RepRap Firmware FAQ
RepRap Firmware (RRF) FAQ
- 1 Can I modify speed and extrusion coefficients and temperatures during a print? Yes
- 2 Can I reconfigure my printer ‘on the fly’? Yes
- 3 Can I print from SD card? Yes
- 4 Can I run RRF with an USB front-end like Pronterface or Repetier-host? Yes
- 5 Can I create my own macros? Yes
- 6 Can I control the printer through WiFi devices? Yes
- 7 Do I need to recompile firmware for configuration? No
- 8 Can I use standard printer LCD panel? No
- 9 Is there an automatic calibration for Cartesian printer? Yes
- 10 Does web interface work on Duet if the board is only powered by USB? Yes
- 11 Can I use external 5V power supply instead of the on-board supply? Yes
- 12 Can I install a filament presence sensor? Yes
- 13 Do I need an USB connection for firmware update? No
- 14 Can I run a Chamber heater from the Extruder heater output? Yes
- 15 If I have a problem with a driver, can I install an external driver? Yes
- 16 Can I use fans with other voltage than main board voltage? Yes
- 17 Can I run a mixing hotend like the diamond? Yes
- 18 Can I run a laser cutter with RRF? Yes
- 19 Can I use an RC servos for automation ? No
- 20 Can I use absolute extruder coordinate? Yes
- 21 Can I use inductive or capacitive calibration sensor? Yes
- 22 Are the input pins capable to handle 5 Volt? No
- 23 Is there auto-calibration for heat loop PID? Not yet
- 24 Shall I have forced cooling on the board? It depends
- 25 Can I have a printer without end-stops sensors? Yes
- 26 What kind of end-stops do I need?
- 27 Can I add more extruders? Yes
- 28 Is there software movement limit? Yes
- 29 Is it possible to install two separated end-stops on each axis? No
- 30 Can RRF run a SCARA printer? No
- 31 Can RRF run a rotary delta (Clavel type) like the Firepick? No
- Yes, there is an interactive console, you may even modify parameters during a print, at your own risks
- Yes, and this is what is done by most users, as Ethernet file transfer is very fast. Lost connection from the PC don’t stop the print, but you lost control if you don’t have a local panel or another controller (which may be a smartphone if you have WiFi on your network).
- Yes, but you shall configure your front-end program for USB hardwired handshaking
- Yes, with any web browser if you have a WiFi connection on your Network or set-up a low cost WiFi bridge on the printer
- No, new issues of firmware are always delivered pre-compiled. Configuration by text files.
- No, only PanelDue work with RRF firmware
- Yes, but it is different from the delta calibration and is limited to five probe points
- Yes, but if you have accessories connected on the 5V like the PanelDue, the 5V consumption shall not exceed your USB port capability. This power supply method is recommended during commissioning as first power on. The Ethernet cable shall be installed and network configured.
- Yes, there are selectors on board
- Yes, based on simple switch (no filament movement detection yet)
- No, except for the first firmware update (first step of commissioning), as boards are delivered with old firmware
- Yes, using a relay (SSR)
- Yes, if you have no expansion board, as drivers can be remapped on the expansion connector. Note: Buy good stepper cables to avoid risks of disconnection while powered, which is the main way to burn a driver.
- Yes, See the schematic here: Duet_Wiring#5V_controlled_fan
- Yes, see this forum thread and result
- No
- Yes, but this is not recommended
- Yes, but you shall add some components to protect your inputs from over-voltage. Never exceed 3.3V on input pins, at risk of board destruction.
- NO. 5V on input pins may kill the board. Caution shall be used.
- Not yet, but it is planned
- It depends mostly of the current of your steppers. Natural cooling is sufficient for steppers at 1A, but board shall be installed to allow easy air flow (best is vertical position)
- Yes, as digital potentiometers allow current reduction via G-code and you can stall steppers on mechanical stops. However, this is not very precise and for Z axis this need to be coupled with automatic calibration.
- Dry switches or powered sensors, provided they work in 3.3V. Pin order is different from Ramps, with center pin in 3.3V
- Yes For the Duet 0.6 and 0.8.5 there is 4 extruders board expansion from original designer (T3P3), simple 4 extruders extension from independent supplier and some stock of 2 extruders shields from RepRapPro.
- Yes. You can define maximum travel where head will not be allowed to go. This volume will be a cylinder for a delta printer and a cube for others.
- No, and it is not needed, the printer knowing its own dimensions. Though dry switches can be installed in series.
- No
- No
In addition to site licence GFDL1.2, this page is also released under license CC BY-SA 4.0
