Repemaker
Revision as of 19:54, 1 October 2013 by JgemezCW (talk | contribs)
Repemaker
Reprap 3d printer.
Creative commons, atribution, no comercial, no derivs.
[[File:]]
Repemaker 3d printer
The repemaker is an experimental 3D printer from FFF system ( Fuse Filament Fabrication ) . The main characteristics search accuracy and compactness . What distinguishes the other printers Repemaker Reprap operation is where x and y axes themselves serving to slide in one direction serve both to transmit the movement to the opposite axis . The structure of wood ( MDF ) closed gives it great stability and easy transport and placement. Both the electronics , with the power supply are under the structure so that the printer occupies approximately the same volume of a laser multifunction . The linear rodamientsos are IGUS brand for X and Y which makes operating the printer emits just noise (unlike ball bearings using other printers) brings space for a couple of buttons on the front for commissioning and lighting (optional ) . Like all Reprap printers ( replicants ) parts can be done in just a printer ... so it is possible to " replicate " .
Features:
Dimensions approx 40 cm wide by 40 long and 45 high. Great compactness.
Ease of transport. Holding the printer by two side openings can be transported very easily . Hot bed . It allows the use not only of PLA but also other materials that need a heat source to paste the first layers Z Axis engine and 4 double smooth bars . It does not work like other printers cantilever sliding around in the Z axis X and Y axis smooth rod triple . The car is totally enclosed thus avoiding vibrations. MDF wood structure . Affordable and high dimensional stability . High stability and low vibration due Electronic power supply and within the structure . All cables are left in the structure . Bowden System , which allows higher speeds to move large masses not in the car. High precision of movement. Control Panel on the front (optional ) Double extruder (optional, two colors or a color and supports composite ) Video of the new car Very low noise bearings by IGUS Ease of assembly structure with few parts and without calibration once assembled .
