Spontaneous polymerization resin blends
[PrintingMaterials Back to Printing Materials page]
Spontaneous Polymerization Resin Blends
There are many dual component polymers available in the market that illustrate this behavior. Most of them are epoxys and are excellent materials as well as versatile. Some dual polymer mixes are in a 1:1 proportion or similar and could be counted in the auto-initiated sub-category of polymers. Nevertheless, for our purposes, both cases have identical applications and usage parameters.
Resins, Oligomers, Monomers
Polyester Resins (Isophthalic, Vinyl Ester, Marine, General purpose, Casting Resin, Surfboard Resin, Gelcoat)
Epoxy Resins (Thin coat, thick coat...)
Catalysts Systems
Monomers, MEK-Peroxide hardener for polyesters
Benzoyl Peroxide hardner for polyesters
Fillers
[FillerMaterials Go to Fillers section]
Formulation Examples
Additives
Glossary of Terms and Definitions
Here you will find a short and basic explanation of terms used in all the sections above. If some term used above seems unclear to you, please post a message in the forum and I will see to add the term to this glossary.
[GlossaryOfTermsAndDefinitions Go to Glossary]
