by firmware but check your motors first.
Instructions
Each Pololu has a trimpot located next to the heatsink. The trimpot controls the current that is sent to each motor. Turning the trimpot counter-clockwise reduces the current to the motor, turning it clockwise increases the current to the motor.
Start by adjusting the trimpot down until your motor vibrates on the spot rather than turning cleanly. Now turn the trimpot in a clockwise direction in small increments (1 eighth of a turn) until the motors just start running. Then give the trim port a final turn of about 1 eighth of a turn and your should be good to go.
Extrusion
Objective: to ensure the hot end temperature is set correctly so that material is extruded cleanly
PLA
Layer height
Objective: to correct the layer height settings to reflect your printer's actual layer height.
Calibration Object: 0.5mm-thin-wall.stl
Instructions
Print the 0.5mm thin wall cube and make sure that the layers adhere well but the nozzle does NOT drag through while printing.
Adjust softwares layer height in .01 increments until you get a nice print.
Depending on other factors you may find it hard to get all four walls to print nicely. For the first pass if you can get just one wall looking good then move on to the next test.
Infill
Objective: to correct the infill setting.
Calibration Object: 20mm-box.stl
Instructions
Set infill solidity to 1.0 for this.
Print the cube and analyze the top. If there is NOT ENOUGH plastic (a concave top), reduce the Infill Width over Thickness by .05 increments. If there is TOO MUCH plastic (convex top), turn that parameter up by .05 increments.
Once you're feeling close, start bumping it around in smaller increments.
You may also need to adjust your feed rate.
Adjust the feed rate by increments of 2 or so until you feel close. If it looks really disgusting and blobby, go by increments of 0.5mm. Then go by smaller and smaller increments until you've nailed it. Although you probably just want to decrease Infill Width over Thickness instead of decreasing Feedrate because lowering feedrate will degrade the resolution.
Temperature control
Objective: to set the hot end temperature correct for your preferred plastic.
Note: you will find that different types of plastic have vastly different temperatures for both your hotend and your bed. What you might not expect is that different colours for the same material can also required different printing temperatures.
As the tower has quite a small 'top' surface area you may need to cool this object as you print. If your printer doesn't have a built in fan you can use any room fan as a substitute.
Calibration Object: 50mm-tower.stl
Instructions
Set the 'Infill solidity' to 1.0.
Start by doing a simple extruder test to determine what the range of temperatures are that you can extrude at. Reduce the temperature in 5 degree increments until the extruder starts skipping when you do a manual extrude. Turn the extruder up 5 degrees and note this as your minimum extruder temperature.
Print this block.
If it looks like a blob, turn down all the temps by 5 degrees until you get something good. Chances are you won't need to do this more than 5 degrees.
Note: Be careful as going too low can result in the plastic setting making it hard for the motors to drive the plastic, possibly causing wear or damage.
TODO: list temperature ranges for common plastics.
Recommendations
PLA
Hotend: 185 °C Bed: 60 °C
ABS Hotend: 230 °C
Bed: 110 °C
Perimeter Width
Objective: correct the perimeter width over thickness
Calibration Object: perimeter-wt.stl
Instructions
This test prints two objects which are designed to fit together.
Try to insert the smaller block into the larger block. Try inserting it differently a few times, and check your belt tensions.
TODO: Need notes on calibration of belt tensions
If you can get it in a few mm, good. If you can get it in all the way, awesome. The fit should be snug. If it is loose and can jitter around inside, decrease the perimeter width over thickness. If you CANNOT get it in AT ALL, and you are sure there are no whiskers blocking it, INCREASE perimeter width over thickness. The latter is more likely.
Bridging
Objective: to maximize your printers ability to bridge gaps (i.e. print in thin air).
Calibration Object: 20mm-hollow-box.stl
Instructions
Print the calibration object and if the top droops in, increase the BRIDGE FEEDRATE MULTIPLIER in Speed by increments of .1 until the top stops drooping.
Print Precision
Objective: improve print precision
Calibration Object: precision-block.stl
Instructions
Then there is the precision block. No real huge calibration parameter here. Just play with this and see how well it does on the overhangs and shapes.
TODO: We need to add some recommendations on how to improve this or find more direct methods of calibrating specific aspects of the print.
Overhang
Objective: fix overhang problems
Calibration Object: overhang-test.stl
Instructions
Then there is a simple overhang test. Print and observe the overhangs. This is up to you to figure how to improve the overhangs.
Oozebane
Objective: stop material oozing out of the noozle during 'non-printing' moves.
