PonokoFrameUpperAssembly
Revision as of 17:49, 7 December 2008 by RussNelson (talk | contribs) (version migrated from twiki)
Making the Ponoko RepRap Upper Framework
[PonokoRepRap Main Ponoko Page]
Prev StepNext Step
UNDER CONSTRUCTION
When assembling the framework, remember that it is what makes the RepRap move in straight lines. The straighter and squarer you make it, the better your RepRap will be. Check all rotating threaded rods and plain rods that are used as slides to make sure they are dead straight. You can sight down them as I'm doing in this photo, or you can roll them bacn and forth on a dead-flat surface. If it doesn't roll smoothly, it's not straight. If not straight enough, clout them into line with a block of firewood or rubber mallet - nothing that will damage the surface.
Ran out of words. Off to library to get more.
Prev StepNext Step
-- Main.VikOlliver - 14 Nov 2008
