Prusa i3 Buyers Guide
Full Kits
All these vendors have an assortment of kits and/or parts specific to the Prusa i3. The list is non-exhaustive and contains both, good and bad quality RepRap-oriented vendors.
To find a shop in your country, click on this little box near "Loc." and you'll find all of them in one spot.
Vendor | Loc. |
Developers of ... | Reviews and notes |
3dborg.com | NE, USA | ✓ | Borg's i3 Mini | mini i3's only, available fully assembled | |||
Charlie's 3D Technologies | BE | ✓ | ✓ | ✓ | aluminum single frame kits | ||
DIY Tech Shop | US | ✓ | ✓ | ✓ | ✓ | <I3x,I3xl,Little Brass Hotend> | |
eMotion Tech | France | ✓ | ✓ | ✓ | ✓ | aluminum single frame kits | |
MakerFarm.com | ✓ | ✓ | ✓ | MakerFarm laser cut frame | laser cut wood kits - 6" and 8" heated bed | ||
NorcalReprap.com | US | ✓ | ✓ | ✓ | ✓ | aluminum & laser cut frame kits | |
reprapsource In Beta | DE | ✓ | ✓ | ✓ | ✓ | box style frames | |
ReprapUniverse.com | NL | ✓ | ✓ | ✓ | ✓ | frame kits, fully assembled kits | |
Twelvepro.com | ✓ | mini i3's, frame kits |
Various kits and plastic parts are also available on eBay. Search for "Prusa i3" for a list. If buying from eBay, make certain to ask the seller which version of the i3 they are for building. There's three flavors: single_plate, box_frame, and mini. single_plate is the aluminum frame (lasercut wood/acrylic alternative available), box_frame is the one where you screw sections of wood together to make a heavy duty box frame, and mini is the 4" x 4" x 4" build volume variant that has an aluminum frame (lasercut wood/acrylic alternative available).
Workshops
Another option is to attend a build workshop. You can get a group together and ask someone to put on a workshop for you, or you can find a group putting on a build workshop, such as your local Hacker Space.
Here is a list of i3 build workshops:
- reprapworkshop.cz (Czech Republic, aluminium frame)
Sourcing Your Own Parts
Sourcing your own parts allows you to personalize your i3 to fit your needs and budget. The total can range from ~$334 to ~$1,290. If you select the best sourcing options, but find good deals on them, you can expect to pay ~$555.
There are a number of design styles and options for different Prusa i3 parts. This can quickly become confusing, especially for the first time builder. There are only a few resources for building a Prusa, (both box frame and single plate style) and nothing to help would-be adopters across the first big hurdle: what parts to order. An unofficial BOM (Bill Of Materials) was put together in November 2012, but there doesn’t seem to be one for the Beta release.
In order to make things easier, I have tried to bring all the relevant info scattered throughout the internet into one place. If you know of a better alternative part, or have a better or cheaper source for a part, please add it to the list.
Frame
The first design choice is between the boxed style frame and the single sheet (also called single plate) style frame. The box style is somewhat more rigid, but also slightly more complex to build and less aesthetically appealing. Single sheet frame is simple, but uses expensive laser cut aluminum parts. (more info here) Note that the two frames require different length rods. For info on the rods, or on using different length rods to increase/decrease your build volume, look here.
NOTE: I’ve converted several dimensions from metric to standard for ease of sourcing within the US. Can someone confirm that the rounding errors are small enough to be negligible? I don’t know what the tolerances are on these parts.