Many extruders will emit (ooze) plastic even when the extruder motor is not turning. To overcome this your slicing software needs to 'retract' the print medium during head movement when not printing. The retraction creates negative pressure within the hot end heating chamber which effectively sucks the print medium back up through the nozzle, stopping it from oozing.
Calibration Object: oozebane-test.stl
The calibration object prints two towers about 30 mm apart. The head must move between each of the towers at each layer. If your printer is not set correctly then you will see many fine filaments (or strings) between the two towers. You can eliminate these filaments by eliminating ooze.
Symptoms
Instructions
This is to try to control ooze and calibrate it to be useful.
Start by setting the Early Shutdown distance to 0 and Slowdown Startup Steps to 1.
Print the piece and measure the length of stringers where the extruder shut off and the line is thick before becoming a thin whisker. Take that length and put it into early shutdown distance.
Play with Early Startup Distance Constant until the place where the extruder arrives at the other tower is nice and smooth, so that there isn't any empty space where plastic should be, but there isn't excess plastic extruded.
References: http://reprap.org/wiki/Sfact#Q:____What_happened_to_the_old_retraction_settings.3F__What_the_hell_is_oozerate.3F
Overhangs
Objective: eliminate droop from overhangs.
Calibration Object: BridgeTestPart.stl
Instructions
If the calibration object droops, you likely need to decrease "Bridge Flowrate over Operating Flowrate." Or increase "Bridge Feedrate over Operating Feedrate."
X & Y scaling aka steps/mm calculations
tl;dr
  • (current steps per mm) * (expected distance movement) / (actual measured distance). E. g:
 (41.8*100)/94.94=~44.02780703602275121129
Then repeat:
 (44.0278*100)/99.95=~44.04982491245622811406
Until you get your desired steps per mm.
(Do note that there is a setting in configuration.h that enable thess EEPROM functions.)
 M501 (show current settings (steps per mm etc)
 M92 X44.04982491245622811406 (change steps per mm to your calculated value, useful for any axis; X,Y,Z and E for Extruder)
 M500 (save your new settings)
To be defined.
Scaling goes into the STEPS_PER_MM of the firmware, track offset goes into the G-code compiler (Skeinforge etc.).
OK, here we get a bit stuck. While the theory section below nicely shows how to calculate the optimum track offset, Skeinforge has no configuration option to adjust this value.
An excerpt from a chat between Greg Frost and Traumflug, on 2011/22/06:
[14:30] <GregFrost_> I calibrated the extruded length and then set feed=flow and pw/t and iw/t to 1.5 and immediately got nice looking prints. However, and here is the kicker, the objects are all slightly too big because my single wall box has an actual w/t of 2.1
[14:31] <GregFrost_> I can fix this with p flow but then i get thin preimeters and they dont alway bond well to each other (but objects are the right size).
[14:31] <GregFrost_> I would like normal flow on the perim but a wider w/t but if i do that it adjusts all of the flows up and I get far too much plastic.
[14:32] <GregFrost_> what I really need is a way to change the distance inside the objest that the perimeter is traced without changing the flow rates.
[14:37] <Traumflug> To be honest, I never used Skeinforge, this adjustable track offset is an assumption.
[14:38] <GregFrost_> Traumflug: it would be a good setting, i agree.
[14:38] <GregFrost_> Traumflug: I think the only way to achieve a track offset is to adjust the perimiter w/t ratio.
[14:38] <Traumflug> So, Skeinforge doesn't compensate for track width?
[14:38] <GregFrost_> Traumflug: it does. but it uses the perimiter witdth/t and infill w.t settings
[14:39] <GregFrost_> Traumflug: then it uses the layer height
[14:39] <GregFrost_> Traumflug: and useing those it works out the track offset.
[14:39] <Traumflug> ok, good to know.
[14:39] <GregFrost_> Traumflug: but the kicker is, changing perimeter w/t also adjusts the flow rate
[14:40] <GregFrost_> Traumflug: so theoretically when you choose a new w/t, it puts out enuf plastic to fill the width.
[14:40] <Traumflug> Yes, theoretically
[14:41] <GregFrost_> Traumflug: but on the perimiter if you use the same volumetric flow as the infill, it bulges past the desired width because there is no containing line.
[14:42] <GregFrost_> but the one setting that allows you to compensate for that adjusts the flow on all other lines (both infill and permiiters)
[14:42] <Traumflug> IMHO, changing the plastic flow to compensate for size errors isn't a good way.
[14:43] <GregFrost_> Traumflug: I agree completely.
[14:43] <Traumflug> Each time you change the flow, a lot of minor parameters change as well, so a prediction is very difficult.
[14:43] <GregFrost_> I want to change the track offset.
Theory and Maths
By Markus "Traumflug" Hitter.
