PonokoFrameBaseAssembly
Revision as of 00:47, 19 November 2008 by VikOlliver (talk | contribs) (version migrated from twiki)
Assembling The Ponoko RepRap Frame Base
UNDER CONSTRUCTION
The Frame Base is assembled largely from the parts you have already built: Lower Corners and Z Motor Assembly. Also included in this section are the Z Axis Drive Rods, or "Z Kebabs" which are fitted into bearings in the base, forming the mechanism that raises and lowers the RepRap's build bed.
Now you can move on to building the Z Frame. -- Main.VikOlliver - 19 Nov 2008