Part | Sourcing Options | Source | Cost |
6x 450x100x12mm pieces of wood | cut from three boards, each 48x4x1/2"* | Home Depot, Lowe’s, etc. | $15-30, depending on grade |
cut from one sheet 24x48x1/2" plywood | Do it Best, Home Depot, Lowe’s, Wickes, etc. | $11-35, depending on grade | |
475x100x15mm piece of wood (to mount spool on top of machine?) | cut from one 48x4x1" board* | Do it Best, Home Depot, Lowe’s, etc. | $1-15, depending on grade |
cut from one sheet 24x48x19/32" plywood | Home Depot, Lowe’s, etc. | $22 | |
230x230x12mm wooden bed | cut from a 10x1" thick board* | Home Depot, Lowe’s, etc. | $4-48, depending on grade and size of board |
cut from one sheet 24x48x1/2" plywood | Do it Best, Home Depot, Lowe’s, Wickes, etc. | $0-35, depending on whether you chose the 1/2” plywood above | |
~24x??? 3.5x20mm wood screws | #6 x 3/4” wood screws | Do it Best, Home Depot, Lowe’s, Wickes, etc. | $2-7, depending on quantity and type |
*Actual dimensions of lumber are smaller than nominal due to shrinkage during drying. Some given dimensions are actual, and some are nominal. Wood also warps as humidity changes. To minimize this, select pieces with uniform edge-grain without knots. Oak and poplar are good choices, and remember to seal the wood to minimize moisture absorption. ([http://www.iment.com/maida/favs/house/useful/woodselecting.htm more info)
Single Sheet Frame Parts (6mm thick) | Kit with laser cut aluminum parts | Charlie’s 3D Technologies, eBay, NorCal-Reprap, RepRap Source | $90-130 |
Kit with laser cut plywood parts | eBay, TwelvePro | $25-30 | |
cut from ¼” Plywood and use gussets for strength | Do it Best, Home Depot, Lowe’s, Wickes, etc. | $10-48, depending on grade and thickness |
Rods
You will need rods to match your frame. Precision ground rods are highly recommended, since bent or uneven rods will directly influence print quality. Bearings may not fit along sections of rod that are too large, and will rattle on smaller sections. Keep in mind that, while precision rod is formulated and tempered for rigidity, rod from welding supply stores is intended to be bent into shape. It is easily marred, and bends easily under any load. For this reason, you may want to buy from a supplier that cuts the rods to length before shipment, since longer rods are more likely to bend during shipping. If sourcing from a local hardware or welding supply store, you may want to roll the rod on the ground or sight down the length to ensure straightness.
Most threaded rod will suffice, provided that it is relatively straight. Precision threaded rod (and precision nuts!) will reduce backlash and improve print precision. For the best quality, any of several varieties of leadscrews can be used (sources listed here), although they require matching nuts. This requires that you modify your printed parts, so they are not listed below. For vertical threaded rods, gravity keeps the nut threads pressed downward against the threads on the rod, and so backlash is less of an issue. A uniform number of threads per inch is still necessary for layer thickness control. M10, M8, and M5 threads have a pitch of 1.5, 1.25, and 0.8 mm per rotation respectively. Although these ISO metric threads are the default, finer threads can also be sourced.
The specific rod diameter used is not crucial, allowing either metric or imperial sizes (although this will create 0.06mm slop in the bearings). Non-precision rods have diameter variations of around ±0.030mm, but too large is worse than too small since the linear bearings won’t fit. Precision bearings are ±0.009 or below. It may also be desirable to use larger rods for i3’s that may have higher loading (many heavy extruders, or a mill and drill head). Different sizes of threaded rods can be used, since they only connect to the i3 via nuts, which can easily be changed slightly. More substantial size changes may require different couplers to connect to the motors. If different smooth rods are used, then appropriately sized bearings must be sourced.
8mm smooth rods (x axis: 2x 470mm, 1x 20mm; Y: 2x 370mm; Z: 2x 405mm) | Precision ground (cut from two 600mm and 2 800mm Precision Drive Shafts) | see vendor list | $85-220, depending on metal |
Non-precision rods (BUY THEM AS STREIGHT AS POSSIBLE and cut from three 36x5/16" rods if necessary) | eBay*, Home Depot, Lowes, Tractor Supply, Wickes, etc | $11-15, depending on metal | |
2x 400+mm M10 threaded rod (Y axis) | cut from 1m long M10 or 3/8” threaded rod | Do it Best, Home Depot, Lowe’s, McMaster, Tractor Supply, Wickes, etc | $2-25, depending on metal |
4x 205+mm M8 threaded rods (Y axis) | cut from 1m long M8 or 5/16” threaded rod | Do it Best, Home Depot, Lowe’s, McMaster, Tractor Supply, Wickes, etc | $3-13, depending on metal |
2x ~370mm M5 threaded rod (Z axis) | cut from 1m long M5, 3/16”, or ¼” threaded rod | Do it Best, Home Depot, Lowe’s, McMaster, Tractor Supply, Wickes, etc | $2-9, depending on metal |
Pre-cut kits with some or all of the above | i3 specific rods | Charlie’s 3d Technologies, eBay, MakeMendel, RepRapSource | $42 |
*There are some precision rods on eBay, but most of them are not. If the seller doesn’t have the tolerances listed, then chances are they aren’t high precision.
