Witbox Diamond
Revision as of 12:07, 19 November 2015 by RepRap.me (talk | contribs) (Hardware)
Witbox Diamond
bq Witbox Diamond
The intention of this page is to serve as a build guide for those who want to modify a bq Witbox for the triple extruder solution Diamond Hotend. A little warning: this procedure will probably void warranty on your printer so before proceeding be sure you know what you are doing.
Part list
Most of the parts listed here are the same as mentioned on the original Diamond Hotend page.
Witbox Diamond main parts
  • 1 x Diamond Nozzle 1.7 mm version
  • 1 x Witbox Diamond Cooling Shield (Diamond_cooler_shield_WITBOX.stl)
  • 1 x Witbox Diamond X-carriage (Diamond_cooler_shield_Hold_WITBOX.stl)
  • 3 x Diamond thermal insulation sheet
  • 1 x Thermal compound
  • 1 x Heater cartridge
  • 1 x Thermistor NTC 100k wired
  • 3 x E3D LiteV6 with bowden fittings
  • 1 x Axial fan (12 volt / 50 mm / at least 18 CFM)
  • 4 x Cable tie
  • 4 x M3 nut
  • 1 x M4 nut
  • 3 x M3x10 CSK
  • 4 x M3x20 CSK
  • 1 x M4x30 CSK
  • 2 x Pin header Male 2P 2.54 mm spacing (Molex KK or Dupont type)
  • 1 x Heat shrink
Bowden extruders
  • 3 x Bowden tube OD:4/ID:2/L:650 mm
  • 3 x MK9 extruder
  • 3 x MK9 extruder motor cable
  • 3 x MK9 extruder mount (MK9_bowden_laser_right.stl)
  • 3 x Bowden tube push fitting
  • 6 x M3x20 bolt
  • 1 x Lasercut extruder mount (T_mount.dxf)
  • 1 x Braided sleeve 20 cm
  • 1 x Cable tie mounting pad
  • 2 x Cable tie
  • 1 x Filament roll holder (Spool_holder_32mm.stl)
  • 1 x Filament roll holder (Spoleholder_T-Mount.stl)
Endstop
  • 1 x Z-endstop adapter (Z-endstop_holder.stl)
  • 2 x M3 nut
  • 2 x M3x6 bolt
Electronics
  • 1 x Stepper Expander X1
  • 2 x Stepsticks
  • 4 x Adhesive PCB spacer (RS: 220-787)
  • 10 x Cable tie (estimated pcs.)
  • 2 x Wire from PSU to Easy Expander
  • 1 x 2x5P IDC cable from Ramps AUX-2 to Easy Expander
Assembling
Electronics
  • Mount the Stepper Expander X1 between the RAMPS and the PSU using the adhesive PCB spacers
  • Connect The Stepper Expander to the RAMPS AUX-2 using the 2x5P IDC cable
  • Add power wiring from PSU to the power input terminals on the Stepper Expander
  • While observing the direction insert one stepstick on the vacant position on the RAMPS board and the other stepstick into the Stepper Expander. (The trimpot on a standard A4988 driver should be closest to the power terminals on the Stepper Expander)
  • Mark the extruder motor cables respectively "A", "B" and "C" in both ends
  • Feed the cables through the back right corner panel
  • Tie all wirings in the electronics compartment so that no wire are blacking the airflow from the cooling fans onto the stepper drivers.
Hardware
  • Dismount the original bq Heatcore extruder
  • Dismount the x-carriage (release belt tension by loosening the hex bolts holding the pulley on the left of the x-axis)
  • Optional: remove the original extruder motor cable. If you carefully release the wires from the black female 4p Dupont plug connected to the RAMPS board (use the tip of an exacto knife) and cut the cable ties along the cable you will be able to pull out the wires from the x-carriage end one at a time. Newer versions of Witbox uses wire chains which can be opened which makes this process easier.
  • Cut the axial fan wires to about 10 cm length, strip the ends and solder a 2 pin male header onto the ends, remember to add heatshrink before soldering
  • Print out the new x-carriage part and glue the M3 and M4 nuts into the respective slots
Diamond Witbox carriage 1.JPG Diamond Witbox carriage 2.JPG Diamond Witbox carriage 3.JPG Diamond Witbox carriage 4.JPG Diamond Witbox carriage 5.JPG
  • Mount the new x-carriage and retighten the bolts at the pulley
Diamond Witbox carriage 6.JPG Diamond Witbox carriage 7.JPG Diamond Witbox carriage 8.JPG Diamond Witbox carriage 9.JPG Diamond Witbox carriage 10.JPG
  • Assemble and mount the Diamond Cooling shield (follow the steps on Diamond Hotend). Reuse the radial blower fan from the original Heatcore extruder.
Diamond Witbox top 1.JPG Diamond Witbox top 2.JPG Diamond Witbox top 3.JPG Diamond Witbox top 4.JPG Diamond Witbox top 5.JPG Diamond Witbox top 6.JPG Diamond Witbox top 7.JPG Diamond Witbox top 8.JPG Diamond Witbox top 9.JPG Diamond Witbox top 10.JPG
  • Install the Z-endstop adapter using two M3 nuts and two M3x8 countersunk bolts
Diamond Witbox endstop 1.JPG Diamond Witbox endstop 2.JPG Diamond Witbox endstop 3.JPG Diamond Witbox endstop 4.JPG
  • Remove and cut holes in the back cover according to the instructions on the "Diamond upgrade parts for Witbox" page (see link below)
  • Remount the back cover while feeding the motor cables through the corresponding hole
  • Add the braided sleeve onto the motor cables
  • Mount the lasercut T-shaped piece
  • Mount the adhesive tie pad
  • Tie the motor cables onto the tie pad using a cable tie
  • Assemble the bowden extruders (follow the steps on Diamond Hotend)
  • Mount the extruders and connect the motor cables
  • See section "Assembly" step "Attaching the bowden tubes" as well as "Bowden tube hints" section on the Diamond Hotend page
Firmware
  • bq Witbox firmware adapted for Diamond Hotend on GitHub (link is being contructed)
Printed and lasercut parts
