WatBot
Revision as of 10:35, 2 November 2010 by Watanabe (talk | contribs) (Progress)
Example Development
Release status: unknown
documenting a generic tool/artpiece
This is 600 pixels wide, and on the left.
Your-File-Name SOLID MODEL ASSEMBLY These are CAD files for the Solid Model Assembly .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)
Your-File-Name CAD FILES FOR PARTS These are CAD files for each part. .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)
Your-File-Name EVEN MORE FILES These are are even more files. .xml.zip, .stl.zip --Example User 12:00, Today's Date 20xx (UTC)|-
Your-File-Name SOLID MODEL ASSEMBLY This is the final finished machine N/A --Example User 12:00, Tomorrow's Date, 20xx (UTC)
Please edit this and click the links to put in your own files! --Sebastien Bailard 08:34, 10 September 2010 (UTC)
Goals
1. Provide a way for me (an architecture master's student) to learn, and take with me, the *equipment* that is becoming essential to our practice-my school has a 6 axis Kuka robot, 4 laser cutters and a bunch of CNC mills/water-jets/etc, but for most of us, after graduation we work in offices/design practices without the budgets for these sorts of gear.
2. 3D printer: makes having a higher Z-axis useful
3. CNC router: MDF, plywood, aluminum, maybe zinc sheeting(no idea about how tough this is, just thinking of architectural materials) drilling holes in steel?
4. Modularity: swapping out plastic extruder for spindel for laser - have not tackled this but imaging some sort of steel sleeve with grooves and maybe a bottom shelf with a hole and a top that can be clamped on.
5. Build platform: constrained by equipment already purchased (see below)
Means
Although it can't self-replicate, hoping that this can be made through the cheap commoditization of the materials used (ie: cheapest ballscrews available sourced from Chinese ebayers) with the goal of decentralizing means of production.
Forum Posts
http://www.cnczone.com/forums/diy-cnc_router_table_machines/114483-router_3d_printer_1x0_7x0_3meter_modular_design.html
Progress
Software-side, looks like EMC will be necessary, as I don't know of any way to use 4 axis's(1 slaved X axis+XYZ) with the reprap software.
BoM:
3060, 6060 and 6090 misumi aluminum extrusions+brackets+screws/nuts shown in renders below
Chinese 2.2kw spindle
Hitachi 2.2kw VFD
x4 425oz-in Keling NEMA23
12.5A 48V Keling PSU
Gecko G540
x2 1100mm, x1 750mm, x1 350mm linearmotion2008 ballscrews/nuts + supported rail/bearing block/mount/couplings kit