8mm smooth rods (x axis: 2x 370mm, 1x 20mm; Y: 2x 350mm; Z: 2x 320mm) | Precision ground (cut from two 600mm and 2 800mm Precision Drive Shafts) | see vendor list | $85-220, depending on metal |
2x 380mm M10 threaded rods (Y axis) | cut from 1m long M10 or 3/8” threaded rod | Do it Best, Home Depot, Lowe’s, McMaster, Tractor Supply, Wickes, etc | $2-25, depending on metal |
4x 205mm M8 threaded rods (Y axis) | cut from 1m long M8 or 5/16” threaded rod | Do it Best, Home Depot, Lowe’s, McMaster, Tractor Supply, Wickes, etc | $3-13, depending on metal |
2x 300+mm M5 threaded rods (Z axis) | cut from 1m long M5, 3/16”, or ¼” threaded rod | Do it Best, Home Depot, Lowe’s, McMaster, Tractor Supply, Wickes, etc | $2-9, depending on metal |
Kit with all of the above | i3 specific rods | Charlie’s 3d Technologies, eBay, TwelvePro** | $49-65, depending on metal |
**TwelvePro rods are intended for their modified frame, not normal i3s.
Basic 3D Printed Parts
Most kits of 3D printed parts will include an extruder of some type, but for simplicity’s sake I will deal with the extruder options separately. There are several types of belts used in RepRap machines, and the GT2 is used for the i3 design. Images of all the printed parts can be found here, and the latest source files are on GitHub. Also, apparently the x carriage is different between the box frame style and the single plate style. This means that an extruder which fits the box style frame may not fit the single plate version, and vice versa. (Is there a discrepancy with other parts to?) Make sure your printed parts match your frame style and extruder type before you buy.
3D Printed parts (for GT2 Belts and Greg's Wades extruder with Jhead) | Select based on desired extruder and pulleys/belts. ABS softens at a higher temperature, so is good in proximity to motors. PLA is more wear resistant, and so makes longer lasting gears. | eBay, or i3 printed parts vendors | $40-79 |
Belts and Pulleys
Timing belts (T2.5, T5, etc.) are highly discouraged in favor of GT2 or GT3 belts. Make sure that the belt holder matches the belt you choose. (The belt holder is one of the 3D printed parts above.)
2x 6mm wide GT2 belt pieces (760? And 900? mm long) 1 for x axis, 1 for y | cut from 2m circumference belt | eBay, or an appropriate vendor | $10-12 |
2x (not 4x?) 6mm wide GT2 pulleys (should fit 5mm rod) (fox x and y) | pulleys with 12 teeth (more is ok) are recommended for minimum positioning error | eBay, or an appropriate vendor | $14-16 |
package with all of the above | cut from 2m circumference belt | eBay, or an appropriate vendor | $18 |
Extruder Cold End
There are a number of extruder cold ends available, but not all will fit the i3 unmodified. To be safe, make sure the extruder you decide on is compatible with your version of the i3 (the single plate and the box frame versions have different carriages). When purchasing extruder parts, be sure that they work with the filament diameter you intend to use (aka, 1.75 or 3mm).
There are no files for an extruder among the official STL files (either box or single plate), so there is no official extruder. There is a version of Greg’s Wade Extruder, as well as a Bowden extruder (both dual and quad versions!), which have been modified to fit the single plate version of the i3. Greg’s Wade Extruder seems to be most common, although the compact/dual extruders appear to work to some degree (Seems to be still under development, as of 2013-8-15). (Note: A compact extruder is essentially half of a dual-extruder, with a few small design changes.)
Direct drive extruders push filament through the hot end quickly, and can retract it just as quickly to reduce oozing. Higher gearing ratios give more precision (good for smaller nozzle apertures and layer heights) at the cost of slower speed. The lowered motor torque allows smaller, lighter motors.
Printed parts (this was likely included in the Basic 3D Printed Parts section above) | eBay | $15 | |
Hobbed bolt, M8 x 60mm (make sure the bolt is hobbed at the desired location. If using 1.75mm filament, be sure the cuts are shallow enough to catch) | Precut hobbes | eBay | $6 |
Local hardware store (cut hobbes yourself, if you have the equipment) | Ace Hardware, Do it Best, Home Depot, Lowe’s, Wickes, etc. | $1 | |
3x 608zz bearings | for bulk discount, purchase with 608 bearings from the hardware section below | eBay, or any of these suppliers | $7-15 |
Smooth 8mmx20mm bar (axle for idler) | cut from the excess left over from making the rods. | eBay*, Home Depot, Lowes, Tractor Supply, Wickes, etc | $0-2 |
4x M4 springs (optional) | Some people prefer rubber matt or lock washers | eBay | $5 |
Other miscellaneous hardware | assorted nuts and bolts, in accordance with which design you choose | Local hardware store | ~$5 (depending on your design) |
Full kit with all of the above | eBay | $48 |
Note: Nuts, bolts, etc may vary slightly depending on exact extruder design. If you can’t find what hardware to get, go with the above plus a couple M3 screws 30-40mm long some M4 screws 20mm long, and nuts/bolts/washers to fit (including locking nuts). Get a bunch of washers for the M8 bolt in case you need to use them as spacers.
