Wood-D
Release status: experimental
Description | Just another wooden 3D-Delta-Printer (Open Source Project)
License | GPL
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | CorelDraw / PDF
External Link |
Wood-D - Just another wooden 3D-Delta-Printer (Open Source Project)
Wood-D is a 3D-Delta-Printer based on LASER-cutted plywood. The joints are made of bearing balls and neodyn ring magnets.
Design Objectives
Specifications
Principle | Delta / Rostock | |
Construction | LASER cutted 4mm plywood (5 pieces a 400 x 300 mm) | |
Printing area | square 190 x 190 mm or circle 220 mm diameter |
fits PCB Heatbed. Heatbed shifted 15 mm in +Y direction |
Printing height | 225 mm | (at a linear system length of 650 mm) about linear system length minus 425 mm |
Dimension base box | 337 x 296 x 60 mm | |
Dimension top box | 337 x 296 x 20 mm | |
Dimension printer | 337 x 296 x 650 mm | depends on linear system length |
Joints | Magnetic (neodym ring magnets with bearing balls) | |
Drive | Stepper motors with timing belt GT2 or T2.5 |
Features
Based on the LASER cutted constructive parts you get a very high precision (nearly) without measuring and adjusting.
The plywood parts/puzzle are hold together with key and slots and a little bit of glue. Through the box design with cross bracing the stiffness is very high. The box design guarantees also a high angle precision.
Linear system rods are pressed in and the linear bearing are hold by a 2-componentt glue (epoxy).
Magnetic joints simplified the construction by giving a very high precision, less friction and zero backlash.
All non plywood parts are standard industrial parts you can buy in online shops and eBay. (only drive shafts have to be sawed)
Necessary tools: LASER cutter (visit a FabLab/Hackerspace in your area), hand saw for metal, screw drivers, inbus keys, gripper, cutter, soldering iron
Parts
Base and Top Box
Linear System
Timing Belt
Joints
Extruder Nozzle
A standard J Head Nozzle is used. See also RepRap Interface Standard RIS 1 for nozzle holder.
Extruder Drive
The drive case is also LASER cutted and is related to the Wade's Geared Extruder.
The details will be published in a seperate article.
Heated Bed
The base box is designed to hold a standard square PCB Heatbed (active area 180x180mm). Alternatively a disk with a diameter up to 300mm can be used (active area diameter 210mm).
Electronics
Any electronics compliant with RepRap Interface Standard RIS 1.
Used in Beta 1: Arduino Mega 2560 with RAMPS 1.4 shield and Marlin firmware
The electronic is mounted on a 'drawer' to easily adapt to any other design.
Downloads
After finishing the first beta phase the construction drawings and LASER cut files will go online. Please wait...
Current Status
Beta 1:
Part | Status | Comment |
Base and top box | ready | minor bugs to fix --> Beta 2 |
Linear system | ready and working | |
Joints | ready and working | Improvements in Beta 2 |
Timing belt | at work... | |
Electronics | at work... | |
Heated Bed | at work... | |
Extruder Drive | near ready |
Links
More infos on the blog page wood-d.de (German language)
