RDB-TS-001-G-DIY
Revision as of 19:23, 7 May 2013 by NoobMan (talk | contribs) (Low side MOSFET Switches (vdc))
RDB RDB Build Documentation
RDB Reprap Development Board
Release status: experimental
Generic development board extension for 3D printing
Features Overview
This board is meant to take GPIO wires from the development board and provides the basic functions, that is switches (for hotends heating), thermistors (for temperature reading) and also endstops headers in two different configurations. As the logic voltage regulator is continuously adjustable, the board can work at a logic voltage of 5v or 3.3v or else. Board features:
-Voltage regulators: 2 (adjustable)
-Endstop Headers: 3+3
-Thermistors: 5
-Switches: 4x Hexfets(Vdc) + 1x Triac(Vac)
-Pcb size: ~ 10x9.4 cm
-optimized for DIY: single sided, no bridges, clearance 0.5mm, min track width 1.5mm, format and traces "bulky" enough so board could be made with any technique.
What this is not
  • This board is NOT a shield, connections require physical wiring between this and development board.
  • This does not contain any mcu.
  • This does not contain stepper drivers or anything stepper related. Because this requires distinct wires from development board, then step/dir/en are the same and go directly from development board to stepper driver boards and their motors. Hence steppers are to be kept separate from this board.
  • For other more "integrated" electronics see List_of_electronics
Power input
  • simple reverse polarity protection with high current diode and fuse
  • transient supressor
  • max input voltage depends on the regulators used
Voltage regulators
  • two continuously adjustable voltage regulators, in paralel configuration
  • multiturn adjustment pots
  • voltage regulators are 3 terminal type, TO-220 package, e.g.: LM317 LM1086, and similar pinout compatibility (TO220 with middle pin Vout)
  • first regulator purposed for development board supply and mosfet driving
  • second regulator provides logic voltage for the board and should be set accordingly: 5v or 3.3v or else, perhaps 1,8v logic but its a bit of a stretch. Ideally this should be set to match closely the development board's logic voltage.
Thermistors
  • ADC pins come from development board, are broken into 5 headers to be further connected to thermistors physical location.
Endstops
  • 3 endstop headers with hardware pullups and protection diodes
These endstops need to sink the current for normal operation and disconnect the line when triggered.
  • 3 endstop headers with hardware pullups and optoisolators
These need to provide current to the optos internal led to keep it lit up for normal operation, and disconnect when triggered. The headers with optoisolators are meant to be somewhat universal and support almost any configuration. For this reason headers have their own separate power connector (v+ and gnd). And the loop is kept separate and not tied to either side, so it could have a switch either place, and short the other. Finally the 5th pin is sort of utility pin and it figures as pulldown by default, but because its conveniently positioned in the middle of power lines, a resistor can be placed as either pullup or pulldown positions. These 5 lines should cover most configuration requirements. Visual indicator leds are in same loop with isolators internal leds, so these lit up always in normal operation. Only when endstop is triggered the visual indicators also turn off. With default values these should work with traditional reprap 5v optoendstops, directly, without other components (without optos boards). For alternate configurations and other sensors the current limiting resistors need to be adjusted according to voltage used and current required.
Switches
All switching components are to-220 package, 3 terminal, with heatsink space for standard to220 radiators and are placed in line for alternative common backplate type sink with 2 points fixture. Mosfets switches use their own connection paths and are not connected to the board's input ground.
  • 2 mosfets with fuse sockets, presumed for high current (bed and hotend)
  • 2 mosfets without fuses
Truth table: feature active when high
logic level Behavior
high conducting
low non-conducting
The fets leds are kind of counter-intuitive, because are tied in paralel to the mosfet. So leds are off when fet is conducting. The leds only light up when there is a load connected and if the mosfet is not conducting. The fets have some optional micro-snubbers, mostly because needed to leave space for standard to-220 radiator "hat" type. Normally snubbers need to be tweaked and then tested in order to make them effective, but on the other hand the default values should provide "something" which cant hurt, to say so. The fets are driven by two small to-92 devices which to the voltage level provided by first regulator (presumably adjusted about 7-12V for development board supply). This should be useful in case of 3.3v logic level, for better gate driving for power mosfet. But otherwise for 5v level and logic mosfets, this part of circuitry can be omitted.
Triac Switch (vac)
  • 1 (optional) zero-crossing optocoupler commanding a triac for on-off control of one Vac line
Triac is optional, for ac switching. It can be used to switch some spindle motor, or if the bed is supplied with ac. This is on-off control only (not proportional, does not change the firing angle). Mains voltages are dangerous, so use this with care and wisdom. Ensure minimal distances and good isolation of the board where the mains circuit is located. Ensure no shorts can possibly occur anywhere: shorting 230vac to 5vdc isnt pretty. Be warned.
Truth table: connected to transistor's base / fet gate, feature active high
high conducting
low non-conducting
Triac by default uses an zero crossing optocoupler, for better switching, so its max switching speed depends on the AC frequency. Triac should be snubberless type (not needing snubber). Unlike fets leds, triac led is normal, e.g. led is on when triac is on and vice-versa.
The logic level command signal can be tied in two ways in the 2 wire connector. If connected through the to92 transistor, this will conduct the line to ground, so triac will be active when the the logic signal is high. If connected to the drive line directly, it needs to sink the current into the uC GPIO itself, so the triac will be active when the logic signal is low. So, second mode of operation is possible, may be not wise, and is also inverted of the first (feature enabled when low and disabled when high).
Source files
Schematic: download as PDF file
Kicad source files: download Kicad files - version 001beta - last updated: 24 Apr 2013
