Volumetric Dimension settings
Overview
Skeinforge 40 introduced some changes based on the Volumetric 5D skeinforge plugin. With 40, skeinforge calculates how much plastic, by volume, is entering the top of the extruder per step, and therefore how much plastic is being pushed out the nozzle per step.
In other words, if 1 cm^3 enters the extruder, 1 cm^3 must exit the extruder.
(Some plastics like ABS don't appear to have a 1:1 relationship. There is ongoing research into why this is. 'Packing density' must be lowered for ABS)
The packing density could be a result of the melt density probably.. Have a look here: http://www.stelray.com/density_val.htm and http://www.natureworksllc.com/Technical-Resources/~/media/Technical_Resources/Properties_Documents/PropertiesDocument_Engineering-Properties_pdf.pdf (I dont have ABS for testing but I have inserted the ratio of molten density to regular density into FDPR and it looks good for the moment...(PLA))
So now we don't need to change feed/flow rate in order to get good prints. all we need to know is how much plastic is entering the extruder.
The biggest change that must be made is Merchants Discount Health Plan recalculating your E_steps_per_mm firmware setting. You need to know how many steps it takes to move the feedstock 1mm into the top of your extruder.
Basic Formula
Here's the basic formula:
micro steps per rev * gear ratio / ( pinch wheel diameter * pi)
- gear ratio: 39/11
- pinch wheel: 8mm hobbed bolt. probably between 7-5 mm
Accessible Wade's by GregFrost
- gear Ratio: 43/10
- gear ratio: 59/11
- pinch wheel: 7mm
- gear ratio: 43/13
- gear ratio: 31/11?
Base values for comparison
Please list your e_steps_per_mm below, so that other reprappers have a data point for comparison:
- Wades w/ .9 degree stepper x 8 microstepping: 722 steps/mm --Buback 15:58, 15 March 2011 (UTC)
- Mendel Parts mendel : 367.355 (actually this is exact the half of what gives correct dimensions in Repsnapper (E.g extrude 10 extrudes 5mm but in skeinforge you can set flowrate same as feedrate then..) Try both settings (367.355 and 734.710 and see..)
- Wades w/ 1.8 degree stepper x 2 microstepping, and 75/9 ratio gears: 79 steps/mm. More details. --Ketil 22 March 2011
- Wades w/ 1.8 degree stepper x 16 microstepping, 39/11 gear ratio, dremelled (16x) bolt: calculated value 462.996 steps per mm. Experimentally determined value with 4042D yellow PLA: 503.443 steps per mm ~~Lanthan 03 August 2011
- Gen3 Tech Zone Remix. Wades: 140 steps/mm (not perfect). Adrians: 166 steps/mm Greg's Hinged Accessible Extruder: 165.24 steps/mm --Nudel 12:10, 23 May 2011 (UTC)
