Wood3d
Revision as of 17:59, 22 December 2014 by Traumflug (talk | contribs)
//identifies pages under construction. remove when the page is relatively stable.
WOOD3D
Release status: concept
An easy fabricable printer on small cnc's
CC-BY-NC-SA
Deltabot
This printer is a redesigned one. The main aspect why i redesigned it is, that you can machine it on your small home cnc router.
The motors and the electronics are mounted on the top, because of heat dissipation and better access for maintenance. The six segments of the top and bottom assembly are all identical. The spool is mounted on top. Access is granted at all sides of the printer. Easy height change. Closed loop belts for better mounting, but also open belts are usable. A row of holes in the spool holder for diverse spooldiameter. Simple adjusting of the endstops. hollow carbon fibre bars. Motormount is just with zip ties and a screwed wooden u-block, for fast motorexchange An own developed effector. No vertikal extrusion profiles needed. The big effector should enable paste extruders and is more stable. The electronics can be mounted on top or under the top plate.
Machined Parts
Costs
I bought all parts on "ebay.de". The most time i bought one part more for replacement, so it became a little bit more costlier.
Parts bought:
Qty. Part Ebayseller Price (incl. shipping)
1 Sainsmart Mega2560 R3+ 5xA4988 + Ramps 1.4 profit_vanity 50.00 €
2 D=5 mm, L=1000mm carbon rods (not hollow) c-composites 15.50 €
13 M5 angle joint, DIN71802 www_stern-cnc_de 20.30 €
20 12mm LM12UU Linear Bearing itechcool 22.15 €
1 Preassembled hotend MK-V with ptfe tube etang_uk 32.11 €
5 Nema17, 1.7A, 17HS4417 actmotor2012 40.00 €
Set 3x GT2 pulleys & 5 meter timing belt ooznest 28.13 €
4 D12x1,5-L=1450mm stainless steel tube from rundumedelstahl_de 34.42 €
1 80W Meanwell laptop powersupply cp-led 32,45 €
SUM - 275.06 €
Videos
<videoflash type="youtube">5RUjISis6-M</videoflash>
technical details
Electronics Ramps1.4 common microswitch heatebed: no (pla recommended) extruder: bowden geared hotend: MK-V
Mechanics 12mm hardenend rod 700mm long - 6x GT2 belt and suitable pulleys pneufit push in fittings for bowden extruder PTFE Tube D6 - carbon fibre hollow tubes Ball joints - 12x Nema17 motor