X and Y Axis
Both horizontal axes can be calibrated with two values: track offset and overall scaling. To find out how this is done, let's have a look at a part specially designed to find out those values:
It's a frame, similar to the one you use to put pictures up onto the wall. The essential part here is, it has long and short distances to measure on the same part. We need to measure both, to distinguish between track offset and scaling.
To the right of the drawing, a few tracks laid down by the extruder are sketched in. It shows how the track offset lets the extruder move closer to the inside of the part, so the outer side of the track just ends where the part should end as well.
All the sizes are overlaid by scaling, which is sort of a "gear ratio" between measurement units and stepper motor steps.
Calibration Object
OpenSCAD
// X-Y Calibration object
// See http://reprap.org/wiki/Calibration#Theory_and_Maths
difference() {
	cube([100,100,3], true);
	cube([80,80,3.1], true);
STL file
File:XYCalibration.stl
Basic Equation
With that knowledge, we can sum up what the extruder moves to get the size T = 10 mm exactly 10 mm wide:
<math>\begin{align}
\mbox{movement} = ( \mbox{intended size} - 2 * \mbox{track offset} ) * \mbox{scaling} \\ \end{align}</math>
This holds true for measurements of any size, i.e. also for the 100 mm size of our calibration frame:
<math>\begin{align}
M_{10} & = ( 10\,\mbox{mm} - 2 * TF ) * S \\ M_{100} & = ( 100\,\mbox{mm} - 2 * TF ) * S \\ \end{align}</math>
You see? Two unknowns and two equations, so the set is solvable.
Extending to Erroneous Movements
Now, the whole point of this writing is, the extruder movement doesn't match what we need to get accurately sized parts. So we have not only a movement, but also a movement error.
The reason for the movement error is, according to the basic equation, erroneous track offset and/or erroneous scaling.
Get these two into the basic equation, result to the left, reason to the right:
<math>\begin{align}
& \mbox{movement} * \mbox{movement error} = \\ & ( \mbox{intended size} - 2 * \mbox{track offset} * \mbox{track offset error} * \mbox{scaling} * \mbox{scaling error} \\ \end{align}</math>
Again, this holds true for both our measurements:
<math>\begin{align}
M_{10} * E_{M10} & = ( 10\,\mbox{mm} - 2 * TF * E_{TF} ) * S * E_S \\ M_{100} * E_{M100} & = ( 100\,\mbox{mm} - 2 * TF * E_{TF} ) * S * E_S \\ \end{align}</math>
... to be continued ... about a formula to get scaling and track offset from measuring these 10 mm and 100 mm ...
Z Axis
On the Z axis, there is no track offset compensation, so calibration is reduced to scaling of part height. Build any part of 50 mm height, let it cool down, measure it. Then adjust your STEPS_PER_MM in your firmware's config.h to reduce the difference between intended and received part.
As most RepRaps use a threaded rod on the Z axis, the theoretical value should match reality pretty close. However, there's also material shrink as the plastics is printed at a higher temperature than room temperature.
Further reading
References
Old Version of this Page
put here as the new part is still incomplete --Traumflug 22:55, 21 June 2011 (UTC)
Is this part of commissioning? Is this part of Builders/Config/Config Axes?
To calibrate, you will need the following: a Rep(st)rap, a slide caliper, and printing material (ABS, PLA, HDPE, etc).
You will also need this object file to print out.
  1. Setup and load your printing material.
  2. Print the calibration object.
  3. Allow the object to cool.
  4. Use the slide caliper to measure each edge and the diagonals.
  5. Make a note of each measurement and this will allow you to determine where a problem is IF there is a problem.
With the above measurements, you should be able to determine any alignment issues. The sides should measure withing .5mm of 40mm.
if it is off consistently, then it is probably a firmware issue.
Most inconsistent discrepancies are a sign of backlash (i.e. slop or play in your mechanical system). Make sure the grub screws on the pulleys are tight; make sure the belts are tensioned so that when you turn the stepper by hand, it immediately produces a movement in the axis; make sure all the bearings turn smoothly, and that the carriages only move along their intended axis. with all of that double checked, try printing your test piece again, and pay very close attention while it is printing. If your stepper motors make strange noises occasionally, it might be that they are skipping steps because they don't have enough torque. Try turning up the trim pot for that axis.
If all this fails, the best place to go to figure out how to fix your issue, once you've identified it, is either to ask someone in the forums, or on IRC, if you prefer. Then come back here and make this page better, or complain to the forum users.
Once you get a simple cube printed adequately, you might consider trying a more difficult object such as the bearing clip 01 for more fine-tuning.
