RepRapSpecifications
Revision as of 16:18, 13 August 2006 by SebastienBailard (talk) (version migrated from twiki)
RepRap Specifications
These figures are very, very preliminary.
Cabinet Dimensions
Height 50 cm
Width 50 cm
Depth 50 cm
Weight 10 kg
This figures include the Environmental Cabinet. The Environmental Cabinet moderates the temperature of the extruded object, and prevents foreign matter such as dust and cat hair, from contaminating the feedstock filament and nozzle. It could be as simple as a carboard box with filter and fan attached.
Build Volume
Height (Z) 30 cm
Width (X) 30 cm
Depth (Y) 30 cm
Nozzle Characteristics
Extruded Filament Thickness 0.5 mm
Nozzle Spatial Precision 0.1mm
Deposition rate (fine) 10 cm^3/minute
Deposition rate (bulk) 20 cm^3/minute
Positioning Apparatus Characteristics
Accuracy
Repeatability
Resolution
For definitions of the above see: http://www.me.mtu.edu/~microweb/chap2/ch2-1.htm
Thermoplastic Characteristics
Filament Feedstock Thickness 3 mm
Density  ?
Shore Hardness A 94
Shore Hardness B 50
Yield Stress 16 MPa
Note: This data describes the characteristics of a solid block of material. An extruded object is a mass of self-adhered filament, and may have voids, and may be more flexible or sheer more easily, in the same way that a coiled mass of wire is different from an ingot of metal.
Replication Rate
Thermoplastic Parts Weight 5 kg
Thermoplastic Parts Volume "
Replication Time Volume /depostion rate
Cartridge
Thermoplastic Cartridge Weight, Full 5.5 kg
Thermoplastic Cartridge Weight, Empty 0.5 kg
Power Requirements
The RepRap uses single rail 12V. 1 standard 200W+ ATX Computer Power Supply should suffice.
Computer Hardware Requirements
USB 1.0 Port
Computer Software Requirements
Java Version 1.4
To install java, go to http://www.java.com and download it or follow your operating-system specific instructions for installing it, as according to the documentation that came with your machine. See InstallingJava.
The RepRap software DriverSoftware is java-based, and will run on any modern personal computer. See DriverSoftware for driver installation instructions. -- Main.SebastienBailard - 13 Aug 2006
