Sanguinololu Wireless Adapter
Description | Release Version 1.0
License | unknown
Author | |
Contributors | |
Based-on | [[]]
Categories | |
CAD Models | Kicad
External Link |
Introduction
The Sanguinololu Wireless Adapter (SWA) allows full wireless communication with the Sanguinololu controller. It includes a bluetooth module (Roving Networks RN-41) as well as a microSD card reader.
Latest Updates
- The SWA has been successfully tested on revision 1.3a of the Sanguinololu, however it should function correctly on revisions 1.2 and above.
- Connecting the SWA to a Sanguinololu of revision 1.1 or below, may damage your SWA or your Sanguinololu.
The SWA uses RX1/TX1 on the Sanguinololu for serial communication. As of this writing, no known firmware supports the SWA 'out of box' without a little modification. Using Sprinter this is relatively easy to do if you are familiar with uploading the firmware. Firstly, find the following files:
- Sprinter.pde
- SdFatUtil.h
- SdFile.cpp
Then, with your favorite text editor replace each instance of 'Serial.' with 'Serial1.' in these three files. Finally, compile and upload to the Sanguinololu. After modification, the USB cable will not function during NORMAL communication with the Sanguinololu. Don't worry, the USB cable will still work with the bootloader when uploading new firmware so you can revert the code and re-establish NORMAL communication at any time.
D1 (Green LED): Slow blinking: Some kind of sleep mode on the RN-41. You will not be able to pair the device in this state. When this happens (and it will after about 30 seconds) you should press the reset button on the Sanguinololu to 'wake up' the RN-41. If the RN-41 is already paired and the LED is in this state, you shouldn't have a problem established a serial connection. Fast blinking: RN-41 is willing to be paired. Constantly on: Serial connection established.
D2 (Yellow LED): Serial connection established.
D3 (Red LED): Power applied / microSD card inserted
A note on D3: The D3 was meant to be a SD card detect indicator. However, the terminals for this function on the SD card socket have proven to be too difficult to solder by hand. Luckily, it can also serve as a 3.3V power indicator if pad 11 is soldered to pad 10 on the SD socket footprint (this is the usual outcome anyway if you're not precise enough). The power indicator function has proven to be more useful when testing the SWA.
Connecting...
Make sure the Sanguinololu is without power. Properly connect the SWA. Turn on power. D1 (Green LED) should immediately start fast blinking.
Ubuntu: In a terminal type something like: hcitool scan You should see the RN-41 onboard the SWA listed as Firefly-XXXX. Immediately preceding it will be the RN-41's address. Copy this address. It will in a format like 00:06:66:07:DA:76
Now type something like: sudo rfcomm connect rfcomm0 <RN-41 address> 1 Make sure to replace <RN-41 address> with the number above.
If a serial connection is successfully made you should see something like the following in your terminal: Connected /dev/rfcomm0 to <RN-41 address> on channel 1 Press CTRL-C for hangup You should see that D1 (Green LED) and D2 (Yellow LED) are now constantly on. You will now be able to connect to the Sanguinololu with the host software of your choice. Be sure to specify the connection port as /dev/rfcomm0 or whatever you used above.
If you would like to use a GUI for pairing and establishing a serial connection the default GUI is not recommended. Instead, use Blueman Device Manager. If you don't have it. Type the following in a terminal sudo apt-get install blueman You may need to start it manually the first time after installing. If you can't find it, restart. It should appear on your panel (as a second bluetooth icon). After you have it up and running, click 'Search' 'Firefly-XXXX' should be listed as a device Right click on 'Firefly-XXXX' and select 'Pair' Type '1234' in the input dialog that appears then 'OK' Right click again and select 'Setup...' Select 'Serial Port' and click 'Forward' You should see a message in the top right of your screen. It's importat that you notice this and the port location (which is typically '/dev/rfcomm0') You should see that D1 (Green LED) and D2 (Yellow LED) are now constantly on. You will now be able to connect to the Sanguinololu with the host software of your choice. Be sure to specify the connection port as /dev/rfcomm0 or whatever you saw above. Note, it may be buggy if you lose the connection or disconnect and try to reconnect immediately afterwards.
Windows 7:
A successful connection has been made with the SWA, but has not been tested further.
