PonokoYInstallation
Revision as of 22:55, 13 December 2008 by RussNelson (talk | contribs) (version migrated from twiki)
Ponoko RepRap - Installing The Y Axis
[PonokoRepRap Main Ponoko Page]
Prev StepNext Step
The Y axis needs to be clamped between two uprights. One of the uprights are the 500mm rods which extend up through the Upper Corners. You'll add another post to the Upper Corners.
<repeat count="4">
Secure the short Y post with <part>two M5 nut</part>s and <part>two M5 8mm grub screw</part>s.
</repeat>
Loosen the M8 nut on the Y Idler enough to place the two Y posts between the plates. Tighten it finger-tight.
Loosen the M3 screws and slide the Y Motor Mount over the two Y posts. Tighten.
After you finish with the Y Motor Mount, go to the other end of this shaft and tighten its M3 screws.
Prev StepNext Step
-- Main.VikOlliver - 28 Nov 2008
