Wood-D Extruder Drive
Description | Just another wooden bowden extruder for 3D-Delta-Printer (Open Source Project)
License | GPL v3
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | CorelDraw / PDF
External Link |
Wood-D - Just another wooden 3D-Delta-Printer (Open Source Project)
Wood-D Extruder Drive is a simple filament bowden extruder based on LASER-cutted plywood.
Design Objectives
Specifications
Principle | Bowden Extruder like Wade's Geared Extruder | |
Construction | LASER cutted 4mm plywood (1 piece a 102 x 295 mm) | |
Filament | 1,75 mm | |
Dimension case | 100 x 60 x 32(+Gears) mm | |
Drive | NEMA 17 Stepper motors |
Features
Based on the LASER cutted constructive parts you get a very high precision.
The plywood parts/puzzle are hold together with key and slots and a little bit of glue. Through the box design with cross bracing the stiffness is very high.
All non plywood parts are standard industrial parts you can buy in online shops and eBay. (only drive shafts have to be sawed)
Necessary tools: LASER cutter (visit a FabLab/Hackerspace in your area), hand saw for metal, screw drivers, gripper, cutter, soldering iron
Parts
Case
LASER cutted plywood or MDF
Drive
Hobbed Bold M8 x 60 (as in Wade's Geared Extruder)
Gears
Standard industial gears 72+24 module 0.8 OR gears from Wade's Geared Extruder
Motor
NEAM 17 stepper motor as usual in RepRap projects
BOM
# | Parts |
1 | Plywood 4 mm with min. 102 x 295 mm |
1 | Hobbed Bold M8 x 60 (as in Wade's Geared Extruder) |
1 | Plastic Gear 72 Tooth Module 0.8 |
(1) | Alternative: RepRap Gear big from Wade Extruder |
1 | Plastic Gear 24 Tooth Module 0.8 |
(1) | Alternative: RepRap Gear small from Wade Extruder |
2 | Ball Bearing with Flange F608ZZ |
1 | Ball Bearing 605ZZ |
1 | Steel Shaft 5 mm with Length 34 mm |
1 | Steel Shaft 5 mm with Length 17 mm |
2 | Pneumatic Bulkhead Connector for 4 mm Tube |
1 | PTFE (Teflon) Tube 4 mm Lenth about 100 mm |
2 | Threaded Rod M4 Length about 100 mm |
4 | Nuts M4 |
4 | Skrews M3 x 8 |
4 | Washer M3 |
2 | Wing Nuts M4 |
(2) | Alternative: Knurled Nuts M4 |
(2) | Alternative: Nuts M4 glued in wooden star knob |
2 | Spring 7 x ? X 35 (or similar) |
1 | NEMA 17 Stepper Motor |
Casein Glue | |
2 Component Glue (Epoxy) |
Downloads
Design and LASER cut files at GitHub repository github.com/jkDesignDE/Wood-D
Tutorial
Assembling tutorial as image sequence at wood-d.de/tutorial-wood-d-extruder-drive
Links
More infos about the Wood-D project on the blog page wood-d.de (German language)
