Rosalind/ua
Revision as of 07:14, 22 March 2019 by Edlab (talk | contribs)
Rosalind Documentation
Rosalind
Стан випуску: Working
Опис A fully parametric GPL printer designed in OpenSCAD
Ліцензія GPL v3
Автор qwazix
Співавтори
На основі mendel
Категорії ні
CAD моделі [1]
Посилання на зовнішній ресурс [2]
Rosalind
A CoreXY parametric 3D printer fully designed in OpenSCAD. You can clone the repository, change the parameters in general-values-n2.scad and print your very own rosalind. Step by step printing and assembly instructions coming soon.
An early photo of Rosalind #1
This wiki can be easily converted to MediaWiki for publication in the Reprap wiki. See convert to MediaWiki for more info.
The bill of materials lists all the parts you will need to purchase to build your own Rosalind.
Basic Printing Instructions
  1. Clone the git repository.
  2. Open general-values-n2.scad and edit as you wish. The comments should help you choose the right values.
  3. Save as general-values.scad overwriting the existing file.
  4. Open rosalind.scad and view your build. Does it look right? Not all possible values have been tested so you have to take a good look here and make sure everything looks alright. If unsure just go with the defaults.
  5. Open the part files one by one and uncomment the print() statement. This is not very straightforward yet but it will be fixed in the next release.
  6. Press F6 and then export to .stl
  7. Print the stl files
Basic Assembly Instructions
Coming soon. For the time being use rosalind.scad as a guide if you’d like to print your own rosalind.
WIP: Build Your Own Rosalind
So, you want to build your very own Rosalind. Great. Let’s get started.
First clone the repository or Download the zip with all the files.
You will need OpenSCAD in order to customize and then print the parts needed for your build. Go download a copy for your system.
Open variants/general-values-n2.scad with your favorite editor. You can customize most of these values but apart from the defaults and the ones in general-values-n1.scad no other values have been tested yet. In the future as more configurations get tested we will include more sample files, or even a separate repository of configurations.
For this tutorial we will assume you are building an unmodified Rosalind-N2.
Let’s begin.
The frame
In order to build the frame you will need 4 things. Aluminium extrusion profiles (or any other kind of beams you can easily screw on), angle fasteners, M5 bolts and M5 t-slot nuts.
T-slot frame, M5 bolts, T-slot nut
The t-slot nut pictured are generally more convenient as they can easily be inserted and removed in the t-slot, and they secure by rotation. However the variant with ball and spring has the advantage of staying put after unscrewing the bolt so it might be preferable for some parts. If you can, procure enough of both.
If you open rosalind.scad in OpenSCAD and look at the console (If you cannot see the console make sure View > Hide Console is unchecked) you will see some information about the printer being output, including the two lines:
ECHO: "Vertical T-Slot profiles (4 pieces): (mm)", 400
ECHO: "Horizontal T-Slot profiles (8 pieces): (mm)", 360
This informs us of the lengths of aluminium profile required to build our rosalind configuration. We will also need some angles to fasten them together and we can find off-the-shelf ones but since this is a RepRap and one of the goals is to be as much printable as possible we will print the angles ourselves.
Open angle-fasteners.scad in OpenSCAD, press F6 to render and then export to STL. Load the STL file into your slicer, your printer, or order a print from a commercial print service. You will need 26 angles and the file has 30 so you will have a few extra if anything goes wrong.
As long as you have printed the angles you will have to assemble a cube like this. Gather your aluminium profiles and set the 4 longest ones aside. You will use them for the Z axis (the upright frame elements, or “columns”) of your Rosalind. Slide the t-slot nut as shown.
Frame Corner Assembly
If you have the self locking slot nuts pictured in the photo above along the bolts and aluminium profile then the easiest way to assemble is to screw the nut to the bolt before inserting into the frame, like below.
Frame Corner Assembly (self locking nuts)
Continue with the rest of the corners until you have a cube.
Frame Assembly
Frame Assembly
The base (bottom)
You can use a sheet of acrylic for the base of the printer but I have found that a piece of moderately thick plywood (~10mm) is a safer choice. It’s easier to cut it yourself, it doesn’t crack and you can later screw on additional equipment easily.
Open base.stl in OpenSCAD, render it (press F6) and export it in .svg or .dxf. You can now print the drawing in a (2D) printer or a plotter and use it as a guide to cut your piece of plywood and drill holes in the appropriate positions.
Once you have the plywood ready, make sure you sand the edges so that they will be smooth to the touch as the base will be accessible from the outside. Clean it well and make sure that no wood splinters remain.
The next step is to tap threads into the central hole of the vertical t-slot profiles. This can be done using a hand-tap or a power-drill.
You can watch this video to see how you can do that. If you do not have a tap or don’t want to bother, you can avoid this step by using sheet metal screws such as this which will thread the aluminium upon screwing on.
Sheet-metal screws
Sheet-metal screws
Assembly instructions for base plywood and feet
The y-axis
Now it is time to start fastening the first functional parts on the frame we just completed. Open y-axis-clamps.scad, and make sure print_all_y_axis_clamps(); is not commented out, and that everything else under /* Print or Preview*/ is. If you are printing the default Rosalind you need not pay attention to anything else.
Depending on the values you have chosen, the parts might need support structures to print successfully. You can do one of the following: (a) enable supports on your slicer, (b) change support to true or (c) change two_parts to true. Option (b) prints the part with an extra leg which you will be required to cut by hand and option (c) divides the clamp into two parts which you will need to screw together using bolts.
Once you have printed the parts, you will have to attach them to the frame like this:
Y-axis clamp assembly instructions
Don’t bother too much about the exact Z position. We can adjust later.
There are three kinds of y-axis clamps. Make sure you install them at their correct positions. Take note of the shelf where the timing belt idlers will later be mounted and the endstop position (Red arrows).
Positions of variants of the y-axis clamp. The clamp nearest to the viewer has neither endstop nor idlers
In the default rosalind-n2 v1.1 configuration the clamp that will hold the endstop does not have a visible difference. This is not always the case depending on the values you selected in general-values.
