User:Lanthan
Revision as of 06:23, 15 August 2011 by Lanthan (talk | contribs) (10 mm microswitch holder)
Background
Lanthan & son & cat set out their journey about robotics in early 2009. The "new" manufacturing techniques exerted a significant appeal on them.
After much lurking in forums and wikis and a steady routine of scavenging in computer and printer parts dumps, they got hold of a benchtop-cnc-router-that-would-cut-a-RepStrap-that-wold-print-a-Reprap. In other therms, they took the winded, twisted long road that offered the most varied learning opportunities.
On the other hand, there weren't so many kits or printed parts available in early 2009-2010. So they decided to cut & adapt a Cupcake, having got interested by its neat plywood assembly techniques.
Early milestones:
  • Learning about Arduino ans stepper motor control
  • Building a primitive eggbot from discarded printer & computer parts
  • Building a cartesian plotter from discarded printer & scanner parts, sorting out a parallel port interface, and driving it with EMC
  • Operating a benchtop cnc router without having the neighbours going postal
Bootstrap generations
F0: Benchtop CNC router
Large benchtop router
"The poor man's laser cutter", actually a very capable solution dealing with pieces up to 550 x 360 mm with (usually) better than 0.05mm precision. Unlike the lasercutter, unwieldy for large production series, but perfect for anyone whishing to learn. The decision to get one evolved from the painstaking, but ultimately successful, hand-build of a Wimshurst machine.
  • Main shortcoming: noise. An incitation to cut a smaller one for PCBs.
  • Main advantage: you do exactly what you want.
F1: Pirated cupcake
As in many cases, the work advanced episodically, was put on hold for many months due to other contingencies, and offered some opportunities for some personal interpretations research. The build was completed in summer 2011. Build details, configuration hints and links have been added to the Pirated CupCake page (will proceed with some reorganization).
July 2011
First prints
While devoid of any stellar performance, and as much a musical instrument as a rapid prototyper, this has quickly turned into a reliable workhorse. Surprisingly little adjustments were needed.
Shortcomings: Like most designs around, Z axis is problematic. A complete Z rebuild with 3 x 12mm guides and LM12UU bearings is in the plans.
F2: Prusa's simplified mendel
By far this was the most intense and involved build construction-wise. Very promising. Needs patience, persistance and recursivity for fine adjustements.
Kitsellers heed: Since most kits already include lasercut parts, one could imagine at least two precision lasercut/routed pieces that get the rods in the exact positions quickly and without much fuss. From what I gather, the Orca's main attrait might be there: precision parts doubling as build guides.
Lanthan's first Prusa Mendel
Build notes and (re)design pieces
M2 holes spaced 10 mm. Direct mounting of common microswitches
On Thingiverse (including STL)
Files:
  • Openscad
  • (STL uploads currently fail on the Wiki)
X axis reinforcement: shaft collars
coming soon
Quick change magnetic X carriage
coming soon
Quick change magnetic base plates
coming soon
WHat's next?
An Orca? (where are the files?)
Lessons learned
Caveat inertial mass
Weight watchers!
These gears were both printed from exactly the same gcode, "all other things equal", at 25 mm/s. The one on the left shows obvious lost steps on the y axis. The only difference was the addition of an 10x110mm aluminium plate (pictured above) to have a full build platform. The additional swinging mass proved too much for the wimpy y-axis stepper.
Remedial action
  • Lowered speed (skeinforge: "speed" and "limit")
  • Slightly increased the y stepper current on the pololu driver.
  • Print small objects without the full surface platform
So far, so good. Noisier stepper, though.
Also, possibly, in the firmware: reduce acceleration.
Foreseen explorations
  • Heliostats and sun-tracking devices
  • Mini solar sinterer / oven ?
  • Applications of RepRap technology in biomedical/health contexts
  • Homegrown mini-mill for PCBs
  • Maybe importing new ideas in a stagnating professional realm
Getting in touch
lanthanid (at) gmail.com
Looking forward to meeting developers and fabbers around the Geneva (CH) Area
Acknowledgements
This has been a wonderful learning experience, and (at least for one us) a refreshing comeback to past interests and links.
As a full case of information gathering and learning endeavour catalyzed by a set of community-driven projets, we are deeply indebted to the experimental work of the many developers, testers, tinkerers and visionaries in the Reprap constellation: Thank you!
