Witbox Diamond
Revision as of 10:44, 1 October 2015 by RepRap.me (talk | contribs) (Printed parts)
Witbox Diamond
Release status: page under construction
bq Witbox Diamond
unknown
This page is under construction: Estimated time of completion (state content useable): one week.
The intention of this page is to serve as a build guide for those who want to modify a bq Witbox for the triple extruder solution Diamond Hotend
Part list
Many of the parts listed here are the same as mentioned on the original Diamond Hotend page. Any variations from this however is mentioned in the list below
Witbox Diamond main parts
  • 1 x Diamond Nozzle for 1.7 mm filament
  • 1 x Witbox Diamond Cooling Shield (printed part)
  • 1 x Witbox Diamond X-carriage (printed part)
  • 3 x Thermal insulator sheet
  • 1 x Thermal compound
  • 1 x Heater cartridge
  • 1 x Thermistor NTC 100k wired
  • 3 x E3D LiteV6 with bowden fittings
  • 1 x Axial fan (12 volt / 50mm / 18 CFM)
  • 4 x Cable tie
  • 4 x M3 nut
  • 1 x M4 nut
  • 4 x M3x20 CSK til 50 mm axial fan
  • 3 x M3x10 CSK
  • 1 x M4x30 CSK
  • 2 x Male 2P 2.54 mm (pin header or Molex KK or Dupont)
  • 1 x Heat shrink
Bowden extruder kit
  • 3 x Bowden tube OD:4/ID:2/L:650 mm
  • 3 x MK9 extruder
  • 3 x extrudermount ”laser” version (printed part)
  • 3 x extruder motor cable
  • 1 x Lasercut extruder mount
  • 1 x Braided sleeve 20 cm
  • 1 x Cable tie mount
  • 2 x Cable tie
  • 1 x Filament roll holders kit (printed part: 2+1 parts)
Endstop
  • 1 x Z-endstop adapter (printed part)
  • 2 x M3 nut
  • 2 x M3x6 bolt
Electronics
  • 1 x Easy Expander X1
  • 2 x Stepsticks
  • 4 x Adhesive PCB spacer (RS: 220-787)
  • 10 x Cable tie (estimered number)
  • 2 x Wire from PSU to Easy Expander
  • 1 x 2x5P IDC cable from Ramps AUX-2 to Easy Expander
Assembling
-- under construction --
Printed parts
