Prusa Mendel/it
Release status: funzionante
Description | Prusa Mendel Versione 2 è un semplice remizMendel.
License | |
Author | |
Contributors | |
Based-on | |
Categories | |
CAD Models | |
External Link |
Introduzione
La prusa Mendel versione 2 è un aggiornamento della Prusa Mendel (iteration 1), che era stata rilasciata nel novembre 2011.
Migliorie
The following is a list of the main improvements made on the original Prusa
- More parts are made to be push-fit
- The carriages accommodate bushings and linear bearings
- Nut traps were added to parts that were attached with M3 screws (e.g. endstop holders etc.)
- The second bed plate was removed (The PCB heatbed is the second plate)
- The belts were changed to T2.5 belts - it is recommended to buy professional belt pulleys
- Most M4 screws were changed to M3s
- A printed plastic belt guide was designed to replace the large M8x30 fender washers
- The belt clamp was redesigned
Development
The development of the Prusa Mendel is hosted on github: http://github.com/prusajr/PrusaMendel.
History
- Iteration 2 announcement
- This page by Gary Hodgson shows the differenced between the original Prusa and Iteration 2
Printed Parts
The [Github repository] for the iteration 2 has all the STL files you need in order to make the printer. Run "generate-metric.bat" (or one of the batch files for the linear bearings) and it'll generate all the STLs needed. You will need OpenSCAD installed and it will need to be in your path.
The following is a list of what needs to be printed:
Parts for Wade's extruder are also included with the iteration 2 STLs:
Quantity | STL file | Picture |
1 | wade.stl | |
1 | wade-big.stl | |
1 | wade-small.stl |
Parti non stampate
Derivata da parts list by Kliment
Quantità | Descrizione | Commenti |
Elementi di fissaggio | ||
100 | M8 dado | Si trovano facilmente in box da 100, quelli in più sono sempre utili. Abbastanza anche per i Wade's extruder |
100 | M8 rondella | Si trovano facilmente in box da 100, quelli in più sono sempre utili. Abbastanza anche per i Wade's extruder |
50 | M3×20 bullone | Abbastanza anche per il Wade's extruder |
50 | M3 dado | Abbastanza anche per il Wade's extruder |
50 | M3 rondella | Abbastanza anche per il Wade's extruder |
6 | M3x10 bullone | |
2 | M3x8 grano | |
1 | M8x50 grano | |
Cuscinetti | ||
10 | LM8UU (Asia) o LME8UU (US, Europe) cuscinetti lineari OR 8mmx25mm bronzine |
Se utilizzi i cuscinetti lineari non risparimiare, quelli economici potrebbero danneggiare le guide. |
3 | 608 "roller skate" cuscinetti | "6082RS" con guarnizione, "608ZZ" con schermatura. Di nuovo, non lesinare. |
Tutte i pezzi di barra filettata possono essere ricavate da 6 barre M8 da 1 metro | ||
6 | 370mm barra filettata M8 | tre per lato |
4 | 294mm barra filettata M8 | Fronte/retro. Va bene anche da 300mm. |
3 | 440mm barra filettata M8 | Alto/basso. Va bene anche da 450mm. |
2 | 210mm barra filettata M8 | Vite per l'asse Z. Va bene anche da 300mm. |
6 | 405mm barra liscia M8 | |
Cinghie | ||
1 | 840mm cinghia dentata GT2 | Può anche essere T2.5. Assicurati di prendere anche la puleggia giusta. Si può usare anche una T5 ma non è consigliato. |
1 | 900mm cinghia dentata GT2 | Può anche essere T2.5. Assicurati di prendere anche la puleggia giusta. Si può usare anche una T5 ma non è consigliato. |
2 | puleggia 16 denti per la cinghia GT2 | Può essere da 12 denti, ma 16 sono consigliati per ridurre il gioco. Il diametro del foro dovrebbe essere 5mm. |
Se si usa il Wade's extruder incluso tra gli STL:
Quantita | Descrizione | Commenti |
4 | M8 rondelle | Inclusi nel conto sopra |
2 | M8 dado | Inclusi nel conto sopra |
6 | M3 dado | Inclusi nel conto sopra |
3 | M3x10 bullone | |
3 | M3x40 bullone | |
1 | M3x8 grano | |
1 | M8x20 grano | |
1 | M8 hobbed bolt | |
Cuscinetti | ||
3 | 608 "roller skate" cuscinetti | "6082RS" con guarnizione, "608ZZ" con schermatura. |
Electronics
Stepper Motors
La Prusa versione 2 utilizza 5 motori passo passo NEMA17 includendo l' estrusore. Se si utilizza il Wade's extruder, il motore dell' estrusore ha bisogno di una coppia minima di 40Ncm (0.4Nm). Uteriori informazioni sulla pagina Stepper Motor.
Controller Electronics
There are many controllers available to use for the Prusa iteration 2. Choosing the best one for your printer is up to you. It's probably best to head over to Comparison_of_Electronics and choose the best one for you. The most popular tend to be RAMPS or Sanguinololu.
