Wood-D
Revision as of 09:26, 17 April 2014 by JKDesign (talk | contribs) (Electronics)
Wood-D
Release status: experimental
Just another wooden 3D-Delta-Printer (Open Source Project)
GPL
CorelDraw / PDF
Wood-D - Just another wooden 3D-Delta-Printer (Open Source Project)
Wood-D is a 3D-Delta-Printer based on LASER-cutted plywood. The joints are made of bearing balls and neodyn ring magnets.
Design Objectives
Specifications
Principle Delta / Rostock
Construction LASER cutted plywood 4mm (400x300mm, 5 pieces)
Printing area 180x180mm or circle 210mm fits PCB Heatbed
Printing height 200mm (typical) depends on linear system lenght
Dimension base box 337x296x60mm
Dimension top box 337x296x20mm
Dimension printer 337x296x650mm depends on linear system lenght
Joints Magnetic
Drive Stepper motors with timing belt
Features
Based on the LASER cutted constructive parts you get a very high precision (nearly) without measuring and adjusting.
The plywood parts/puzzle are hold together with key and slots and a little bit of glue. Through the box design with cross bracing the stiffness is very high. The box design guarantees also a high angle precision.
Linear system rods are pressed in and the linear bearing are hold by a 2-componentt glue (epoxy).
All non plywood parts are standard industrial parts you can buy in online shops and eBay. (only drive shafts have to be sawed)
Necessary tools: LASER cutter (visit a FabLab/Hackerspace in your area), hand saw for metal, screw drivers, inbus keys, gripper, cutter, soldering iron
Parts
Base and Top Box
Linear System
Timing Belt
Joints
Extruder
Heated Bed
The base box is designed to hold a standard square PCB Heatbed. Alternatively a disk with a diameter up to 300mm can be used.
Electronics
Any electronics compliant with RepRap Interface Standard RIS 1.
Used in Beta 1: Arduino Mega 2560 with RAMPS 1.4 shield and Marlin firmware
The electronic is mounted on a 'drawer' to easily adapt to any other design.
Downloads
After the first beta phase the construction drawings and LASER cut files are going online. Please wait...
Current Status
Beta 1:
Part Status Comment
Base and top box ready minor bugs to fix
Linear system ready and working
Joints ready and working
Timing belt at work...
Links
More infos on the blog page wood-d.de (German language)
