Template:Firmware Support
Revision as of 07:06, 24 May 2023 by Droftarts (talk | contribs) (Fix Druid firmware link)
Support Marlin RepRapFirmware Klipper Prusa Buddy Repetier Smoothie Druid MK4duo
grbl Sprinter BFB FiveD Machinekit Redeem Teacup Yaskawa MakerBot
How to use
Copy one of the examples below as a starting-point, paste it into the G-code wiki page above your G-code description, and edit as needed. You can put anything as a value, but certain values will be color-coded for easier reference. The following embed…
{{Firmware Support | marlin={{yes}} | reprapfirmware={{yes|3.4+}} | klipper={{yes}} | prusa={{yes}} | buddy={{yes}} | repetier={{partial}} | smoothie={{yes}} | druid={{automatic}} | mk4duo={{yes}} | grbl={{no}} | sprinter={{yes}} | bfb={{no}} | fived={{yes|1.23+}} | machinekit={{experimental}} | redeem={{yes}} | teacup={{???}} | yaskawa={{yes}} | makerbot={{no}} }}
…will produce this result:
Yes 3.4+ Yes Yes Yes Partial Yes Automatic Yes
No Yes No 1.23+ Experimental Yes ??? Yes No
Special Values
Value Description
??? Unknown if the firmware supports this G-code. Try to find out before posting. This is the default if a firmware is left out.
yes The G-code is fully supported by the firmware.
yes|1.23+ The G-code is supported by version 1.23 and above.
no The firmware does not support the G-code at all.
partial There is only partial support for the full G-code specification.
experimental The G-code is experimental and may change or be removed.
automatic The firmware handles this G-code automatically. (Unclear, so avoid this label.)
Examples
Unknown
{{Firmware Support | marlin={{???}} | reprapfirmware={{???}} | klipper={{???}} | prusa={{???}} | buddy={{???}} | repetier={{???}} | smoothie={{???}} | druid={{???}} | mk4duo={{???}} | makerbot={{???}} | grbl={{???}} | sprinter={{???}} | bfb={{???}} | fived={{???}} | machinekit={{???}} | | redeem={{???}} | teacup={{???}} | yaskawa={{???}} }}
- or simply -
{{Firmware Support}}
None
For completely new G-codes this is probably the best starting-point.
{{Firmware Support | marlin={{no}} | reprapfirmware={{no}} | klipper={{no}} | prusa={{no}} | buddy={{no}} | repetier={{no}} | smoothie={{no}} | druid={{no}} | mk4duo={{no}} | makerbot={{no}} | grbl={{no}} | sprinter={{no}} | bfb={{no}} | fived={{no}} | machinekit={{no}} | | redeem={{no}} | teacup={{no}} | yaskawa={{no}} }}
No No No No No No No No No
Marlin Derivatives
This may be an easier starting-point for Marlin derivatives that support similar G-codes.
{{Firmware Support | marlin={{yes}} | reprapfirmware={{???}} | klipper={{yes}} | prusa={{yes}} | buddy={{yes}} | repetier={{???}} | smoothie={{???}} | druid={{yes}} | mk4duo={{yes}} | makerbot={{???}} | grbl={{???}} | sprinter={{???}} | bfb={{???}} | fived={{???}} | machinekit={{???}} | | redeem={{???}} | teacup={{???}} | yaskawa={{???}} }}
- or simply -
{{Firmware Support | marlin={{yes}} | klipper={{yes}} | prusa={{yes}} | buddy={{yes}} | druid={{yes}} | mk4duo={{yes}} }}
Yes ??? Yes Yes Yes ??? ??? Yes Yes
Adding a Title
You can override the default title that appears on the left side ("Support") using title=Something Else. For example:
{{Firmware Support | title=M123<br>Support | marlin={{no}} | reprapfirmware={{no}} | klipper={{no}} | prusa={{no}} | buddy={{no}} | repetier={{no}} | smoothie={{no}} | druid={{no}} | mk4duo={{no}} | makerbot={{no}} | grbl={{no}} | sprinter={{no}} | bfb={{no}} | fived={{no}} | machinekit={{no}} | | redeem={{no}} | teacup={{no}} | yaskawa={{no}} }}
M123
Support