Raldrich Geared Stepper Extruder
This extruder that was listed in an early i3 Bill of Materials. Is it the official i3 extruder?
Compact Dual Extruder (experimental)
Both the Compact and the Dual Compact Extruder require 42BYG48HJ50 geared motors instead of standard NEMA 17 motors. The motors used in development were sourced from 2engineers, which has since changed their design. A PG35L might be adapted, and could be sourced from NMB Minebea. Two sets of drive-gears, 608 bearings, bar axles, springs, and assorted nuts and bolts are also required for the extruder. Details surrounding the compact dual extruder are scarce. Several people appear to have “working” hardware, but so far the software is still under development.
Applications include dissolvable support material, printed electronics (using off the shelf conductive filament), faster high-detail printing, composite materials (living hinges, etc.), as well as multi-color prints. Full color printers would be better served by dyeing the filament or by using a mixer extruder or RichRap extruder.
I3ext by SGraber
Machined drive gear and geared drive from stepper to filament driver
Extruder Hot End
You also have a couple options when it comes to the extruder hot end. The J-head extruder was designed so that it could be machined all in one piece. This makes it cheaper and more reliable, but means you need a J-head for each nozzle diameter you want to print with. (They do have exchangeable PTFE liners for different filament diameters.) Having a separate nozzle, heater block, barrel, and PTFE sleeve allows the user to mix and match filament size and nozzle diameters on a whim.
J-Head only | eBay | $40 | |
Electronics (thermistor, heater resistor, and optional heat resistant wire) | eBay | $5 | |
PTFE liner (1.75 or 3mm ID) | hard to find in 1.75mm | eBay, or [vendor list] | $7 |
Assembled J-Head containing all of the above | (0.3, 0.35, 0.4, and 0.5mm nozzles only) | eBay | $38 |
Nozzle | 0.2, 0.25, 0.35, 0.4, 0.5mm options | eBay | $5 |
Heater Block | eBay | $7-8 | |
Barrel (1.75 or 3mm) | eBay | $8-12 | |
PEEK/PTFE groove Mount Assembly | eBay | $22 | |
12V 40W Cartridge heater | eBay | $6 | |
Thermistor with hex housing | eBay | $12 | |
2x M3 set screws (3mm and 6mm long) | Do it Best, Home Depot, Lowe’s, McMaster, Tractor Supply, Wickes, etc | $1 | |
Assembled kit containing all of the above | eBay | $73 |
Magma Hot End
From Trinity Lab. Appears to work with i3 Rework only
Ubis Hot End
Same mount as Jhead.
E3D Hot End
highly recommended on the forums: http://forums.reprap.org/read.php?279,222917,230896#msg-230896
Electronics
There are a huge number of electronics pieces that can be used. Pretty much any complete set of electronics will work with a single extruder i3. If a dual extruder is used, then a 5th stepper driver is necessary. This requires a shield that can hold 5 stepper drivers. See the Comparison of Electronics page for more info. The below list is simplified for ease of use. Shields and CPUs are generally packaged together and labeled as “RAMPS”, “Sanguinololu”, etc. Stepper drivers may or may not be included.
