User:JC Orozco
Revision as of 13:30, 8 July 2021 by JC Orozco (talk | contribs) (Added descriptions to the images)
Juan Carlos Orozco Arena. July 8, 2021
Idea dump series. Description of interesting ideas to allow them to be freely available and avoid being locked down by patents.
Robots and Cranes: Robots and cranes complement each other nicely. Robot precision and speed plus crane load capacity and reach (large working area). Many configurations are possible to take advantage of this complementary features of robots and cranes. I present here some examples: An hybrid robot plus crane to increase the end effector load capacity: 20210707 113001 RobotsCranes1.jpg
Overhead crane moving robots and using robots to move parts on a warehouse or industrial plant: 20210708 111725 RobotsCranes2.jpg
Robot mechanical play compensation using pull strings (rigid or flexible). Gearboxes with zero backlash are expensive. I propose here an alternative, a robot built with inexpensive gearmotors can achieve high precision if a force is applied using rigid or flexible strings to make its combined backlash to go to a fixed position. Top view, note the two gearmotors that pull the end effector on each side of the robot base. In this case a spring is used to control the tension that this strings pull the end effector to lock the gear play of the robot actuators into a fixed position. 20210707 113017 RobotPullstring1.jpg
