Wilson Bill of materials
The parts list below is the default for Wilson, which uses all metric components and has a ~200mm x 200mm x 200mm build volume.
There is an OpenOffice spreedsheet in the github repository which will assist in generating a BOM for other build volumes.
Parts List
Item | Quantity | Length / Note |
2020 Extrusions | ||
Vertical frame piece (sides) | 2 | 370mm |
Horizontal frame piece (top and bottom) | 2 | 330mm |
M8 Smooth Rods | ||
X-Axis | 2 | 380mm |
Y-Axis | 2 | 380mm |
Z-Axis | 2 | 325mm |
Threaded Rods | ||
M5 threaded rod for Z axis | 2 | 300mm |
M10 threaded rod for Y axis | 2 | 405mm |
Belts & Pulleys | ||
Y axis GT2 timing belt (w=6mm) | 1 | 820mm |
X axis GT2 timing belt (w=6mm) | 1 | 930mm |
GT2 pulley | 2 | |
Nuts & Bolts | ||
M10 nuts and washers | 12 | |
M5 x 8mm machine screw | 36 | |
M5 hex nut | 2 | |
M5 t slot nut | 36 | |
M4 x 20mm machine screw | 6 | |
M4 hex nut | 6 | |
M3 x 8mm machine screw | 1 | |
M3 x 10mm machine screw | 11 | |
M3 x 14mm machine screw | 18 | |
M3 x 30mm machine screw | 7 | |
M3 x 60mm machine screw | 2 | 50mm ok if your springs are short enough |
M3 hex nut | 20? | |
M3 lock nut | 7 | |
M8 x 20mm smooth rod or grub screw | 1 | |
Printed Parts – Required | ||
X end idler | 1 | |
X end motor | 1 | |
X carriage | 1 | |
Y end idler | 1 | |
Y end motor | 1 | |
Z motor holder, left | 1 | |
Z motor holder, right | 1 | |
Z rod holder, left | 1 | |
Z rod holder, right | 1 | |
Z rear bracket | 2 | |
Frame brace 2 | ||
Idler bearing guide (pair) | 2 | |
Printed Parts – Recommended | ||
Electronics frame mount | 1 | |
Filament spool support | 1 | |
SMART display frame mount | 1 | |
Everything Else | ||
NEMA17 Stepper motor | 5 | |
MDF board (6mm thick) | 1 | 230mm by 230m |
MK2 Heat bed | 1 | |
Glass bed | 1 | 3mm borosilicate |
Controller (Mega/RAMPS, Rambo, etc | 1 | |
Endstop (limit) switch | 3 | |
LM8UU Linear bearing | 12 | |
608ZZ roller bearing | 4 | |
624 roller bearing | 2 | |
5mm to 5mm shaft couplers | 2 | Can also use 3/16" ID vinyl tubing |
40mm x 40mm x 10mm fan | 1 | |
80mm x 80mm fan | 1 | |
Miniature zip ties | 20 | |
Extruder idler springs | 2 | High tension |
Bed leveling springs | 4 | Lower tension |
Power Supply | 1 |