Shield | RAMPS (feature rich option, separate CPU; supports dual extruders) | eBay, or see vendor list | ~$20-40, depending on quality & assembly level |
Sanguinololu without CPU (simple option; onboard CPU; only supports single extruder) | eBay, or see vendor list | ~$20-40, depending on quality and assembly level | |
Gen7 (DIY option, only supports single extruder) | see vendor list | $15 | |
CPU (Arduino Mega with one of several ATmega chips) | Arduino Mega with ATmega2560 or 1280 microcontroller on a board (for RAMPS) | eBay, Arduino website, or see vendor list | ~$15-60 |
Arduino Mega with ATmega 1284P or 644P chip (for Sanguinololu and Gen7; generally included with shield) | eBay | ~$15-50 | |
4x A4988 Stepper drivers (5 needed for dual extruders) | Pololu A4988, with or without overcurrent protection (fuses on shield makes overcurrent redundant, but it can’t hurt) | eBay, Pololu | ~$40-85, depending on number & quality |
StepStick (Imitation Pololu by Joem) | eBay, or see vendor list | ~$25-35, depending on number & quality | |
G3D driver (improved StepStick) | eBay, or see vendor list | $40-50 | |
Connectivity (need at least one method of getting files to printer) | USB cable (RAMPS has a type B receptacle) | eBay, or anywhere else. | $2-5, depending on length |
SD or MicroSD card slot | eBay | ~$10 | |
Sanguinololu Wireless Adapter | ODDepot | $55 | |
Bluetooth mod for BlueSMiRF | SparkFun | ~$9-65 | |
(Optional) Heat Sinks for Stepper Drivers (They run hot!) | Needs thermally conductive adhesive/tape, which may be sold separately. | eBay, or see vendor list | ~$7 |
(Optional) RAMPS Controller display (may contain SD slot) | See RAMPS LCD, GADGETS3D Shield with Panel, and Smart Controller | eBay, or any of the vendor lists | $23-30 |
Kit with all of the above | eBay or RepRap suppliers | $69-89 |
5x or 6x NEMA 17 stepper Motors (2 for x, 1 for y, 1 for z, and 1 per extruder) | The minimum permissible holding torque is around 13.7 N·cm for the axes, and 40.0 N·cm for a Wade's Geared Extruder. Choose motors with ratings around 3-5 V and 1-1.5 A for optimal performance. | eBay, or see NEMA 17 vendor list | $35-90, depending on quality |
1-4 fans (Extruder fan(s), and fan(s) for electronics) | Generally 12V, 40x40mm fans are used | Amazon, eBay, see vendor list | $2-20, depending on number |
3x end-stops | mechanical endstop | see vendor list | $3-6 |
Optical (GEN 7 endstop and Opto Endstop) | Avrthing, eBay | ~$18 | |
Magnetic (hall-effect) | eBay | $42 | |
Power Supply Units for controller electronics* (choose based on electronics. RAMPS uses 12V, and ~20A-30A) | OEM type PSU (designed to be highly customizable for different applications. For this reason, there is no cable or plug panel included with the PSU. In the US, IEC320 C14 connections are common, but use your preferred standard.) | Amazon, eBay | ~$16-38 |
Computer PSU (standard PC PSUs need to support twice the required current**. server PSUs are more stable at their rated max current) | eBay, or somewhere with RepRap electronics | $20-40 | |
AC to DC Power Brick (difficult to find at or above 20A/240W, but a 203W Xbox 360 PSU or an 18A Dell can be converted) | eBay | ~$22 | |
Wires, (and optionally crimps, plugs, solder, etc. depending on what comes with the parts you’ve sourced) | motors, fans, end stops, heated bed, thermistors, and hot-end may not come with wires. 16 or 18 gauge (AWG) should work fine. | Amazon, eBay, etc. | ~$6-$30 |
*Searching for a specific power supply may be ineffective here. It may be more effective to search for Rep-Rap specific power supplies, and then select one that meets your voltage/current criteria, thermal overload/overcurrent protection, etc.
**Standard PC PSU’s tend to offer both +12V and -12V. RAMPS controllers only use the +12V and the ground. As a result, a 300W PSU will have difficulty maintaining more than ~150W. (remember, 1W=1V*1A)
Bed
The build surface is chosen so that the printed filament adheres to it. Various tapes can be used, and have the advantage of being easy to remove from both the piece and the bed underneath. Glass provides poor adhesion, however hairspray or a glue-stick can be used to make a good bond.
The bed doesn’t necessarily have to be heated. If the first few layers of a print cool no uniformly, they have a tendency to curl up like a potato chip. Heating the bed greatly minimizes this problem.
Printed Circuit Boards are the most common type of heated bed. They must be etched from 35µm copper clad silicon, NOT plated. Non-uniform copper will not heat evenly. For especially tall/thin parts, a heated build chamber can be used to reduce warping. See http://reprap.org/wiki/Heated_Bed for more information on bed construction.
