RepRapPro Mendel heatbed assembly
Revision as of 11:52, 17 June 2012 by Adrianbowyer (talk | contribs) (Step 2: Wiring)
Introduction | Frame assembly | Y axis assembly | X axis assembly | Z axis assembly | Heated bed assembly | Extruder drive assembly | Hot end assembly | Power supply | Wiring | Commissioning | Printing | Multi‑colour/multi‑materials | Colour Printing - Slic3r | Colour Printing - RepRapPro Slicer | Maintenance | Troubleshooting | Improvements
A notice about these instructions!
Since 1st April 2013, the RepRapPro Mendel has been superseded by the RepRapPro Tricolour and Mono Mendel.
If you are building the new machine, use the official, and most up to date, instructions on the RepRapPro wiki here
Goal
By the end of this step your RepRap machine should look like this:
And in addition it will have an aluminium plate on top of the red circuit board.
Tools
You will need the following tools:
  1. M3 Allen key
  2. Cross-head screwdriver
  3. Multimeter
  4. Soldering iron and solder
Parts
Lasercut insulator 1
PCB bed heater 1
Glass printing plate 1
Foldback spring clips 4
M3 x 40mm screws 3
30mm springs 3
M3 nuts 13
M3 washers 16
10K glass bead thermistor 1
twin ribbon wire 1.1m
20A wire 1.1m
3mm LED 1
1k resistor 1
Aluminium heat spreader 1
M3 x 10mm countersunk screws 4
1mm dia copper wire 35mm
Heatshrink 30mm
Cable tie 1
Get the twin ribbon wires by stripping them off the 10-way ribbon cable supplied with the kit. If that ribbon cable has a colored stripe down one side, strip the two wires furthest from it. If it has no coloured stripe, strip from one side, then put the remaining 8-way ribbon flat on the bench and run a felt-tipped marker down one side:
This will make the wires in it easier to identify later. Set the 8-way ribbon aside for later use.
Step 1: Main assembly
Use the countersunk screws together with four nuts and washers to sandwich the heated bed PCB between the aluminium plate and the MDF insulator.
The zig-zag heater track on the PCB faces up towards the aluminium plate.
Make sure that the PCB solder terminals, the rectangular cut in the insulator, and the notch out of the aluminium plate all line up.
Take care not to break the lasercut springs in the corner of the insulator. (These are to allow for differential expansion.)
Here is a view of the underside. Use a pencil to mark + and - as shown. This will help with the wiring.
Step 2: Wiring
Bend the LED's legs as shown above. The longer leg (+) is underneath in this picture.
Solder the LED and the resistor as shown. You may find this easier if you prop the bed up on something clear of the bench so the wires can poke through.
The long leg of the LED goes to the side you marked +. In the picture you are looking at the bottom of the LED.
Solder the wires on both sides of the PCB. Trim the wires flush with the top of the PCB using side cutters.
Solder the twin ribbon wires onto the thermistor as shown above. Stagger the connections. Use the insulation stripped from the short connection to insulate the thermistor wire.
Tin the ends of the wires, then tin the wires on the thermistor, then sweat them together.
Insulate the joins with a length of heatshrink.
Strip the insulation from the other ends of the wires and use your meter to check the resistance. It should be about 10K ohms, though the exact value will depend on room temperature.
Bend the thermistor at right angles and tape it to the bed. Make sure it goes through the hole in the insulator and the hole in the PCB and touches the aluminium plate. If you like you can add a little heatsink grease to improve the thermal contact between the thermistor and the plate.
Pack the hole in the insulator with something fluffy: cotton wool or a bit of scrunched tissue both work well. Put tape over the hole. (The LED and resistor are the wrong way round in this picture - ignore them.)
Lead the wires to the edge of the bed where the two cable-grip holes are and tape them down. Use the holes on the side you marked -. Note the strain relief loop; don't run the wires straight.
Cut the single-strand copper wire in half. Bare the ends of the high current wire.
Push the copper into the middle of the wire strands, twist the strands to hold it, and solder the join. Put heatshrink on.
The picture shows one wire complete, the other ready to be soldered.
Solder the wires to the bed. Solder them both sides for strength and trim any excess from the aluminium side.
The wire with the black stripe goes to the side you marked -.
Put the glass plate on the aluminium and make sure that none of the wires stick out and foul it.
Use the cable tie to attach the high-current wires and the thermistor wires. Again, note that the high-current wires are not pulled taught. They have a strain relief loop. Put the cable tie through the holes on the side you marked +.
Pull the cable tie good and tight, and then clip the excess off it.
Step 3: Attach to the machine
Put the three long screws through the mounting holes with washers under their heads.
Put the springs on. The sequence from the screw head goes:
  1. Screw head
  2. Washer
  3. MDF insulator
  4. Washer
  5. Spring
  6. Washer
  7. Nut
  8. Nut
Use the last three nuts and washers to mount the bed on the machine.
If you want a superb machine (of course you do), before you mount the bed put a little superglue on the heads of the screws that hold down the toothed-belt clamps, cut two rectangles of aluminium foil about 20 mm x 30 mm and glue these onto the screw heads. These will act as a heat shield, and will prevent the printed clamps from getting warm.
Pull the nuts into their recesses under the printed parts on the Y carriage with a shorter screw with a washer under its head if needs be.
Adjust the screws to get the bed roughly level (measure the heights of the corners above the Y rods with digital callipers).
Tighten the nuts against the Y carriage to secure the bed.
Adjust the nuts above that set the spring compression so that the bed is held firmly against the screw heads, but can be pushed down with a finger.
Next step
The extruder drive