(Optional, but highly recommended) Heated bed (generally 214x214mm) | PCB Heated Bed (Most uniform heating. May require LEDs and wires) | eBay, or see vendor list | $13-20 |
Stripboard PCB heating element (cheap, but effective) | VeroBoard | $7 | |
Repurposed heaters (hot-plate, motorcycle grip heater, Silicone heating mat, polyimide film heater, clothes iron, etc.) | eBay | ~$5 and up, depending on heater size/type | |
Heat bed with Aluminum clad resistors (TO220 Resistors fail eventually) | eBay | ~$5 and up, depending on number and size | |
Heat bed by taping down uninsulated wire with Kapton tape (nichrome wire or other) | eBay | $6, but may require $20 fire extinguisher | |
Bed Material/build surface (if using glass/ceramic/metal without tape, you may want to coat with strong hairspray, PVAc glue or a glue-stick to promote adhesion.) | Glass plate/mirror (you can buy precut, or cut it yourself) | eBay | $20 |
Metal (heats evenly, but thin metal warps) | Ace Hardware, Do it Best, Home Depot, Lowe’s, etc. | $5-18, depending on surplus | |
Ceramic tile (Easier to cut/drill than glass, but heats up slowly) | Home Depot, Lowe’s, Wickes, etc. | $3 | |
Tape (kapton or masking tape) | eBay, or pretty much anywhere | $3-22, depending on width | |
4x binder clips | Something to hold the build surface in place (if needed ) | Amazon, eBay, Staples, etc | $1-4 |
Thermistor (required for heated bed) | You may want to purchase this from the same source as your hot end thermistor | eBay | $5 |
Hardware
I could only find two sources for this. One is an [outdated, unofficial, and untested bill of materials]. The other is the BOM for the i3 Rework. I have noted the discrepancies below. Once I build my I3, I will try to update this list with any additions/changes.
11x? linear bearings/bushings (7 for x axis, 3 for y) | LM8UU linear bearings | eBay, or see vendor list | $8-20 |
3D Printed PLA bushings, or commercial bushings (quiet, but lowers positioning precision. You will need a way of attaching them) | Print own, or see vendor list | $0, or $13-18 | |
5x? ball bearings (2x or 4x 608 for x and y, and 1x 624 for y?) | ZZ are the most common, although 2RS or VV may be preferable for a milling and drilling head. | eBay, or see vendor list | $10-20??? |
2x couplers (z-axis) | 5x5mm steel couplers | eBay, or somewhere with RepRap parts | $6-10 |
3d printed couplers (Easy Reliable Coupler, auto-centering coupler, etc) | ??? | $0-??? | |
Stretch 4?mm ID plastic tubing over 5mm rod and motor shaft | Don’t. Just don’t. | $10, for way too much tubing |
(6x M2.5x10 mm machine screw (2 for x axis, 2 for y, 2 for z) ) | Local Hardware store | $ | |
(5x M3x10 mm bolt (3 for x axis, 2 for y) | Local Hardware store | $ | |
(M2 hex bolt for x endstop) | Local Hardware store | $ | |
41x? M3x14 mm screws (X: 10x M3x16 mm machine screw, 2x for endstops (could also be M2 or M2.5) Y: 4x for endstops (could also be M2 or M2.5) ) | Local Hardware store | $ | |
7x? M3x30 mm screws (4x M3 40mm bolts for Print Bed) | Local Hardware store | $ | |
2x? M3x60 mm screws | Local Hardware store | $ | |
6x? M4x20 mm screws | Local Hardware store | $ | |
1x? M8x30 mm screw (X: 1 M8x40 mm bolt Y: 1 M8x40mm bolt) | Local Hardware store | $ | |
1x? M8x20 mm set (grub) screw | Local Hardware store | $ | |
5x? M3x??? mm set (grub) screws (X: 1x M3x8 mm, 1x “M3 grub screw (for pulleys if not included)” Y: 1x M3x8 grub screw (2 if not included with pulley) | Local Hardware store | $ | |
53x? Ø3mm washers | Local Hardware store | $ | |
6x? Ø8mm washers | Local Hardware store | $ | |
34x? Ø10mm washers (y axis) (or 34 M8 washers) | Local Hardware store | $ | |
33x? M3 nuts (2x M2 hex nuts for X endstops) | Local Hardware store | $ | |
6x? M4 nuts (4x for X) | Local Hardware store | $ | |
2x M5 nuts (x axis) | Local Hardware store | $ | |
1x M8 nut (x axis) | Local Hardware store | $ | |
34x? M10 nuts (y axis) (or 35 M8 nuts???) | Local Hardware store | $ | |
1x? M8 Nylstop nut | Local Hardware store | $ | |
?x zip ties | Local Hardware store | $ |
